Rtems-test with qemu integration for pc386
Krzysztof Mięsowicz
krzysztof.miesowicz at gmail.com
Tue Jul 1 19:32:37 UTC 2014
Chris, I would like to ask where should I put rtems-boot hd image needed to
run pc386 on qemu. Should I create some directory under rtems-tools and put
image into it?
2014-06-27 3:34 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> On Thu, Jun 26, 2014 at 5:26 PM, Chris Johns <chrisj at rtems.org> wrote:
> > On 27/06/2014 4:09 am, Joel Sherrill wrote:
> >> See pc386/configure.ac for this
> >> RTEMS_BSP_CLEANUP_OPTIONS(1, 1)
> >> dnl argument 1 indicates the default value for
> BSP_PRESS_KEY_FOR_RESET
> >> dnl argument 2 indicates the default value for
> BSP_RESET_BOARD_AT_EXIT
> >> Sounds like the default should change or the test build needs to pass
> >> in BSP_PRESS_KEY_FOR_RESET=0.
> > Yes please or even remove this code from the BSP. It is not a good thing
> to
> > have in an embedded system. This is system and app level type
> functionality.
> +1
> > Chris
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140701/03b684ab/attachment.html>
