Function pointer within isr
Wed Jul 2 13:15:45 UTC 2014
On 7/1/2014 3:37 PM, Peter Dufault wrote:
> On Jun 30, 2014, at 14:41 , Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
>> Is your "struct handler_arguments" declared on the stack (e.g. an
>> automatic variable)? If so, then the memory is likely clobbered by
>> the time the ISR runs.
> Not necessarily. A common method would be:
> thread_to_process_something() {
> 	struct handler_arguments on_stack;
> 	install_isr_that_uses_on_stack();
> 	while (work_to_do_with_isr()) {
> 		receive_and_process_semaphore_from_isr();
> 	shutdown_isr();
> You just need to ensure that the stack isn't out of scope when the isr can fire.
Good point but most code is going to have an initialization subroutine
like a device driver initialization routine that is called as the system is
brought up.
But a device driver dedicated task that encapsulates everything including
initialization wouldn't have this problem.
> You can't do this on systems that have per-thread stacks that are only mapped when the thread is active, but I don't know of any RTEMS usage of that.  I've used multi-processor systems that have that attribute.
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
