[PATCH 3/5 v2] SPARC: add BSP specific error handler
Daniel Hellstrom daniel at gaisler.com
Thu Jul 3 07:29:28 UTC 2014
PATCHv2: BSP_fatal_exit defined in header
Instead of calling the system call TA instruction directly it
is better paractise to isolate the trap implementation to the
system call functions.
BSP_fatal_exit() is added.
 c/src/lib/libbsp/sparc/erc32/Makefile.am           |    1 +
 c/src/lib/libbsp/sparc/erc32/include/bsp.h         |    2 ++
 c/src/lib/libbsp/sparc/leon2/Makefile.am           |    1 +
 c/src/lib/libbsp/sparc/leon2/include/bsp.h         |    2 ++
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |    1 +
 c/src/lib/libbsp/sparc/leon3/include/bsp.h         |    2 ++
 c/src/lib/libbsp/sparc/shared/start/start.S        |    5 ++---
 .../libbsp/sparc/shared/startup/bsp_fatal_exit.c   |   19 +++++++++++++++++++
 8 files changed, 30 insertions(+), 3 deletions(-)
 create mode 100644 c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_exit.c
diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
index d5de377..b9f1c53 100644
--- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
+++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
@@ -45,6 +45,7 @@ libbsp_a_SOURCES += startup/boardinit.S
 libbsp_a_SOURCES += startup/bspidle.c
 libbsp_a_SOURCES += startup/bspdelay.c
 libbsp_a_SOURCES += ../../sparc/shared/startup/early_malloc.c
+libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_exit.c
 # ISR Handler
 libbsp_a_SOURCES += ../../sparc/shared/cpu.c
 libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
index fbe8988..b1cc83e 100644
--- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
@@ -92,6 +92,8 @@ rtems_isr_entry set_vector(                     /* returns old vector */
     int                 type                    /* RTEMS or RAW intr  */
+void BSP_fatal_exit(uint32_t error);
 void bsp_spurious_initialize( void );
 /* Allocate 8-byte aligned non-freeable pre-malloc() memory. The function
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index e808b33..3f8edf4 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -60,6 +60,7 @@ libbsp_a_SOURCES += startup/bspidle.c
 libbsp_a_SOURCES += ../../shared/bspinit.c
 # ISR Handler
diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
index 63af19e..1943baf 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
@@ -113,6 +113,8 @@ rtems_isr_entry set_vector(                     /* returns old vector */
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 5dd43c3..54c9f22 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -41,6 +41,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
     ../../shared/bspinit.c ../../sparc/shared/startup/early_malloc.c
 libbsp_a_SOURCES += startup/bspreset.c
 libbsp_a_SOURCES += startup/cpucounter.c
 # ISR Handler
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index ce4fe09..5f6f0a0 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -131,6 +131,8 @@ rtems_isr_entry set_vector(                     /* returns old vector */
diff --git a/c/src/lib/libbsp/sparc/shared/start/start.S b/c/src/lib/libbsp/sparc/shared/start/start.S
index e621c39..8f10000 100644
--- a/c/src/lib/libbsp/sparc/shared/start/start.S
+++ b/c/src/lib/libbsp/sparc/shared/start/start.S
@@ -368,9 +368,8 @@ zerobss:
 #if !defined(START_LEON3_ENABLE_SMP)
         PUBLIC(bsp_reset)
 SYM(bsp_reset):
-	mov	1, %g1
-        ta      0                       ! Halt if _main returns ...
-        nop
+        call    SYM(BSP_fatal_exit)
+         clr     %o0
 #endif
 /* end of file */
diff --git a/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_exit.c b/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_exit.c
new file mode 100644
index 0000000..c7ba6c2
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_exit.c
@@ -0,0 +1,19 @@
+ * @file
+ * @ingroup sparc_bsp
+ * @brief ERC32/LEON2/LEON3 BSP specific exit handler.
+ *  COPYRIGHT (c) 2014.
+ *  Aeroflex Gaisler AB.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <rtems.h>
+  sparc_syscall_exit(RTEMS_FATAL_SOURCE_BSP, error);
1.7.0.4
