[PATCH 2/5 v2] SPARC BSPs: remove BSP_fatal_return unreached code
Daniel Hellstrom daniel at gaisler.com
Thu Jul 3 07:29:27 UTC 2014
PATCHv2: unreachable code after SMP secondary CPU init or boot_card
         calls, is now removed instead of cleaned-up.
 c/src/lib/libbsp/sparc/erc32/include/bsp.h  |    2 --
 c/src/lib/libbsp/sparc/leon2/include/bsp.h  |    2 --
 c/src/lib/libbsp/sparc/leon3/include/bsp.h  |    2 --
 c/src/lib/libbsp/sparc/shared/start/start.S |    9 ++-------
 4 files changed, 2 insertions(+), 13 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
index 775a19f..fbe8988 100644
--- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
@@ -92,8 +92,6 @@ rtems_isr_entry set_vector(                     /* returns old vector */
     int                 type                    /* RTEMS or RAW intr  */
-void BSP_fatal_return( void );
 void bsp_spurious_initialize( void );
 /* Allocate 8-byte aligned non-freeable pre-malloc() memory. The function
diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
index 0bb0eef..63af19e 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
@@ -113,8 +113,6 @@ rtems_isr_entry set_vector(                     /* returns old vector */
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index cb15796..ce4fe09 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -131,8 +131,6 @@ rtems_isr_entry set_vector(                     /* returns old vector */
diff --git a/c/src/lib/libbsp/sparc/shared/start/start.S b/c/src/lib/libbsp/sparc/shared/start/start.S
index 070387f..e621c39 100644
--- a/c/src/lib/libbsp/sparc/shared/start/start.S
+++ b/c/src/lib/libbsp/sparc/shared/start/start.S
@@ -252,8 +252,6 @@ SYM(hard_reset):
 	call	SYM(bsp_start_on_secondary_processor) ! does not return
 	 sub	%sp, CPU_MINIMUM_STACK_FRAME_SIZE, %sp
-	ba	SYM(bsp_reset)		! just in case
-	 nop
 cpu0:
 #endif
@@ -364,14 +362,11 @@ zerobss:
         nop
         mov     %0, %o0                 ! command line
-        call    SYM(boot_card)
-        sub     %sp, 0x60, %sp          ! room for boot_card to save args
-        nop
+        call    SYM(boot_card)          ! does not return
+         sub     %sp, 0x60, %sp         ! room for boot_card to save args
 #if !defined(START_LEON3_ENABLE_SMP)
-        PUBLIC(BSP_fatal_return)
         PUBLIC(bsp_reset)
-SYM(BSP_fatal_return):
 SYM(bsp_reset):
 	mov	1, %g1
         ta      0                       ! Halt if _main returns ...
1.7.0.4
