[PATCH 1/2] bsp/sparc: Ensure that data cache snooping is enabled
Fri Jul 4 06:02:22 UTC 2014
On 2014-07-03 11:39, Daniel Cederman wrote:
> @@ -39,7 +40,9 @@ void bsp_start_on_secondary_processor()
>     uint32_t cpu_index_self = _CPU_SMP_Get_current_processor();
> -  leon3_set_cache_control_register(0x80000F);
> +  if( ! leon3_data_cache_snooping_enabled() )
> +    BSP_fatal_exit( LEON3_FATAL_INVALID_CACHE_CONFIG );
>     /* Unmask IPI interrupts at Interrupt controller for this CPU */
>     LEON3_IrqCtrl_Regs->mask[cpu_index_self] |= 1U << LEON3_MP_IRQ;
> @@ -48,7 +51,8 @@ void bsp_start_on_secondary_processor()
>   uint32_t _CPU_SMP_Initialize( void )
> +    bsp_fatal( LEON3_FATAL_INVALID_CACHE_CONFIG );
>     if ( rtems_configuration_get_maximum_processors() > 1 ) {
>       LEON_Unmask_interrupt(LEON3_MP_IRQ);
Fatal error codes should uniquely identify the code location, so you should use
two error codes here.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
