[PATCH 3/3] score: Add SMP support to the cache manager
Fri Jul 4 06:38:59 UTC 2014
On 2014-07-03 11:37, Daniel Cederman wrote:
> Adds functions that allows the user to specify which cores that should
> perform the cache operation. SMP messages are sent to all the specified
> cores and the caller waits until all cores have acknowledged that they
> have flushed their cache. Implementation is shown using both function
> pointers and function ids together with a switch statement. One needs
> to be dropped before committing. Any preference?
>   c/src/lib/libcpu/shared/src/cache_manager.c |  166 +++++++++++++++++++++++++++
>   cpukit/rtems/include/rtems/rtems/cache.h    |   84 ++++++++++++++
>   cpukit/score/include/rtems/score/smpimpl.h  |   13 +++
>   3 files changed, 263 insertions(+)
> diff --git a/c/src/lib/libcpu/shared/src/cache_manager.c b/c/src/lib/libcpu/shared/src/cache_manager.c
> index 420a013..91e9f72 100644
> --- a/c/src/lib/libcpu/shared/src/cache_manager.c
> +++ b/c/src/lib/libcpu/shared/src/cache_manager.c
> @@ -37,6 +37,172 @@
>   #include <rtems.h>
>   #include "cache_.h"
> +#include <rtems/score/smplock.h>
> +#include <rtems/score/smpimpl.h>
> +#if defined( RTEMS_SMP )
> +typedef void (*cache_manager_func_t)(const void * d_addr, size_t n_bytes);
The *_t namespace is reserved by POSIX.  The names don't follow the score
naming conventions.
http://www.rtems.org/wiki/index.php/Naming_rules
> +typedef enum {
> +  FLUSH_MULTIPLE_DATA_LINES,
> +  INVALIDATE_MULTIPLE_DATA_LINES,
> +  INVALIDATE_MULTIPLE_INSTRUCTION_LINES,
> +  FLUSH_ENTIRE_DATA,
> +  INVALIDATE_ENTIRE_INSTRUCTION,
> +  INVALIDATE_ENTIRE_DATA
> +} cache_manager_func_id_t;
> +typedef struct {
> +  SMP_lock_Control lock;
> +  cache_manager_func_t func;
> +  cache_manager_func_id_t func_id;
> +  Atomic_Uint count;
> +  const void *addr;
> +  size_t size;
> +} Cache_Manager_SMP;
> +static Cache_Manager_SMP _CM_SMP = {
> +  .lock = SMP_LOCK_INITIALIZER("CacheMgr"),
> +  .count = CPU_ATOMIC_INITIALIZER_UINT(0)
> +void
> +_SMP_Cache_manager_ipi_handler(void)
I would rather name this _SMP_Cache_manager_message_handler().
> +#ifdef USE_FUNCPTR
> +  _CM_SMP.func( _CM_SMP.addr, _CM_SMP.size );
> +#else
> +  switch( _CM_SMP.func_id ) {
> +    case FLUSH_MULTIPLE_DATA_LINES:
> +      rtems_cache_flush_multiple_data_lines(
> +          _CM_SMP.addr, _CM_SMP.size );
> +      break;
> +    case INVALIDATE_MULTIPLE_DATA_LINES:
> +      rtems_cache_invalidate_multiple_data_lines(
> +      break;
> +    case INVALIDATE_MULTIPLE_INSTRUCTION_LINES:
> +      rtems_cache_invalidate_multiple_instruction_lines(
> +      break;
> +    case FLUSH_ENTIRE_DATA:
> +      rtems_cache_flush_entire_data();
> +      break;
> +    case INVALIDATE_ENTIRE_INSTRUCTION:
> +      rtems_cache_invalidate_entire_instruction();
> +      break;
> +    case INVALIDATE_ENTIRE_DATA:
> +      rtems_cache_invalidate_entire_data();
> +      break;
> +    default:
> +      _Assert( 0 );
> +      break;
> +#endif
> +  _Atomic_Fetch_sub_uint( &_CM_SMP.count, 1, ATOMIC_ORDER_RELEASE );
> +static void
> +_cache_manager_send_ipi_msg( const cpu_set_t *set, cache_manager_func_t func,
> +    cache_manager_func_id_t func_id, const void * addr, size_t size )
> +  uint32_t i;
> +  uint32_t set_size = 0;
> +  SMP_lock_Context lock_context;
> +  _Assert( _System_state_Is_up( _System_state_Get() ) );
> +  for( i=0; i < _SMP_Get_processor_count(); ++i ) {
> +    set_size += CPU_ISSET(i, set);
> +  _SMP_lock_Acquire( &_CM_SMP.lock, &lock_context );
With this implementation cache routines must not be called from interrupt
context.  This should be mentioned in the documentation.
It is extremely difficult to implement it in a way so that it can be used from
interrupt context.
> +  _CM_SMP.func = func;
> +  _CM_SMP.func_id = func_id;
> +  _CM_SMP.addr = addr;
> +  _CM_SMP.size = size;
> +  _Atomic_Store_uint( &_CM_SMP.count, set_size, ATOMIC_ORDER_RELEASE );
> +  _Atomic_Fence( ATOMIC_ORDER_RELEASE );
> +  _SMP_Send_message_cpu_set( set, SMP_MESSAGE_CACHE_MANAGER );
> +  while(_Atomic_Load_uint( &_CM_SMP.count, ATOMIC_ORDER_ACQUIRE ) != 0 );
> +  _SMP_lock_Release( &_CM_SMP.lock, &lock_context );
> +void
> +rtems_cache_invalidate_entire_instruction_cpu_set ( const cpu_set_t *set )
This limits the API to the default cpu_set_t.  Other routines like
pthread_setaffinity_np() don't have this limitation.
On other places we don't use "cpu" instead we use "processor" it should be
consistent in the high level RTEMS APIs.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
