[PATCH 3/3] score: Add SMP support to the cache manager
Joel Sherrill
Joel.Sherrill at OARcorp.com
Fri Jul 4 15:24:30 UTC 2014
On Jul 4, 2014 10:09 AM, Daniel Cederman <cederman at gaisler.com> wrote:
> > This limits the API to the default cpu_set_t. Other routines like
> > pthread_setaffinity_np() don't have this limitation.
> I looked at pthread_setaffinity_np() and got a bit confused. I see that
> it takes both a pointer to a cpu_set_t and the size of the cpu set. It
> forwards it to _Scheduler_Set_affinity which requires
> __RTEMS_HAVE_SYS_CPUSET_H__ to be defined. If this is defined then
> _CPU_set_Handler_initialization checks that the number of cpus is less
> than CPU_SETSIZE. In newlib this is defined to 32 and is used to size
> the cpu_set_t struct. So why is the size needed for
> pthread_setaffinity_np if the number of cpus cannot exceed a hardcoded
> constant? I recall that there was a discussion on the list about cpu
> sets, but I'm not finding anything searching.
This keeps the API compatible with Linux and *BSD even though we don't support more than 32 yet. So planning ahead.
> Daniel Cederman
> Software Engineer
> Aeroflex Gaisler AB
> Aeroflex Microelectronic Solutions – HiRel
> Kungsgatan 12
> SE-411 19 Gothenburg, Sweden
> Phone: +46 31 7758665
> www.Aeroflex.com/Gaisler
> On 2014-07-04 08:38, Sebastian Huber wrote:
> > On 2014-07-03 11:37, Daniel Cederman wrote:
> >> Adds functions that allows the user to specify which cores that should
> >> perform the cache operation. SMP messages are sent to all the specified
> >> cores and the caller waits until all cores have acknowledged that they
> >> have flushed their cache. Implementation is shown using both function
> >> pointers and function ids together with a switch statement. One needs
> >> to be dropped before committing. Any preference?
> >> c/src/lib/libcpu/shared/src/cache_manager.c | 166
> >> cpukit/rtems/include/rtems/rtems/cache.h | 84 ++++++++++++++
> >> cpukit/score/include/rtems/score/smpimpl.h | 13 +++
> >> 3 files changed, 263 insertions(+)
> >> diff --git a/c/src/lib/libcpu/shared/src/cache_manager.c
> >> b/c/src/lib/libcpu/shared/src/cache_manager.c
> >> index 420a013..91e9f72 100644
> >> --- a/c/src/lib/libcpu/shared/src/cache_manager.c
> >> +++ b/c/src/lib/libcpu/shared/src/cache_manager.c
> >> @@ -37,6 +37,172 @@
> >> #include <rtems.h>
> >> #include "cache_.h"
> >> +#include <rtems/score/smplock.h>
> >> +#include <rtems/score/smpimpl.h>
> >> +#if defined( RTEMS_SMP )
> >> +typedef void (*cache_manager_func_t)(const void * d_addr, size_t
> >> n_bytes);
> > The *_t namespace is reserved by POSIX. The names don't follow the
> > score naming conventions.
> > http://www.rtems.org/wiki/index.php/Naming_rules
> >> +typedef enum {
> >> + FLUSH_MULTIPLE_DATA_LINES,
> >> + INVALIDATE_MULTIPLE_DATA_LINES,
> >> + INVALIDATE_MULTIPLE_INSTRUCTION_LINES,
> >> + FLUSH_ENTIRE_DATA,
> >> + INVALIDATE_ENTIRE_INSTRUCTION,
> >> + INVALIDATE_ENTIRE_DATA
> >> +} cache_manager_func_id_t;
> >> +typedef struct {
> >> + SMP_lock_Control lock;
> >> + cache_manager_func_t func;
> >> + cache_manager_func_id_t func_id;
> >> + Atomic_Uint count;
> >> + const void *addr;
> >> + size_t size;
> >> +} Cache_Manager_SMP;
> >> +static Cache_Manager_SMP _CM_SMP = {
> >> + .lock = SMP_LOCK_INITIALIZER("CacheMgr"),
> >> + .count = CPU_ATOMIC_INITIALIZER_UINT(0)
> >> +void
> >> +_SMP_Cache_manager_ipi_handler(void)
> > I would rather name this _SMP_Cache_manager_message_handler().
> >> +#ifdef USE_FUNCPTR
> >> + _CM_SMP.func( _CM_SMP.addr, _CM_SMP.size );
> >> +#else
> >> + switch( _CM_SMP.func_id ) {
> >> + case FLUSH_MULTIPLE_DATA_LINES:
> >> + rtems_cache_flush_multiple_data_lines(
> >> + _CM_SMP.addr, _CM_SMP.size );
> >> + break;
> >> + case INVALIDATE_MULTIPLE_DATA_LINES:
> >> + rtems_cache_invalidate_multiple_data_lines(
> >> + break;
> >> + case INVALIDATE_MULTIPLE_INSTRUCTION_LINES:
> >> + rtems_cache_invalidate_multiple_instruction_lines(
> >> + break;
> >> + case FLUSH_ENTIRE_DATA:
> >> + rtems_cache_flush_entire_data();
> >> + break;
> >> + case INVALIDATE_ENTIRE_INSTRUCTION:
> >> + rtems_cache_invalidate_entire_instruction();
> >> + break;
> >> + case INVALIDATE_ENTIRE_DATA:
> >> + rtems_cache_invalidate_entire_data();
> >> + break;
> >> + default:
> >> + _Assert( 0 );
> >> + break;
> >> +#endif
> >> + _Atomic_Fetch_sub_uint( &_CM_SMP.count, 1, ATOMIC_ORDER_RELEASE );
> >> +static void
> >> +_cache_manager_send_ipi_msg( const cpu_set_t *set,
> >> cache_manager_func_t func,
> >> + cache_manager_func_id_t func_id, const void * addr, size_t size )
> >> + uint32_t i;
> >> + uint32_t set_size = 0;
> >> + SMP_lock_Context lock_context;
> >> + _Assert( _System_state_Is_up( _System_state_Get() ) );
> >> + for( i=0; i < _SMP_Get_processor_count(); ++i ) {
> >> + set_size += CPU_ISSET(i, set);
> >> + _SMP_lock_Acquire( &_CM_SMP.lock, &lock_context );
> > With this implementation cache routines must not be called from
> > interrupt context. This should be mentioned in the documentation.
> > It is extremely difficult to implement it in a way so that it can be
> > used from interrupt context.
> >> + _CM_SMP.func = func;
> >> + _CM_SMP.func_id = func_id;
> >> + _CM_SMP.addr = addr;
> >> + _CM_SMP.size = size;
> >> + _Atomic_Store_uint( &_CM_SMP.count, set_size, ATOMIC_ORDER_RELEASE );
> >> + _Atomic_Fence( ATOMIC_ORDER_RELEASE );
> >> + _SMP_Send_message_cpu_set( set, SMP_MESSAGE_CACHE_MANAGER );
> >> + while(_Atomic_Load_uint( &_CM_SMP.count, ATOMIC_ORDER_ACQUIRE ) !=
> >> 0 );
> >> + _SMP_lock_Release( &_CM_SMP.lock, &lock_context );
> >> +void
> >> +rtems_cache_invalidate_entire_instruction_cpu_set ( const cpu_set_t
> >> *set )
> > On other places we don't use "cpu" instead we use "processor" it should
> > be consistent in the high level RTEMS APIs.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140704/0654d080/attachment-0001.html>
