[PATCH] Fix RTL colon problem
Peng Fan van.freenix at gmail.com
Sat Jul 5 07:22:06 UTC 2014
Hi,
When loading an object file which is in an archive file using such a
command "dlo tmp.ra:xx.rap", it shows file not found. This patch fix it.
Regards,
Peng.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140705/f1838107/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140705/f1838107/attachment-0001.obj>
