[GSOC] GPIO status and I2C start
Andre Marques
andre.lousa.marques at gmail.com
Sat Jul 5 22:58:23 UTC 2014
Hello,
The Raspberry Pi GPIO interrupts are already working, and a test case is
available to test that [1]. A function is also provided to debounce a
switch if needed. The test case requires two switches and two LEDS using
the same setup described at [2] by only changing the pin numbers.
The test works by setting interrupts on both edges of the switches,
which handlers will turn on or off the corresponding LED. One of the
LEDs also has a level interrupt which prints a message on the screen
when the LED is on (high level).
While I wait for some feedback on that, I will be looking at the next
step: the I2C interface. To test both the I2C and the SPI interfaces I
have here a simple display [3]. The idea is to create a low level driver
for I2C to provide the needed directives for the libi2c API, so the
driver for the display will actually use the libi2c API. Any thoughts
here are welcome too!
Thanks,
André Marques.
[1] -
https://github.com/asuol/rtems/blob/GPIO_API/testsuites/samples/LIBGPIO_TEST_IQR/init.c
[2] - http://asuolgsoc2014.wordpress.com/2014/06/22/testing-the-gpio-api/
[3] - http://www.newhavendisplay.com/nhd0216k3zflgbwv3-p-5738.html
