[PATCH 4/4] bsps/sparc: Move APBUART printk support
Mon Jul 7 11:39:19 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 .../libbsp/sparc/leon3/console/printk_support.c    |   51 --------------------
 c/src/lib/libbsp/sparc/leon3/include/leon.h        |   19 -------
 .../libbsp/sparc/shared/include/apbuart_termios.h  |   19 +++++++
 .../lib/libbsp/sparc/shared/uart/apbuart_termios.c |   51 ++++++++++++++++++++
 4 files changed, 70 insertions(+), 70 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
index d12099b..03021c7 100644
--- a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
+++ b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
@@ -75,57 +75,6 @@ void bsp_debug_uart_init(void)
- *  apbuart_outbyte_polled
- *  This routine transmits a character using polling.
-void apbuart_outbyte_polled(
-  struct apbuart_regs *regs,
-  unsigned char ch,
-  int do_cr_on_newline,
-  int wait_sent
-send:
-  while ( (regs->status & APBUART_STATUS_TE) == 0 ) {
-    /* Lower bus utilization while waiting for UART */
-    __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
-  regs->data = (unsigned int) ch;
-  if ((ch == '\n') && do_cr_on_newline) {
-    ch = '\r';
-    goto send;
-  /* Wait until the character has been sent? */
-  if (wait_sent) {
-    while ((regs->status & APBUART_STATUS_TE) == 0)
- *  apbuart_inbyte_nonblocking
- *  This routine polls for a character.
-int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
-  /* Clear errors */
-  if (regs->status & APBUART_STATUS_ERR)
-    regs->status = ~APBUART_STATUS_ERR;
-  if ((regs->status & APBUART_STATUS_DR) == 0)
-    return EOF;
-  else
-    return (int) regs->data;
 /* putchar/getchar for printk */
 static void bsp_out_char(char c)
diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
index d7048f3..1fc4e28 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
@@ -278,25 +278,6 @@ extern int syscon_uart_index;
 extern int debug_uart_index;
-  unsigned char ch,
-  int wait_sent
-int apbuart_inbyte_nonblocking(struct apbuart_regs *regs);
 void leon3_cpu_counter_initialize(void);
 /* GRLIB extended IRQ controller register */
diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h b/c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h
index 4b54252..ba5f049 100644
--- a/c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h
+++ b/c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h
@@ -33,6 +33,25 @@ const rtems_termios_device_handler apbuart_handler_interrupt;
 const rtems_termios_device_handler apbuart_handler_polled;
+ *  apbuart_outbyte_polled
+ *  This routine transmits a character using polling.
+void apbuart_outbyte_polled(
+  struct apbuart_regs *regs,
+  unsigned char ch,
+  int do_cr_on_newline,
+  int wait_sent
+ *  apbuart_inbyte_nonblocking
+ *  This routine polls for a character.
+int apbuart_inbyte_nonblocking(struct apbuart_regs *regs);
 #ifdef __cplusplus
 #endif /* __cplusplus */
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c
index 4b69e1b..58822c5 100644
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c
+++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c
@@ -223,6 +223,57 @@ static void apbuart_last_close_interrupt(
   rtems_interrupt_handler_remove(uart->irq, apbuart_isr, tty);
+  unsigned char ch,
+  int wait_sent
+send:
+  while ( (regs->status & APBUART_STATUS_TE) == 0 ) {
+    /* Lower bus utilization while waiting for UART */
+    __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
+  regs->data = (unsigned int) ch;
+  if ((ch == '\n') && do_cr_on_newline) {
+    ch = '\r';
+    goto send;
+  /* Wait until the character has been sent? */
+  if (wait_sent) {
+    while ((regs->status & APBUART_STATUS_TE) == 0)
+  /* Clear errors */
+  if (regs->status & APBUART_STATUS_ERR)
+    regs->status = ~APBUART_STATUS_ERR;
+  if ((regs->status & APBUART_STATUS_DR) == 0)
+    return -1;
+  else
+    return (int) regs->data;
 const rtems_termios_device_handler apbuart_handler_interrupt = {
   .first_open = apbuart_first_open_interrupt,
   .last_close = apbuart_last_close_interrupt,
1.7.7
