Fwd: [PATCH] Add const qualifier in <sys/cpuset.h>
Mon Jul 7 21:27:28 UTC 2014
Hi Chris,
I added this patch to rtems-tools. Attached is a patch to
RSB to use it for the sparc tools. If this looks OK, should
I make a similar update to all applicable 4.11 targets?
--joel
-------- Original Message --------
Subject: 	[PATCH] Add const qualifier in <sys/cpuset.h>
Date: 	Mon, 14 Apr 2014 08:43:46 -0500
From: 	Sebastian Huber <sebastian.huber at embedded-brains.de>
To: 	newlib at sourceware.org <newlib at sourceware.org>
CC: 	Sebastian Huber <sebastian.huber at embedded-brains.de>
newlib/ChangeLog
2014-04-14  Sebastian Huber  <sebastian.huber at embedded-brains.de>
	* libc/sys/rtems/sys/cpuset.h (CPU_SET_S): Add const qualifier.
	(CPU_SET): Likewise.
 newlib/libc/sys/rtems/sys/cpuset.h |    4 ++--
 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/newlib/libc/sys/rtems/sys/cpuset.h b/newlib/libc/sys/rtems/sys/cpuset.h
index 2818677..8fae475 100644
--- a/newlib/libc/sys/rtems/sys/cpuset.h
+++ b/newlib/libc/sys/rtems/sys/cpuset.h
@@ -153,14 +153,14 @@ static __inline void CPU_CLR(int cpu, cpu_set_t *set)
   CPU_CLR_S(cpu, sizeof(*set), set);
-static __inline int CPU_ISSET_S(int cpu, size_t setsize, cpu_set_t *set)
+static __inline int CPU_ISSET_S(int cpu, size_t setsize, const cpu_set_t *set)
   const cpu_set_word_t *w = &set->__bits[0];
   return ((w[__cpuset_index(cpu)] & __cpuset_mask(cpu)) != 0);
-static __inline int CPU_ISSET(int cpu, cpu_set_t *set)
+static __inline int CPU_ISSET(int cpu, const cpu_set_t *set)
   return CPU_ISSET_S(cpu, sizeof(*set), set);
1.7.7
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140707/90da215f/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140707/90da215f/attachment.bin>
