[PATCH 2/2] smptests/smpmrsp01: Add and update test cases
Tue Jul 8 15:05:53 UTC 2014
 testsuites/smptests/smpmrsp01/init.c        |  428 +++++++++++++++++++++---
 testsuites/smptests/smpmrsp01/smpmrsp01.scn |  477 +++++++++++++++++++--------
 2 files changed, 720 insertions(+), 185 deletions(-)
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index b93f196..ce22c25 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -21,7 +21,9 @@
 #include <rtems/libcsupport.h>
+#include <rtems/score/schedulersmpimpl.h>
 #include <rtems/score/smpbarrier.h>
+#include <rtems/score/smplock.h>
 #define TESTS_USE_PRINTK
 #include "tmacros.h"
@@ -32,27 +34,43 @@ const char rtems_test_name[] = "SMPMRSP 1";
 #define MRSP_COUNT 32
+#define SWITCH_EVENT_COUNT 32
 typedef struct {
   uint32_t sleep;
   uint32_t timeout;
   uint32_t obtain[MRSP_COUNT];
+  uint32_t cpu[CPU_COUNT];
 } counter;
 typedef struct {
+  uint32_t cpu_index;
+  const Thread_Control *executing;
+  const Thread_Control *heir;
+  const Thread_Control *heir_node;
+  Priority_Control heir_priority;
+} switch_event;
+typedef struct {
   rtems_id main_task_id;
+  rtems_id migration_task_id;
   rtems_id counting_sem_id;
   rtems_id mrsp_ids[MRSP_COUNT];
   rtems_id scheduler_ids[CPU_COUNT];
   rtems_id worker_ids[2 * CPU_COUNT];
-  rtems_id timer_id;
   volatile bool stop_worker[CPU_COUNT];
   counter counters[2 * CPU_COUNT];
+  uint32_t migration_counters[CPU_COUNT];
   Thread_Control *worker_task;
   SMP_barrier_Control barrier;
+  SMP_lock_Control switch_lock;
+  size_t switch_index;
+  switch_event switch_events[32];
 } test_context;
 static test_context test_instance = {
-  .barrier = SMP_BARRIER_CONTROL_INITIALIZER
+  .barrier = SMP_BARRIER_CONTROL_INITIALIZER,
+  .switch_lock = SMP_LOCK_INITIALIZER("test instance switch lock")
 static void barrier(test_context *ctx, SMP_barrier_State *bs)
@@ -60,14 +78,27 @@ static void barrier(test_context *ctx, SMP_barrier_State *bs)
   _SMP_barrier_Wait(&ctx->barrier, bs, 2);
-static void assert_prio(rtems_id task_id, rtems_task_priority expected_prio)
+static rtems_task_priority get_prio(rtems_id task_id)
   rtems_status_code sc;
   rtems_task_priority prio;
   sc = rtems_task_set_priority(task_id, RTEMS_CURRENT_PRIORITY, &prio);
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  rtems_test_assert(prio == expected_prio);
+  return prio;
+static void wait_for_prio(rtems_id task_id, rtems_task_priority prio)
+  while (get_prio(task_id) != prio) {
+    /* Wait */
+static void assert_prio(rtems_id task_id, rtems_task_priority expected_prio)
+  rtems_test_assert(get_prio(task_id) == expected_prio);
 static void change_prio(rtems_id task_id, rtems_task_priority prio)
@@ -85,6 +116,78 @@ static void assert_executing_worker(test_context *ctx)
+static void switch_extension(Thread_Control *executing, Thread_Control *heir)
+  test_context *ctx = &test_instance;
+  SMP_lock_Context lock_context;
+  size_t i;
+  _SMP_lock_ISR_disable_and_acquire(&ctx->switch_lock, &lock_context);
+  i = ctx->switch_index;
+  if (i < SWITCH_EVENT_COUNT) {
+    switch_event *e = &ctx->switch_events[i];
+    Scheduler_SMP_Node *node = _Scheduler_SMP_Thread_get_node(heir);
+    e->cpu_index = rtems_get_current_processor();
+    e->executing = executing;
+    e->heir = heir;
+    e->heir_node = _Scheduler_Node_get_owner(&node->Base);
+    e->heir_priority = node->priority;
+    ctx->switch_index = i + 1;
+  _SMP_lock_Release_and_ISR_enable(&ctx->switch_lock, &lock_context);
+static void reset_switch_events(test_context *ctx)
+  ctx->switch_index = 0;
+static size_t get_switch_events(test_context *ctx)
+  size_t events;
+  events = ctx->switch_index;
+  return events;
+static void print_switch_events(test_context *ctx)
+  size_t n = get_switch_events(ctx);
+  size_t i;
+  for (i = 0; i < n; ++i) {
+    char ex[5];
+    char hr[5];
+    char hn[5];
+    rtems_object_get_name(e->executing->Object.id, sizeof(ex), &ex[0]);
+    rtems_object_get_name(e->heir->Object.id, sizeof(hr), &hr[0]);
+    rtems_object_get_name(e->heir_node->Object.id, sizeof(hn), &hn[0]);
+    printf(
+      "[%" PRIu32 "] %4s -> %4s (prio %3" PRIu32 ", node %4s)\n",
+      e->cpu_index,
+      &ex[0],
+      &hr[0],
+      e->heir_priority,
+      &hn[0]
 static void obtain_and_release_worker(rtems_task_argument arg)
@@ -134,9 +237,8 @@ static void obtain_and_release_worker(rtems_task_argument arg)
   rtems_test_assert(0);
-static void test_mrsp_obtain_and_release(void)
+static void test_mrsp_obtain_and_release(test_context *ctx)
-  test_context *ctx = &test_instance;
   rtems_id scheduler_id;
@@ -144,6 +246,8 @@ static void test_mrsp_obtain_and_release(void)
   puts("test MrsP obtain and release");
+  change_prio(RTEMS_SELF, 2);
   /* Check executing task parameters */
   sc = rtems_task_get_scheduler(RTEMS_SELF, &scheduler_id);
@@ -151,8 +255,6 @@ static void test_mrsp_obtain_and_release(void)
   rtems_test_assert(ctx->scheduler_ids[0] == scheduler_id);
-  assert_prio(RTEMS_SELF, 2);
   /* Create a MrsP semaphore object and lock it */
   sc = rtems_semaphore_create(
@@ -408,15 +510,6 @@ static void test_mrsp_unlock_order_error(void)
-static void deadlock_timer(rtems_id id, void *arg)
-  rtems_status_code sc;
-  sc = rtems_task_suspend(ctx->worker_ids[0]);
-  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
 static void deadlock_worker(rtems_task_argument arg)
@@ -425,9 +518,6 @@ static void deadlock_worker(rtems_task_argument arg)
   sc = rtems_semaphore_obtain(ctx->mrsp_ids[1], RTEMS_WAIT, RTEMS_NO_TIMEOUT);
-  sc = rtems_timer_fire_after(ctx->timer_id, 2, deadlock_timer, NULL);
   sc = rtems_semaphore_obtain(ctx->mrsp_ids[0], RTEMS_WAIT, RTEMS_NO_TIMEOUT);
@@ -444,21 +534,14 @@ static void deadlock_worker(rtems_task_argument arg)
-static void test_mrsp_deadlock_error(void)
+static void test_mrsp_deadlock_error(test_context *ctx)
   rtems_task_priority prio = 2;
   puts("test MrsP deadlock error");
-  assert_prio(RTEMS_SELF, prio);
-  sc = rtems_timer_create(
-    rtems_build_name('M', 'R', 'S', 'P'),
-    &ctx->timer_id
+  change_prio(RTEMS_SELF, prio);
     rtems_build_name(' ', ' ', ' ', 'A'),
@@ -505,9 +588,6 @@ static void test_mrsp_deadlock_error(void)
   sc = rtems_semaphore_release(ctx->mrsp_ids[0]);
-  sc = rtems_task_resume(ctx->worker_ids[0]);
   sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
@@ -519,9 +599,6 @@ static void test_mrsp_deadlock_error(void)
   sc = rtems_semaphore_delete(ctx->mrsp_ids[1]);
-  sc = rtems_timer_delete(ctx->timer_id);
 static void test_mrsp_multiple_obtain(void)
@@ -642,6 +719,206 @@ static void test_mrsp_multiple_obtain(void)
+static void run_task(rtems_task_argument arg)
+  volatile bool *run = (volatile bool *) arg;
+  while (true) {
+    *run = true;
+static void test_mrsp_obtain_and_sleep_and_release(test_context *ctx)
+  rtems_status_code sc;
+  rtems_id sem_id;
+  rtems_id run_task_id;
+  volatile bool run = false;
+  puts("test MrsP obtain and sleep and release");
+  change_prio(RTEMS_SELF, 1);
+  reset_switch_events(ctx);
+  sc = rtems_task_create(
+    rtems_build_name(' ', 'R', 'U', 'N'),
+    2,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &run_task_id
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_task_start(run_task_id, run_task, (rtems_task_argument) &run);
+  sc = rtems_semaphore_create(
+    rtems_build_name('S', 'E', 'M', 'A'),
+    1,
+    RTEMS_MULTIPROCESSOR_RESOURCE_SHARING
+      | RTEMS_BINARY_SEMAPHORE,
+    1,
+    &sem_id
+  rtems_test_assert(!run);
+  sc = rtems_task_wake_after(2);
+  rtems_test_assert(run);
+  run = false;
+  sc = rtems_semaphore_obtain(sem_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  sc = rtems_semaphore_release(sem_id);
+  print_switch_events(ctx);
+  sc = rtems_semaphore_delete(sem_id);
+  sc = rtems_task_delete(run_task_id);
+static void help_task(rtems_task_argument arg)
+  sc = rtems_semaphore_obtain(ctx->mrsp_ids[0], RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  sc = rtems_semaphore_release(ctx->mrsp_ids[0]);
+  while (true) {
+    /* Do nothing */
+static void test_mrsp_obtain_and_release_with_help(test_context *ctx)
+  rtems_id help_task_id;
+  puts("test MrsP obtain and release with help");
+  change_prio(RTEMS_SELF, 3);
+    1,
+    2,
+    &ctx->mrsp_ids[0]
+  assert_prio(RTEMS_SELF, 2);
+    rtems_build_name('H', 'E', 'L', 'P'),
+    3,
+    &help_task_id
+  sc = rtems_task_set_scheduler(
+    help_task_id,
+    ctx->scheduler_ids[1]
+  sc = rtems_task_start(help_task_id, help_task, 0);
+    4,
+    &run_task_id
+  wait_for_prio(help_task_id, 2);
+  rtems_test_assert(rtems_get_current_processor() == 0);
+  change_prio(run_task_id, 1);
+  rtems_test_assert(rtems_get_current_processor() == 1);
+  while (!run) {
+    /* Wait */
+  change_prio(run_task_id, 4);
+  assert_prio(RTEMS_SELF, 3);
+  wait_for_prio(help_task_id, 3);
+  sc = rtems_semaphore_delete(ctx->mrsp_ids[0]);
+  sc = rtems_task_delete(help_task_id);
 static uint32_t simple_random(uint32_t v)
   v *= 1664525;
@@ -673,6 +950,8 @@ static void load_worker(rtems_task_argument index)
       sc = rtems_task_wake_after(1);
+      ++ctx->counters[index].cpu[rtems_get_current_processor()];
     } else {
       uint32_t n = (v >> 17) % (i + 1);
       uint32_t s;
@@ -695,6 +974,8 @@ static void load_worker(rtems_task_argument index)
           break;
         v = simple_random(v);
@@ -704,6 +985,8 @@ static void load_worker(rtems_task_argument index)
         sc = rtems_semaphore_release(ctx->mrsp_ids[k]);
@@ -717,16 +1000,47 @@ static void load_worker(rtems_task_argument index)
-static void test_mrsp_load(void)
+static void migration_task(rtems_task_argument arg)
   uint32_t cpu_count = rtems_get_processor_count();
+  uint32_t v = 0xdeadbeef;
+  while (true) {
+    uint32_t cpu_index = (v >> 5) % cpu_count;
+    sc = rtems_task_set_scheduler(RTEMS_SELF, ctx->scheduler_ids[cpu_index]);
+    ++ctx->migration_counters[rtems_get_current_processor()];
+    v = simple_random(v);
+static void test_mrsp_load(test_context *ctx)
+  uint32_t cpu_count = rtems_get_processor_count();
   uint32_t index;
   puts("test MrsP load");
+    rtems_build_name('M', 'I', 'G', 'R'),
+    2,
+    &ctx->migration_task_id
+  sc = rtems_task_start(ctx->migration_task_id, migration_task, 0);
     rtems_build_name('S', 'Y', 'N', 'C'),
@@ -829,15 +1143,18 @@ static void test_mrsp_load(void)
   sc = rtems_semaphore_delete(ctx->counting_sem_id);
+  sc = rtems_task_delete(ctx->migration_task_id);
   for (index = 0; index < 2 * cpu_count; ++index) {
     uint32_t nest_level;
     printf(
-      "worker[%" PRIu32 "][%" PRIu32 "]\n"
+      "worker[%" PRIu32 "]\n"
         "  sleep = %" PRIu32 "\n"
         "  timeout = %" PRIu32 "\n",
-      index / 2,
-      index % 2,
+      index,
       ctx->counters[index].sleep,
       ctx->counters[index].timeout
@@ -849,6 +1166,22 @@ static void test_mrsp_load(void)
         ctx->counters[index].obtain[nest_level]
+    for (cpu_index = 0; cpu_index < cpu_count; ++cpu_index) {
+      printf(
+        "  cpu[%" PRIu32 "] = %" PRIu32 "\n",
+        cpu_index,
+        ctx->counters[index].cpu[cpu_index]
+  for (index = 0; index < cpu_count; ++index) {
+    printf(
+      "migrations[%" PRIu32 "] = %" PRIu32 "\n",
+      index,
+      ctx->migration_counters[index]
@@ -883,10 +1216,12 @@ static void Init(rtems_task_argument arg)
   test_mrsp_initially_locked_error();
   test_mrsp_nested_obtain_error();
   test_mrsp_unlock_order_error();
-  test_mrsp_deadlock_error();
+  test_mrsp_deadlock_error(ctx);
   test_mrsp_multiple_obtain();
-  test_mrsp_obtain_and_release();
-  test_mrsp_load();
+  test_mrsp_obtain_and_sleep_and_release(ctx);
+  test_mrsp_obtain_and_release_with_help(ctx);
+  test_mrsp_obtain_and_release(ctx);
+  test_mrsp_load(ctx);
   rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
@@ -901,7 +1236,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS (2 * CPU_COUNT + 1)
+#define CONFIGURE_MAXIMUM_TASKS (2 * CPU_COUNT + 2)
 #define CONFIGURE_MAXIMUM_SEMAPHORES (MRSP_COUNT + 1)
 #define CONFIGURE_MAXIMUM_MRSP_SEMAPHORES MRSP_COUNT
 #define CONFIGURE_MAXIMUM_TIMERS 1
@@ -983,8 +1318,11 @@ RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(16);
   RTEMS_SCHEDULER_ASSIGN(16, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INITIAL_EXTENSIONS \
+  { .thread_switch = switch_extension }, \
+  RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INIT_TASK_NAME rtems_build_name('M', 'A', 'I', 'N')
 #define CONFIGURE_INIT_TASK_PRIORITY 2
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/smptests/smpmrsp01/smpmrsp01.scn b/testsuites/smptests/smpmrsp01/smpmrsp01.scn
index 5762a02..bbae93a 100644
--- a/testsuites/smptests/smpmrsp01/smpmrsp01.scn
+++ b/testsuites/smptests/smpmrsp01/smpmrsp01.scn
@@ -2,146 +2,343 @@
 test MrsP flush error
 test MrsP initially locked error
 test MrsP nested obtain error
+test MrsP unlock order error
+test MrsP deadlock error
+test MrsP multiple obtain
+test MrsP obtain and sleep and release
+[0] MAIN ->  RUN (prio   2, node  RUN)
+[0]  RUN -> MAIN (prio   1, node MAIN)
+[0] MAIN -> IDLE (prio   1, node MAIN)
+[0] IDLE -> MAIN (prio   1, node MAIN)
+test MrsP obtain and release with help
+[1] IDLE -> HELP (prio   3, node HELP)
+[0] MAIN -> IDLE (prio   2, node MAIN)
+[0] IDLE -> MAIN (prio   2, node MAIN)
+[1] HELP -> MAIN (prio   2, node HELP)
+[0] MAIN ->  RUN (prio   1, node  RUN)
+[1] MAIN -> HELP (prio   2, node HELP)
+[0]  RUN -> IDLE (prio   2, node MAIN)
+[0] IDLE -> MAIN (prio   3, node MAIN)
 test MrsP load
-worker[0][0]
-  sleep = 890
-  timeout = 1455
-  obtain[0] = 141069
-  obtain[1] = 111062
-  obtain[2] = 255631
-  obtain[3] = 186559
-  obtain[4] = 310707
-  obtain[5] = 246838
-  obtain[6] = 331853
-  obtain[7] = 298938
-  obtain[8] = 331989
-  obtain[9] = 343041
-  obtain[10] = 310191
-  obtain[11] = 381001
-  obtain[12] = 269001
-  obtain[13] = 412849
-  obtain[14] = 217768
-  obtain[15] = 444036
-  obtain[16] = 160721
-  obtain[17] = 476211
-  obtain[18] = 151929
-  obtain[19] = 438664
-  obtain[20] = 132708
-  obtain[21] = 388090
-  obtain[22] = 118166
-  obtain[23] = 337468
-  obtain[24] = 96676
-  obtain[25] = 271392
-  obtain[26] = 75445
-  obtain[27] = 203259
-  obtain[28] = 52933
-  obtain[29] = 132769
-  obtain[30] = 27856
-  obtain[31] = 57014
-worker[0][1]
-  sleep = 15
-  timeout = 33
-  obtain[0] = 2241
-  obtain[1] = 1890
-  obtain[2] = 4128
-  obtain[3] = 3128
-  obtain[4] = 5110
-  obtain[5] = 3981
-  obtain[6] = 5348
-  obtain[7] = 4825
-  obtain[8] = 5184
-  obtain[9] = 5720
-  obtain[10] = 4488
-  obtain[11] = 6038
-  obtain[12] = 4095
-  obtain[13] = 6658
-  obtain[14] = 3754
-  obtain[15] = 6768
-  obtain[16] = 2654
-  obtain[17] = 7051
-  obtain[18] = 2679
-  obtain[19] = 6956
-  obtain[20] = 2498
-  obtain[21] = 6173
-  obtain[22] = 2024
-  obtain[23] = 5514
-  obtain[24] = 1650
-  obtain[25] = 4141
-  obtain[26] = 1568
-  obtain[27] = 3285
-  obtain[28] = 812
-  obtain[29] = 2317
-  obtain[30] = 527
-  obtain[31] = 996
-worker[1][0]
-  sleep = 890
-  timeout = 1581
-  obtain[0] = 140732
-  obtain[1] = 111655
-  obtain[2] = 256936
-  obtain[3] = 186534
-  obtain[4] = 311714
-  obtain[5] = 248065
-  obtain[6] = 333155
-  obtain[7] = 300734
-  obtain[8] = 329675
-  obtain[9] = 343832
-  obtain[10] = 309112
-  obtain[11] = 380452
-  obtain[12] = 270156
-  obtain[13] = 416600
-  obtain[14] = 223484
-  obtain[15] = 444991
-  obtain[16] = 163750
-  obtain[17] = 476096
-  obtain[18] = 150317
-  obtain[19] = 432827
-  obtain[20] = 133946
-  obtain[21] = 388441
-  obtain[22] = 119760
-  obtain[23] = 337033
-  obtain[24] = 99153
-  obtain[25] = 271558
-  obtain[26] = 77535
-  obtain[27] = 202607
-  obtain[28] = 53225
-  obtain[29] = 130801
-  obtain[30] = 27321
-  obtain[31] = 56239
-worker[1][1]
-  sleep = 25
-  timeout = 48
-  obtain[0] = 2164
-  obtain[1] = 1722
-  obtain[2] = 4095
-  obtain[3] = 3002
-  obtain[4] = 4950
-  obtain[5] = 4020
-  obtain[6] = 5235
-  obtain[7] = 4716
-  obtain[8] = 5407
-  obtain[9] = 5070
-  obtain[10] = 5082
-  obtain[11] = 6130
-  obtain[12] = 4368
-  obtain[13] = 6108
-  obtain[14] = 3270
-  obtain[15] = 6800
-  obtain[16] = 2652
-  obtain[17] = 7633
-  obtain[18] = 2451
-  obtain[19] = 7480
-  obtain[20] = 2079
-  obtain[21] = 6232
-  obtain[22] = 1590
-  obtain[23] = 5739
-  obtain[24] = 1627
-  obtain[25] = 4030
-  obtain[26] = 1296
-  obtain[27] = 2803
-  obtain[28] = 969
-  obtain[29] = 2253
-  obtain[30] = 217
-  obtain[31] = 930
+worker[0]
+  sleep = 16
+  timeout = 3420
+  obtain[0] = 2503
+  obtain[1] = 1671
+  obtain[2] = 4446
+  obtain[3] = 2850
+  obtain[4] = 5003
+  obtain[5] = 3793
+  obtain[6] = 5575
+  obtain[7] = 4468
+  obtain[8] = 5326
+  obtain[9] = 4645
+  obtain[10] = 4565
+  obtain[11] = 5082
+  obtain[12] = 4050
+  obtain[13] = 5203
+  obtain[14] = 2945
+  obtain[15] = 5704
+  obtain[16] = 1652
+  obtain[17] = 5870
+  obtain[18] = 1472
+  obtain[19] = 4933
+  obtain[20] = 1136
+  obtain[21] = 3463
+  obtain[22] = 1257
+  obtain[23] = 3230
+  obtain[24] = 823
+  obtain[25] = 2860
+  obtain[26] = 736
+  obtain[27] = 1270
+  obtain[28] = 438
+  obtain[29] = 1273
+  obtain[30] = 378
+  obtain[31] = 422
+  cpu[0] = 116428
+  cpu[1] = 16133
+  cpu[2] = 32982
+  cpu[3] = 32557
+worker[1]
+  sleep = 1
+  timeout = 4
+  obtain[0] = 2
+  obtain[1] = 0
+  obtain[2] = 3
+  obtain[3] = 8
+  obtain[4] = 10
+  obtain[5] = 0
+  obtain[6] = 7
+  obtain[7] = 0
+  obtain[8] = 0
+  obtain[9] = 0
+  obtain[10] = 11
+  obtain[11] = 0
+  obtain[12] = 26
+  obtain[13] = 14
+  obtain[14] = 5
+  obtain[15] = 0
+  obtain[16] = 0
+  obtain[17] = 18
+  obtain[18] = 12
+  obtain[19] = 0
+  obtain[20] = 0
+  obtain[21] = 0
+  obtain[22] = 0
+  obtain[23] = 0
+  obtain[24] = 0
+  obtain[25] = 0
+  obtain[26] = 0
+  obtain[27] = 0
+  obtain[28] = 0
+  obtain[29] = 0
+  obtain[30] = 0
+  obtain[31] = 0
+  cpu[0] = 140
+  cpu[1] = 24
+  cpu[2] = 33
+  cpu[3] = 36
+worker[2]
+  sleep = 14
+  timeout = 3513
+  obtain[0] = 2474
+  obtain[1] = 1793
+  obtain[2] = 4551
+  obtain[3] = 2833
+  obtain[4] = 5293
+  obtain[5] = 3681
+  obtain[6] = 5309
+  obtain[7] = 4565
+  obtain[8] = 5270
+  obtain[9] = 4610
+  obtain[10] = 4817
+  obtain[11] = 4760
+  obtain[12] = 3858
+  obtain[13] = 5919
+  obtain[14] = 3172
+  obtain[15] = 5286
+  obtain[16] = 1968
+  obtain[17] = 5800
+  obtain[18] = 1768
+  obtain[19] = 4629
+  obtain[20] = 1446
+  obtain[21] = 4109
+  obtain[22] = 1046
+  obtain[23] = 3119
+  obtain[24] = 1012
+  obtain[25] = 2338
+  obtain[26] = 790
+  obtain[27] = 1628
+  obtain[28] = 432
+  obtain[29] = 1281
+  obtain[30] = 270
+  obtain[31] = 418
+  cpu[0] = 15589
+  cpu[1] = 121473
+  cpu[2] = 31797
+  cpu[3] = 31645
+worker[3]
+  sleep = 1
+  timeout = 3
+  obtain[0] = 4
+  obtain[1] = 0
+  obtain[2] = 9
+  obtain[3] = 0
+  obtain[4] = 5
+  obtain[5] = 0
+  obtain[6] = 0
+  obtain[7] = 8
+  obtain[8] = 0
+  obtain[9] = 10
+  obtain[10] = 0
+  obtain[11] = 0
+  obtain[12] = 0
+  obtain[13] = 0
+  obtain[14] = 0
+  obtain[15] = 16
+  obtain[16] = 0
+  obtain[17] = 18
+  obtain[18] = 0
+  obtain[19] = 0
+  obtain[20] = 0
+  obtain[21] = 1
+  obtain[22] = 0
+  obtain[23] = 24
+  obtain[24] = 0
+  obtain[25] = 0
+  obtain[26] = 0
+  obtain[27] = 0
+  obtain[28] = 0
+  obtain[29] = 0
+  obtain[30] = 0
+  obtain[31] = 0
+  cpu[0] = 22
+  cpu[1] = 123
+  cpu[2] = 7
+  cpu[3] = 39
+worker[4]
+  sleep = 19
+  timeout = 3025
+  obtain[0] = 2574
+  obtain[1] = 1845
+  obtain[2] = 4423
+  obtain[3] = 2985
+  obtain[4] = 5086
+  obtain[5] = 3679
+  obtain[6] = 5286
+  obtain[7] = 4447
+  obtain[8] = 5885
+  obtain[9] = 4771
+  obtain[10] = 4857
+  obtain[11] = 5467
+  obtain[12] = 4554
+  obtain[13] = 5210
+  obtain[14] = 3547
+  obtain[15] = 6169
+  obtain[16] = 2337
+  obtain[17] = 6109
+  obtain[18] = 1797
+  obtain[19] = 5136
+  obtain[20] = 1646
+  obtain[21] = 4251
+  obtain[22] = 1041
+  obtain[23] = 3235
+  obtain[24] = 975
+  obtain[25] = 2961
+  obtain[26] = 739
+  obtain[27] = 1704
+  obtain[28] = 554
+  obtain[29] = 1344
+  obtain[30] = 182
+  obtain[31] = 559
+  cpu[0] = 5617
+  cpu[1] = 5834
+  cpu[2] = 100129
+  cpu[3] = 99149
+worker[5]
+  sleep = 18
+  timeout = 3123
+  obtain[0] = 2439
+  obtain[1] = 1878
+  obtain[2] = 4576
+  obtain[3] = 2938
+  obtain[4] = 5088
+  obtain[5] = 3723
+  obtain[6] = 5611
+  obtain[7] = 4411
+  obtain[8] = 5522
+  obtain[9] = 4893
+  obtain[10] = 4877
+  obtain[11] = 4932
+  obtain[12] = 4263
+  obtain[13] = 5608
+  obtain[14] = 2791
+  obtain[15] = 5905
+  obtain[16] = 1739
+  obtain[17] = 5322
+  obtain[18] = 1892
+  obtain[19] = 5118
+  obtain[20] = 1360
+  obtain[21] = 4764
+  obtain[22] = 1099
+  obtain[23] = 3180
+  obtain[24] = 913
+  obtain[25] = 2612
+  obtain[26] = 807
+  obtain[27] = 1588
+  obtain[28] = 493
+  obtain[29] = 1348
+  obtain[30] = 389
+  obtain[31] = 471
+  cpu[0] = 5554
+  cpu[1] = 6139
+  cpu[2] = 97852
+  cpu[3] = 95573
+worker[6]
+  sleep = 1
+  timeout = 11
+  obtain[0] = 2
+  obtain[1] = 2
+  obtain[2] = 9
+  obtain[3] = 4
+  obtain[4] = 15
+  obtain[5] = 12
+  obtain[6] = 7
+  obtain[7] = 16
+  obtain[8] = 10
+  obtain[9] = 20
+  obtain[10] = 11
+  obtain[11] = 5
+  obtain[12] = 0
+  obtain[13] = 0
+  obtain[14] = 0
+  obtain[15] = 16
+  obtain[16] = 0
+  obtain[17] = 0
+  obtain[18] = 0
+  obtain[19] = 20
+  obtain[20] = 0
+  obtain[21] = 44
+  obtain[22] = 0
+  obtain[23] = 0
+  obtain[24] = 0
+  obtain[25] = 7
+  obtain[26] = 0
+  obtain[27] = 0
+  obtain[28] = 0
+  obtain[29] = 0
+  obtain[30] = 0
+  obtain[31] = 0
+  cpu[0] = 10
+  cpu[1] = 6
+  cpu[2] = 168
+  cpu[3] = 217
+worker[7]
+  sleep = 1
+  timeout = 0
+  obtain[0] = 0
+  obtain[1] = 0
+  obtain[2] = 0
+  obtain[3] = 0
+  obtain[4] = 0
+  obtain[5] = 0
+  obtain[6] = 0
+  obtain[7] = 0
+  obtain[8] = 0
+  obtain[9] = 0
+  obtain[10] = 0
+  obtain[11] = 0
+  obtain[12] = 0
+  obtain[13] = 0
+  obtain[14] = 0
+  obtain[15] = 0
+  obtain[16] = 0
+  obtain[17] = 0
+  obtain[18] = 0
+  obtain[19] = 0
+  obtain[20] = 0
+  obtain[21] = 0
+  obtain[22] = 0
+  obtain[23] = 0
+  obtain[24] = 0
+  obtain[25] = 0
+  obtain[26] = 0
+  obtain[27] = 0
+  obtain[28] = 0
+  obtain[29] = 0
+  obtain[30] = 0
+  obtain[31] = 0
+  cpu[0] = 0
+  cpu[1] = 0
+  cpu[2] = 1
+  cpu[3] = 0
+migrations[0] = 110919
+migrations[1] = 110920
+migrations[2] = 109762
+migrations[3] = 112076
 *** END OF TEST SMPMRSP 1 ***
1.7.7
