[PATCH-V2 4/7] bsp/sparc: Flush icache before first time enabling interrupts
Daniel Cederman cederman at gaisler.com
Wed Jul 9 07:02:16 UTC 2014
A secondary processor might miss changes done to the trap table
if the instruction cache is not flushed. Once interrupts are enabled
any other required cache flushes can be ordered via the cache
manager.
 c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c |    9 +++++++++
 cpukit/score/cpu/sparc/rtems/score/cpu.h      |    4 ++++
 2 files changed, 13 insertions(+)
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c b/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c
index 567eecc..9166ad5 100644
--- a/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c
@@ -15,6 +15,7 @@
 #include <bsp.h>
 #include <bsp/bootcard.h>
+#include <cache_.h>
 #include <leon.h>
 #include <rtems/bspIo.h>
 #include <rtems/score/smpimpl.h>
@@ -80,3 +81,11 @@ void _CPU_SMP_Send_interrupt(uint32_t target_processor_index)
   /* send interrupt to destination CPU */
   LEON3_IrqCtrl_Regs->force[target_processor_index] = 1 << LEON3_MP_IRQ;
+void _BSP_Start_multitasking(
+  Context_Control *heir
+  _CPU_cache_invalidate_entire_instruction();
+  _CPU_Context_Restart_self( heir );
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index c010005..4a08441 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -1203,6 +1203,10 @@ register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
   void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
+  void _BSP_Start_multitasking( Context_Control *heir )
+    RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
+  #define _CPU_Start_multitasking _BSP_Start_multitasking
   static inline void _CPU_SMP_Processor_event_broadcast( void )
     __asm__ volatile ( "" : : : "memory" );
1.7.9.5
