[PATCH 4/6] spintrcritical20: Fix incorrect assumption
Thu Jul 10 07:18:50 UTC 2014
On 2014-07-09 16:37, Joel Sherrill wrote:
> I think this patch is wrong. Subsequent changes to the thread queue after I
> posted this resulted in the test breaking again.
> What is the test trying to do? I think sometimes through the loop, the
> condition the test expects is not occurring and it fails.
 From the doc file we have:
   - Ensure that _Thread_queue_Process_timeout() works in case it is
     interrupted and _Thread_queue_Dequeue() is called.
It simulates a nested interrupt case.  Since we can use only the clock tick to
work with interrupts I had to do the following:
1. Create a high priority task which creates the base state (semaphore locked).
2. Use a low priority task to simulate the timeout process.
3. Use a timer to simulate the high priority nested interrupt.
I think this is the only test which uses this approach so far.  This partly
explains why bugs like this prevailed for such a long time:
https://www.rtems.org/bugzilla/show_bug.cgi?id=2140
Do you not hit the test case or do you hit an assertion failure?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
