Misc on RBTree Thread Queue Priority Discipline Changes
Thu Jul 10 07:41:55 UTC 2014
Hello Joel,
I think it is good approach to use a RB tree for the priority queues.  Reducing
the size of non-thread objects is always beneficial, since you usually have a
lot of them.  The new network stack uses for example more than 2000 semaphores,
but only a hand full of tasks.
It might be interesting to compare the performance of the two priority queue
implementations (existing and RB tree based).
The RB tree implementation itself has room for improvement.  You can for
example store the color in the lower bits of one of the pointers.  This is how
other RB tree implementations do this (its a size reduction of 25%).  Also the
RB tree control is pretty huge.  The compare function and is unique indicator
can easily be converted to function parameters (its a size reduction of 33%).
The max pointer may be avoided also.  We can do something like this
struct RBTree_Control:
   RBTree_Root             Root
   RBTree_Compare_function compare_function
   bool                    is_unique
op(ctrl):
   base_op(ctrl.Root, ctrl.compare_function, ctrl.is_unique)
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
