[PATCH 4/4] capture01: New non-interactive test for capture engine.
Jennifer Averett jennifer.averett at oarcorp.com
Thu Jul 10 13:44:15 UTC 2014
 testsuites/libtests/Makefile.am             |   1 +
 testsuites/libtests/capture01/Makefile.am   |  20 +++
 testsuites/libtests/capture01/capture01.doc |  19 +++
 testsuites/libtests/capture01/capture01.scn |  35 ++++
 testsuites/libtests/capture01/init.c        | 253 ++++++++++++++++++++++++++++
 testsuites/libtests/capture01/system.h      |  42 +++++
 testsuites/libtests/capture01/test1.c       | 250 +++++++++++++++++++++++++++
 testsuites/libtests/configure.ac            |   1 +
 8 files changed, 621 insertions(+)
 create mode 100644 testsuites/libtests/capture01/Makefile.am
 create mode 100644 testsuites/libtests/capture01/capture01.doc
 create mode 100644 testsuites/libtests/capture01/capture01.scn
 create mode 100644 testsuites/libtests/capture01/init.c
 create mode 100644 testsuites/libtests/capture01/system.h
 create mode 100644 testsuites/libtests/capture01/test1.c
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index f3987b3..f6a2778 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -14,6 +14,7 @@ _SUBDIRS += block14
 _SUBDIRS += block13
 _SUBDIRS += rbheap01
 _SUBDIRS += flashdisk01
+_SUBDIRS += capture01
 _SUBDIRS += bspcmdline01 cpuuse devfs01 devfs02 devfs03 devfs04 \
     deviceio01 devnullfatal01 dumpbuf01 gxx01 \
diff --git a/testsuites/libtests/capture01/Makefile.am b/testsuites/libtests/capture01/Makefile.am
new file mode 100644
index 0000000..6c0d80a
--- /dev/null
+++ b/testsuites/libtests/capture01/Makefile.am
@@ -0,0 +1,20 @@
+rtems_tests_PROGRAMS = capture01
+capture01_SOURCES = init.c test1.c system.h
+dist_rtems_tests_DATA = capture01.scn
+dist_rtems_tests_DATA += capture01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+LINK_OBJS = $(capture01_OBJECTS)
+LINK_LIBS = $(capture01_LDLIBS)
+capture01$(EXEEXT): $(capture01_OBJECTS) $(capture01_DEPENDENCIES)
+	@rm -f capture01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/libtests/capture01/capture01.doc b/testsuites/libtests/capture01/capture01.doc
index 0000000..c3d2e56
--- /dev/null
+++ b/testsuites/libtests/capture01/capture01.doc
@@ -0,0 +1,19 @@
+#  COPYRIGHT (c) 1989-1999.
+#  On-Line Applications Research Corporation (OAR).
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.org/license/LICENSE.
+This is a non-ineractive test of the capture engine.  This test is based
+on the methods that would be called through the monitor capture commands:
+  copen 10000
+  cwceil 98
+  cwfloor 105
+  cwglob on
+  ctset RMON
+  cwlist
+  cenable
+  ctrace
diff --git a/testsuites/libtests/capture01/capture01.scn b/testsuites/libtests/capture01/capture01.scn
index 0000000..e6d9cb1
--- /dev/null
+++ b/testsuites/libtests/capture01/capture01.scn
@@ -0,0 +1,35 @@
+*** BEGIN OF TEST CAPTURE ENGINE ***
+watch priority ceiling is 100
+watch priority floor is 102
+global watch is enabled
+total 1
+ 00000000 ???? g-  T:S------ F:-----
+0a010002 CT1a 102 102 SWITCHED_OUT
+0a010003 CT1b 101 101 CREATED
+0a010003 CT1b 101 101 STARTED
+0a010003 CT1b 101 101 SWITCHED_IN
+0a010003 CT1b 101 101 BEGIN
+0a010003 CT1b 101 101 SWITCHED_OUT
+0a010004 CT1c 100 100 CREATED
+0a010004 CT1c 100 100 STARTED
+0a010004 CT1c 100 100 SWITCHED_IN
+0a010004 CT1c 100 100 BEGIN
+0a010004 CT1c 100 100 SWITCHED_OUT
+0a010002 CT1a 102 100 SWITCHED_IN
+0a010004 CT1c 100 100 TERMINATED
+0a010003 CT1b 101 101 TERMINATED
+0a010002 CT1a 102 102 SWITCHED_IN
+0a010002 CT1a 102 102 TERMINATED
+*** END OF TEST CAPTURE ENGINE ***
diff --git a/testsuites/libtests/capture01/init.c b/testsuites/libtests/capture01/init.c
index 0000000..dcffc4c
--- /dev/null
+++ b/testsuites/libtests/capture01/init.c
@@ -0,0 +1,253 @@
+ *  COPYRIGHT (c) 1989-2012.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may in
+ *  the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#define CONFIGURE_INIT
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "system.h"
+#include <ctype.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <inttypes.h>
+#include <rtems.h>
+#include <rtems/capture-cli.h>
+#include <rtems/monitor.h>
+#include <rtems/shell.h>
+#define ASSERT_SC(sc) assert((sc) == RTEMS_SUCCESSFUL)
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument argument);
+const char rtems_test_name[] = "CAPTURE ENGINE";
+static void cwlist(void);
+static void ctrace(void);
+static void cwlist ()
+  rtems_capture_control_t* control = rtems_capture_get_control_list ();
+  rtems_task_priority      ceiling = rtems_capture_watch_get_ceiling ();
+  rtems_task_priority      floor = rtems_capture_watch_get_floor ();
+  fprintf (stdout, "watch priority ceiling is %" PRId32 "\n", ceiling);
+  fprintf (stdout, "watch priority floor is %" PRId32 "\n", floor);
+  fprintf (stdout, "global watch is %s\n",
+          rtems_capture_watch_global_on () ? "enabled" : "disabled");
+  fprintf (stdout, "total %" PRId32 "\n", rtems_capture_control_count ());
+  while (control)
+    uint32_t flags;
+    int      f;
+    int      fshowed;
+    int      lf;
+    fprintf (stdout, " ");
+    rtems_monitor_dump_id (rtems_capture_control_id (control));
+    rtems_monitor_dump_name (rtems_capture_control_name (control));
+    flags = rtems_capture_control_flags (control);
+    fprintf (stdout, " %c%c ",
+             rtems_capture_watch_global_on () ? 'g' : '-',
+             flags & RTEMS_CAPTURE_WATCH ? 'w' : '-');
+    flags = rtems_capture_control_to_triggers (control);
+    fprintf (stdout, " T:%c%c%c%c%c%c%c",
+             flags & RTEMS_CAPTURE_SWITCH    ? 'S' : '-',
+             flags & RTEMS_CAPTURE_CREATE ? 'C' : '-',
+             flags & RTEMS_CAPTURE_START ? 'S' : '-',
+             flags & RTEMS_CAPTURE_RESTART ? 'R' : '-',
+             flags & RTEMS_CAPTURE_DELETE ? 'D' : '-',
+             flags & RTEMS_CAPTURE_BEGIN ? 'B' : '-',
+             flags & RTEMS_CAPTURE_EXITTED ? 'E' : '-');
+    flags = rtems_capture_control_from_triggers (control);
+    fprintf (stdout, " F:%c%c%c%c%c",
+             flags & RTEMS_CAPTURE_DELETE  ? 'D' : '-');
+    for (f = 0, fshowed = 0, lf = 1; f < RTEMS_CAPTURE_TRIGGER_TASKS; f++)
+      if (rtems_capture_control_by_valid (control, f))
+        if (lf && ((fshowed % 3) == 0))
+          fprintf (stdout, "\n");
+          lf = 0;
+        fprintf (stdout, "  %2i:", f);
+        rtems_monitor_dump_name (rtems_capture_control_by_name (control, f));
+        fprintf (stdout, "/");
+        rtems_monitor_dump_id (rtems_capture_control_by_id (control, f));
+        flags = rtems_capture_control_by_triggers (control, f);
+        fprintf (stdout, ":%c%c%c%c%c",
+        fshowed++;
+        lf = 1;
+    if (lf)
+    control = rtems_capture_next_control (control);
+static void ctrace()
+  rtems_status_code       sc;
+  bool                    csv = false;
+  static int              dump_total = 22;
+  int                     total;
+  int                     count;
+  uint32_t                read;
+  rtems_capture_record_t* rec;
+  total = dump_total;
+  while (total)
+    sc = rtems_capture_read (0, 0, &read, &rec);
+    if (sc != RTEMS_SUCCESSFUL)
+      fprintf (stdout, "error: trace read failed: %s\n", rtems_status_text (sc));
+      rtems_capture_flush (0);
+      return;
+     * If we have no records then just exist. We still need to release
+     * the reader lock.
+    if (read == 0)
+      rtems_capture_release (read);
+      break;
+    count = total < read ? total : read;
+    while (count--)
+      if (csv)
+        fprintf (stdout, "%08" PRIxPTR ",%03" PRIu32
+                   ",%03" PRIu32 ",%04" PRIx32 ",%" PRId64 "\n",
+                 (uintptr_t) rec->task,
+                 (rec->events >> RTEMS_CAPTURE_REAL_PRIORITY_EVENT) & 0xff,
+                 (rec->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT) & 0xff,
+                 (rec->events >> RTEMS_CAPTURE_EVENT_START),
+                 (uint64_t) rec->time);
+      else
+        uint32_t event;
+        int      e;
+        event = rec->events >> RTEMS_CAPTURE_EVENT_START;
+        for (e = RTEMS_CAPTURE_EVENT_START; e <= RTEMS_CAPTURE_EVENT_END; e++)
+          if (event & 1)
+            rtems_monitor_dump_id (rtems_capture_task_id (rec->task));
+            fprintf (stdout, " %c%c%c%c",
+                     (char) (rec->task->name >> 24) & 0xff,
+                     (char) (rec->task->name >> 16) & 0xff,
+                     (char) (rec->task->name >> 8) & 0xff,
+                     (char) (rec->task->name >> 0) & 0xff);
+            fprintf (stdout, " %3" PRId32 " %3" PRId32 " %s\n",
+                    rtems_capture_event_text (e));
+          event >>= 1;
+      rec++;
+    if (count < total)
+      total -= count;
+    else
+      total = 0;
+    rtems_capture_release (count);
+rtems_task Init(
+  rtems_task_argument ignored
+#if BSP_SMALL_MEMORY
+  printf("NO Capture Engine. MEMORY TOO SMALL");
+#else
+  rtems_task_priority old_priority;
+  rtems_mode          old_mode;
+  rtems_name          to_name = rtems_build_name('I', 'D', 'L', 'E');;
+  rtems_test_begin();
+  rtems_task_set_priority(RTEMS_SELF, 20, &old_priority);
+  rtems_task_mode(RTEMS_PREEMPT,  RTEMS_PREEMPT_MASK, &old_mode);
+  sc = rtems_capture_open (5000, NULL);
+  ASSERT_SC(sc);
+  sc = rtems_capture_watch_ceiling (100);
+  ASSERT_SC(sc);
+  sc = rtems_capture_watch_floor (102);
+  ASSERT_SC(sc);
+  sc = rtems_capture_watch_global (true);
+  ASSERT_SC(sc);
+  sc = rtems_capture_set_trigger (
+    0,
+    0,
+    to_name,
+    0,
+    rtems_capture_from_any,
+    rtems_capture_switch
+  ASSERT_SC(sc);
+  cwlist();
+  sc = rtems_capture_control (true);
+  ASSERT_SC(sc);
+  capture_test_1();
+  ctrace();
+  ctrace();
+  rtems_test_end();
+  exit( 0 );
+#endif
diff --git a/testsuites/libtests/capture01/system.h b/testsuites/libtests/capture01/system.h
index 0000000..62c221f
--- /dev/null
+++ b/testsuites/libtests/capture01/system.h
@@ -0,0 +1,42 @@
+/*  system.h
+ *  This include file contains information that is included in every
+ *  function in the test set.
+ *  COPYRIGHT (c) 1989-1997.
+#include <rtems.h>
+#include <rtems/test.h>
+/* functions */
+rtems_task Init(
+  rtems_task_argument argument
+void capture_test_1(void);
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define TASK_ALLOCATION_SIZE     (5)
+#define CONFIGURE_MAXIMUM_TASKS  rtems_resource_unlimited(TASK_ALLOCATION_SIZE)
+#define CONFIGURE_EXTRA_TASK_STACKS (75 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS (5)
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
+/* end of include file */
diff --git a/testsuites/libtests/capture01/test1.c b/testsuites/libtests/capture01/test1.c
index 0000000..5e334fc
--- /dev/null
+++ b/testsuites/libtests/capture01/test1.c
@@ -0,0 +1,250 @@
+/*  Test1
+ *  This test uses creates a number of tasks so the capture engine
+ *  can show a trace.
+ *  Input parameters:  NONE
+ *  Output parameters:  NONE
+#endif
+#include <stdio.h>
+#include <rtems.h>
+#if !BSP_SMALL_MEMORY
+static volatile int capture_CT1a_deleted;
+static volatile int capture_CT1b_deleted;
+static volatile int capture_CT1c_deleted;
+static void
+capture_wait (uint32_t period)
+  rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (period * 1000));
+ * CT1a: Claim the mutex and then wait a while then wake
+ *       up and release the mutex. While this task waits with
+ *       the mutex another higher priority task is started that
+ *       just loops using all the processing time. It is not until
+ *       another even higher priority thread blocks on the mutex
+ *       does this task get raised to that priority and so
+ *       releases the mutex. This will allow us to capture the
+ *       action of priority inversion.
+static void
+capture_CT1a (rtems_task_argument arg)
+  rtems_id mutex = (rtems_id) arg;
+  sc = rtems_semaphore_obtain (mutex, RTEMS_WAIT, 0);
+    fprintf (stdout, "error: CT1a: mutex obtain: %s\n",
+             rtems_status_text (sc));
+  capture_wait (2500);
+  sc = rtems_semaphore_release (mutex);
+    fprintf (stdout, "error: CT1a: mutex release: %s\n",
+  capture_CT1a_deleted = 1;
+  rtems_task_delete (RTEMS_SELF);
+static void
+capture_CT1b (rtems_task_argument arg)
+  volatile int i;
+  while (!capture_CT1c_deleted)
+    i++;
+  capture_CT1b_deleted = 1;
+static void
+capture_CT1c (rtems_task_argument arg)
+    fprintf (stdout, "error: CT1c: mutex obtain: %s\n",
+  capture_wait (500);
+    fprintf (stdout, "error: CT1c: mutex release: %s\n",
+  capture_CT1c_deleted = 1;
+void capture_test_1 ()
+  rtems_name        name;
+  rtems_id          id[3];
+  rtems_id          mutex;
+  int               loops;
+  capture_CT1a_deleted = 0;
+  capture_CT1b_deleted = 0;
+  capture_CT1c_deleted = 0;
+  name = rtems_build_name('C', 'T', 'm', '1');
+  sc = rtems_semaphore_create (name, 1,
+                               RTEMS_PRIORITY | RTEMS_BINARY_SEMAPHORE |
+                               RTEMS_INHERIT_PRIORITY,
+                               0, &mutex);
+    fprintf (stdout, "error: Test 1: cannot mutex: %s\n",
+    return;
+  name = rtems_build_name('C', 'T', '1', 'a');
+  sc = rtems_task_create (name, 102, 2 * 1024,
+                          RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,
+                          RTEMS_PREEMPT | RTEMS_TIMESLICE | RTEMS_NO_ASR,
+                          &id[0]);
+    fprintf (stdout, "error: Test 1: cannot create CT1a: %s\n",
+    rtems_semaphore_delete (mutex);
+    return;
+  sc = rtems_task_start (id[0], capture_CT1a, (rtems_task_argument) mutex);
+    fprintf (stdout, "error: Test 1: cannot start CT1a: %s\n",
+    rtems_task_delete (id[0]);
+    return;
+  capture_wait (1000);
+  name = rtems_build_name('C', 'T', '1', 'b');
+  sc = rtems_task_create (name, 101, 2 * 1024,
+                          &id[1]);
+    fprintf (stdout, "error: Test 1: cannot create CT1b: %s\n",
+    return;
+  sc = rtems_task_start (id[1], capture_CT1b, 0);
+    fprintf (stdout, "error: Test 1: cannot start CT1b: %s\n",
+    rtems_task_delete (id[1]);
+    return;
+  name = rtems_build_name('C', 'T', '1', 'c');
+  sc = rtems_task_create (name, 100, 2 * 1024,
+                          &id[2]);
+    fprintf (stdout, "error: Test 1: cannot create CT1c: %s\n",
+    return;
+  sc = rtems_task_start (id[2], capture_CT1c, (rtems_task_argument) mutex);
+    fprintf (stdout, "error: Test 1: cannot start CT1c: %s\n",
+    rtems_task_delete (id[2]);
+    return;
+  loops = 15;
+  while (!(capture_CT1a_deleted || capture_CT1b_deleted ||
+           capture_CT1c_deleted) && loops)
+    loops--;
+  if (!loops)
+    fprintf (stdout, "error: Test 1: test tasks did not delete\n");
+  sc = rtems_semaphore_delete (mutex);
+    fprintf (stdout, "error: Test 1: deleting the mutex: %s\n",
+#endif /* BSP_SMALL_MEMORY */
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 81dd1fd..e246680 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -110,6 +110,7 @@ termios06/Makefile
 termios07/Makefile
 termios08/Makefile
 tztest/Makefile
+capture01/Makefile
 POSIX/Makefile
 math/Makefile
 mathf/Makefile
1.8.1.4
