Performance Impact of Thread Queue Priority Change
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Jul 11 00:15:54 UTC 2014
I added variants of tm02 and tm03 for counting/priority,
binary/FIFO, and binary/priority. These tests are for an
operation count of 100 on sis. I have attached the patch
and the files.
The "0" times are because I just repurposed an existing
test and when it blocks the middle tasks in FIFO order,
each requires a context switch through it. When in
priority order, it restores the highest priority and there
isn't enough code executed to be reliably measured.
For the test cases we have, everything looks the same
or better but not remarkably so.
If someone can suggest some test cases which push
priority blocking, I am happy to try them.
I am not seeing a downside to committing this code.
If someone doesn't say something, then I plan to
commit it soon. Soon being after this weekend since
it is my wedding anniversary and we are taking a
long weekend.
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140710/b4aeea26/attachment-0001.bin>
rtems_semaphore_create: only case - 48
rtems_semaphore_delete: only case - 60
rtems_semaphore_ident: only case - 62
rtems_semaphore_obtain: available - 8
rtems_semaphore_obtain: binary/FIFO not available caller blocks - 87
rtems_semaphore_obtain: binary/priority not available caller blocks - 113
rtems_semaphore_obtain: counting/FIFO not available caller blocks - 86
rtems_semaphore_obtain: counting/priority not available caller blocks - 112
rtems_semaphore_obtain: not available NO_WAIT - 8
rtems_semaphore_release: binary/FIFO task readied preempts caller - 76
rtems_semaphore_release: binary/priority task readied preempts caller - 0
rtems_semaphore_release: counting/FIFO task readied preempts caller - 74
rtems_semaphore_release: counting/priority task readied preempts caller - 0
rtems_semaphore_release: no waiting tasks - 24
rtems_semaphore_release: task readied -- returns to caller - 31
rtems_semaphore_create: only case - 59
rtems_semaphore_delete: only case - 71
rtems_semaphore_obtain: binary/FIFO not available caller blocks - 88
rtems_semaphore_obtain: binary/priority not available caller blocks - 116
rtems_semaphore_obtain: counting/FIFO not available caller blocks - 87
rtems_semaphore_obtain: counting/priority not available caller blocks - 115
rtems_semaphore_release: binary/FIFO task readied preempts caller - 80
rtems_semaphore_release: counting/FIFO task readied preempts caller - 78
rtems_semaphore_release: no waiting tasks - 28
rtems_semaphore_release: task readied -- returns to caller - 34
