[PATCH-V2 5/7] score/sparc: Add comment on icache flush after trap table update
Daniel Cederman cederman at gaisler.com
Fri Jul 11 07:12:46 UTC 2014
On 2014-07-09 16:38, Gedare Bloom wrote:
> On Wed, Jul 9, 2014 at 3:02 AM, Daniel Cederman <cederman at gaisler.com> wrote:
>> Changes to the trap table might be missed by other cores.
>> If the system state is up, the other cores can be notified
>> using SMP messages that they need to flush their icache.
>> If the up state has not been reached there is no need to
>> notify other cores. They will do an automatic flush of the
>> icache just after entering the up state, but before enabling
>> interrupts.
>>   cpukit/score/cpu/sparc/cpu.c |   12 +++++++++---
>>   1 file changed, 9 insertions(+), 3 deletions(-)
>> diff --git a/cpukit/score/cpu/sparc/cpu.c b/cpukit/score/cpu/sparc/cpu.c
>> index c616de4..88228b7 100644
>> --- a/cpukit/score/cpu/sparc/cpu.c
>> +++ b/cpukit/score/cpu/sparc/cpu.c
>> @@ -210,10 +210,16 @@ void _CPU_ISR_install_raw_handler(
>>       (u32_handler & HIGH_BITS_MASK) >> HIGH_BITS_SHIFT;
>>     slot->jmp_to_low_of_handler_plus_l4 |= (u32_handler & LOW_BITS_MASK);
>> -  /* need to flush icache after this !!! */
>> +   * Changes to the trap table might be missed by other cores.
>> +   * If the system state is up, the other cores can be notified
>> +   * using SMP messages that they need to flush their icache.
>> +   * If the up state has not been reached there is no need to
>> +   * notify other cores. They will do an automatic flush of the
>> +   * icache just after entering the up state, but before enabling
>> +   * interrupts.
> This was needed for UP mode also, since stores to the trap table are
> cached in d-cache instead of i-cache, you need to flush/invalidate
> i-cache so the updated trap table entry will be loaded from memory. It
> should be made clear that this is the situation, else someone might
> think to make this invalidate conditional on SMP mode...
> -Gedare
I will add that to the comment. Thanks!
>>     rtems_cache_invalidate_entire_instruction();
>>   void _CPU_ISR_install_vector(
>> 1.7.9.5
>> devel mailing list
>> devel at rtems.org
Daniel Cederman
Software Engineer
Aeroflex Gaisler AB
Aeroflex Microelectronic Solutions – HiRel
Kungsgatan 12
SE-411 19 Gothenburg, Sweden
Phone: +46 31 7758665
www.Aeroflex.com/Gaisler
