>> + BSP_fatal_exit(
>> LEON3_FATAL_INVALID_CACHE_CONFIG_SECONDARY_PROCESSOR );
> bsp_fatal()?
I wanted to use bsp_fatal, but it tries to acquire a ticket lock which
does not work when data cache snooping is disabled.
On 2014-07-09 09:28, Sebastian Huber wrote:
> On 2014-07-09 09:02, Daniel Cederman wrote:
>> Check that data cache snooping exists and is enabled on all cores.
>> c/src/lib/libbsp/shared/include/fatal.h | 2 ++
>> c/src/lib/libbsp/sparc/leon3/include/leon.h | 10 ++++++++++
>> c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c | 8 ++++++--
>> 3 files changed, 18 insertions(+), 2 deletions(-)
>> diff --git a/c/src/lib/libbsp/shared/include/fatal.h
>> b/c/src/lib/libbsp/shared/include/fatal.h
>> index e928bba..99da207 100644
>> --- a/c/src/lib/libbsp/shared/include/fatal.h
>> +++ b/c/src/lib/libbsp/shared/include/fatal.h
>> @@ -49,6 +49,8 @@ typedef enum {
>> /* LEON3 fatal codes */
>> LEON3_FATAL_NO_IRQMP_CONTROLLER = BSP_FATAL_CODE_BLOCK(2),
>> LEON3_FATAL_CONSOLE_REGISTER_DEV,
>> + LEON3_FATAL_INVALID_CACHE_CONFIG_MAIN_PROCESSOR,
>> + LEON3_FATAL_INVALID_CACHE_CONFIG_SECONDARY_PROCESSOR,
>> /* LPC24XX fatal codes */
>> LPC24XX_FATAL_PL111_SET_UP = BSP_FATAL_CODE_BLOCK(3),
>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h
>> b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>> index d7048f3..a62ad29 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
>> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>> @@ -86,6 +86,11 @@ extern "C" {
>> #define LEON_REG_TIMER_CONTROL_LD 0x00000004 /* 1 = load counter */
>> /* 0 = no function */
>> + * The following defines the bits in the LEON Cache Control Register.
>> +#define LEON3_REG_CACHE_CTRL_DS 0x00800000 /* Data cache
>> snooping */
>> /* LEON3 Interrupt Controller */
>> extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
>> /* LEON3 GP Timer */
>> @@ -347,6 +352,11 @@ static inline uint32_t
>> leon3_get_cache_control_register(void)
>> return leon3_get_system_register(0x0);
>> +static inline bool leon3_data_cache_snooping_enabled(void)
>> + return leon3_get_cache_control_register() & LEON3_REG_CACHE_CTRL_DS;
>> static inline uint32_t leon3_get_inst_cache_config_register(void)
>> return leon3_get_system_register(0x8);
>> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c
>> b/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c
>> index 9166ad5..312488d 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c
>> @@ -15,6 +15,7 @@
>> #include <bsp.h>
>> #include <bsp/bootcard.h>
>> +#include <bsp/fatal.h>
>> #include <cache_.h>
>> #include <leon.h>
>> #include <rtems/bspIo.h>
>> @@ -39,7 +40,9 @@ void bsp_start_on_secondary_processor()
>> uint32_t cpu_index_self = _CPU_SMP_Get_current_processor();
>> - leon3_set_cache_control_register(0x80000F);
>> + if ( ! leon3_data_cache_snooping_enabled() )
>> + BSP_fatal_exit(
> bsp_fatal()?
>> /* Unmask IPI interrupts at Interrupt controller for this CPU */
>> LEON3_IrqCtrl_Regs->mask[cpu_index_self] |= 1U << LEON3_MP_IRQ;
>> @@ -48,7 +51,8 @@ void bsp_start_on_secondary_processor()
>> uint32_t _CPU_SMP_Initialize( void )
>> + bsp_fatal( LEON3_FATAL_INVALID_CACHE_CONFIG_MAIN_PROCESSOR );
>> if ( rtems_configuration_get_maximum_processors() > 1 ) {
>> LEON_Unmask_interrupt(LEON3_MP_IRQ);
