[PATCH 1/6] smpschedaffinity01: New test.
Jennifer Averett jennifer.averett at oarcorp.com
Fri Jul 11 14:44:42 UTC 2014
This test verifies that affinity is honored when set prior to task start.
 testsuites/smptests/Makefile.am                    |   1 +
 testsuites/smptests/configure.ac                   |   1 +
 testsuites/smptests/smpschedaffinity01/Makefile.am |  19 +++
 testsuites/smptests/smpschedaffinity01/init.c      | 173 +++++++++++++++++++++
 .../smpschedaffinity01/smpschedaffinity01.doc      |  11 ++
 .../smpschedaffinity01/smpschedaffinity01.scn      |  15 ++
 6 files changed, 220 insertions(+)
 create mode 100644 testsuites/smptests/smpschedaffinity01/Makefile.am
 create mode 100644 testsuites/smptests/smpschedaffinity01/init.c
 create mode 100644 testsuites/smptests/smpschedaffinity01/smpschedaffinity01.doc
 create mode 100644 testsuites/smptests/smpschedaffinity01/smpschedaffinity01.scn
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 1edfbde..227c036 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -23,6 +23,7 @@ SUBDIRS += smplock01
 SUBDIRS += smpmigration01
 SUBDIRS += smpmigration02
 SUBDIRS += smpmrsp01
+SUBDIRS += smpschedaffinity01
 SUBDIRS += smpscheduler01
 SUBDIRS += smpscheduler02
 SUBDIRS += smpscheduler03
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 79b3bf8..88b43cd 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -81,6 +81,7 @@ smpmrsp01/Makefile
 smppsxaffinity01/Makefile
 smppsxaffinity02/Makefile
 smppsxsignal01/Makefile
+smpschedaffinity01/Makefile
 smpscheduler01/Makefile
 smpscheduler02/Makefile
 smpscheduler03/Makefile
diff --git a/testsuites/smptests/smpschedaffinity01/Makefile.am b/testsuites/smptests/smpschedaffinity01/Makefile.am
new file mode 100644
index 0000000..353abe1
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpschedaffinity01
+smpschedaffinity01_SOURCES = init.c
+dist_rtems_tests_DATA = smpschedaffinity01.scn smpschedaffinity01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpschedaffinity01_OBJECTS)
+LINK_LIBS = $(smpschedaffinity01_LDLIBS)
+smpschedaffinity01$(EXEEXT): $(smpschedaffinity01_OBJECTS) $(smpschedaffinity01_DEPENDENCIES)
+	@rm -f smpschedaffinity01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpschedaffinity01/init.c b/testsuites/smptests/smpschedaffinity01/init.c
index 0000000..1f1e32a
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity01/init.c
@@ -0,0 +1,173 @@
+ *  COPYRIGHT (c) 2014.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+ * Start 4 tasks with affinity for each of the 4 cpus.
+ * Allow tasks to set their actual cpu value and delete themselves.
+ * Verify the actual cpu values match the expected cpu values.
+ * Init task is at a lower priority 8 and the threads
+ * with affinity are at priority 4, so the affinity task
+ * on the core init is running on will preempt it.
+ * Test tasks run and delete themselves.
+ * Init task never blocks.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SMPSCHEDAFFINITY 1";
+#define NUM_CPUS   4
+#define TASK_COUNT 5
+struct task_data_t {
+  rtems_id   id;
+  int        expected_cpu;
+  cpu_set_t  cpuset;
+  bool       ran;
+  int        actual_cpu;
+static struct task_data_t task_data[NUM_CPUS] = {
+  {0x0, 2, {{0x4}}, false, -1},
+  {0x0, 0, {{0x1}}, false, -1},
+  {0x0, 3, {{0x8}}, false, -1},
+  {0x0, 1, {{0x2}}, false, -1}
+ * Spin loop to allow tasks to delay without yeilding the
+ * processor.
+static void test_delay(int ticks)
+  rtems_interval start, stop;
+  start = rtems_clock_get_ticks_since_boot();
+  do {
+    stop = rtems_clock_get_ticks_since_boot();
+  } while ( (stop - start) < ticks );
+static void task(rtems_task_argument arg)
+  uint32_t cpu;
+  cpu_set_t cpuset;
+  cpu = rtems_get_current_processor();
+  rtems_task_get_affinity( rtems_task_self(), sizeof(cpuset), &cpuset );
+  task_data[arg].ran = true;
+  task_data[arg].actual_cpu = cpu;
+  rtems_task_delete( RTEMS_SELF );
+static void test(void)
+  rtems_status_code   sc;
+  rtems_task_argument i;
+  size_t              size;
+  uint32_t            cpu_count;
+  /* Get the number of processors that we are using. */
+  cpu_count = rtems_get_processor_count();
+  size = sizeof(cpu_set_t);
+  /* Create and start tasks on each cpu with the appropriate affinity. */
+  for (i = 0; i < NUM_CPUS; i++) {
+      /* Skip if this cpu doesn't exist, don't create task */
+      if ( task_data[i].expected_cpu >= cpu_count ) {
+        printf( "Skipping TA0%d because on a core we do not have\n", i );
+        continue;
+      sc = rtems_task_create(
+        rtems_build_name('T', 'A', '0', '0'+i),
+        4,
+        RTEMS_MINIMUM_STACK_SIZE,
+        RTEMS_DEFAULT_MODES,
+        RTEMS_DEFAULT_ATTRIBUTES,
+        &task_data[ i ].id
+      rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+      printf("Set TA%d affinity to cpu %d\n", i, task_data[i].expected_cpu );
+      sc = rtems_task_set_affinity( task_data[ i ].id, size, &task_data[i].cpuset );
+      printf("Start TA%d on cpu %d\n", i, task_data[i].expected_cpu);
+      sc = rtems_task_start( task_data[ i ].id, task, i );
+  /* spin for 100 ticks */
+  test_delay(100);
+  printf("Verify Tasks Ran\n");
+    /* Skip if this cpu doesn't exist, task doesn't exist */
+      continue;
+    /* print the expected and actual values */
+    printf( "TA0%d: ran=%d expected=%d actual=%d\n",
+     i,
+     task_data[i].ran,
+     task_data[i].expected_cpu,
+     task_data[i].actual_cpu
+    /*  Abort test if values are not as expected */
+    rtems_test_assert( task_data[i].ran == true );
+    rtems_test_assert( task_data[i].expected_cpu == task_data[i].actual_cpu );
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS NUM_CPUS
+#define CONFIGURE_MAXIMUM_TASKS          TASK_COUNT
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+  #define CONFIGURE_INIT_TASK_PRIORITY      8
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpschedaffinity01/smpschedaffinity01.doc b/testsuites/smptests/smpschedaffinity01/smpschedaffinity01.doc
index 0000000..124b5ed
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity01/smpschedaffinity01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpschedaffinity01
+directives:
+  - _Scheduler_priority_affinity_xxx
+concepts:
+  - Ensure that affinity is honored when set prior to task start.
diff --git a/testsuites/smptests/smpschedaffinity01/smpschedaffinity01.scn b/testsuites/smptests/smpschedaffinity01/smpschedaffinity01.scn
index 0000000..caefb22
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity01/smpschedaffinity01.scn
@@ -0,0 +1,15 @@
+*** BEGIN OF TEST SMPSCHEDAFFINITY 1 ***
+Set TA0 affinity to cpu 2
+Start TA0 on cpu 2
+Set TA1 affinity to cpu 0
+Start TA1 on cpu 0
+Set TA2 affinity to cpu 3
+Start TA2 on cpu 3
+Set TA3 affinity to cpu 1
+Start TA3 on cpu 1
+Verify Tasks Ran
+TA00: ran=1 expected=2 actual=2
+TA01: ran=1 expected=0 actual=0
+TA02: ran=1 expected=3 actual=3
+TA03: ran=1 expected=1 actual=1
+*** END OF TEST SMPSCHEDAFFINITY 1 ***
1.8.1.4
