[PATCH] Fix RTL archive file load
Peng Fan
van.freenix at gmail.com
Mon Jul 14 13:23:22 UTC 2014
Hi,
When the first time executing such a command "dlo libxx.ra:yy.rap" or "dlo
libxx.a:yy.o", RTL complains "no format loader found". when executing the
command the second time, the archive files can be loaded correctly. It is
because cache flush uses `file_size = -1` while file_size is unsigned type
, and `rtems_rtl_obj_cache_read` should include a if condition because A
cache obj can cache different files but it can only cache one file once.
Hope this explaination is clear:) Details is in the patch.
Regards,
Peng.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140714/655e2697/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140714/655e2697/attachment.obj>
