[PATCH] Common ARM A8 code.
Ben Gras
beng at shrike-systems.com
Wed Jul 16 00:45:32 UTC 2014
.../libbsp/arm/shared/include/arm-a8core-start.h | 55 ++++++++++++++++++++++
1 file changed, 55 insertions(+)
create mode 100644 c/src/lib/libbsp/arm/shared/include/arm-a8core-start.h
diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a8core-start.h b/c/src/lib/libbsp/arm/shared/include/arm-a8core-start.h
new file mode 100644
index 0000000..416f282
--- /dev/null
+++ b/c/src/lib/libbsp/arm/shared/include/arm-a8core-start.h
@@ -0,0 +1,55 @@
+ * @file
+ * @ingroup arm_shared
+ * @brief A8CORE_START Support
+ * Copyright (c) 2014 Chris Johns <chrisj at rtems.org>. All rights reserved.
+#ifndef LIBBSP_ARM_SHARED_ARM_A8CORE_START_H
+#define LIBBSP_ARM_SHARED_ARM_A8CORE_START_H
+#include <libcpu/arm-cp15.h>
+#include <bsp.h>
+#include <bsp/start.h>
+#include <bsp/arm-errata.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+BSP_START_TEXT_SECTION static inline arm_a8core_start_set_vector_base(void)
+ * Do not use bsp_vector_table_begin == 0, since this will get optimized away.
+ if (bsp_vector_table_end != bsp_vector_table_size) {
+ uint32_t ctrl;
+ arm_cp15_set_vector_base_address(bsp_vector_table_begin);
+ ctrl = arm_cp15_get_control();
+ ctrl &= ~ARM_CP15_CTRL_V;
+ arm_cp15_set_control(ctrl);
+BSP_START_TEXT_SECTION static inline arm_a8core_start_hook_1(void)
+ arm_a8core_start_set_vector_base();
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_SHARED_ARM_A8CORE_START_H */
1.8.3.4
