Problem with ticker.exe for or1ksim/OpenRISC BSP
    Hesham Moustafa
    heshamelmatary at gmail.com
    Fri Jul 18 20:16:49 UTC 2014
On Fri, Jul 18, 2014 at 4:19 PM, Gedare Bloom <gedare at rtems.org> wrote:
> I see you are kind of copying the file structure of ARM. I'm not sure
> this is a good example for a simple port. m68k is more
> straightforward.
Which file?
> -Gedare
> On Fri, Jul 18, 2014 at 10:17 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Fri, Jul 18, 2014 at 1:35 AM, Hesham Moustafa
>> <heshamelmatary at gmail.com> wrote:
>>> On Thu, Jul 17, 2014 at 3:10 PM, Joel Sherrill
>>> <joel.sherrill at oarcorp.com> wrote:
>>> > This definitely sounds like not handling the context switch necessary
>>> > part of the
>>> > IRQ processing properly so always returning to IDLE. I call this a
>>> > simple return.
>>> > All ports have a version of this code. no_cpu should have reasonable
>>> > pseudo-code.
>>> > m68k is likely the easiest to read as real code.
>>> > You need to do a simple return if:
>>> > (a) IRQ is nested, or
>>> > (b) DISPATCH_NEEDED is false
>>> This is a macro that defines the address of the corresponding variable
>>> within the per cpu config table right? Please correct the following if
>>> I it's wrong. From assembly (when doing restore after C ISR handler is
>>> executed), I have to load this variable value, check if it's true
>>> (greater than zero), and if yes, jump to _ISR_Dispatch. I am a little
>>> confused what context should be loaded in both cases of: simple
>>> return, and _ISR_Dispatch; In case of _ISR_Dispatch, should I save
>>> stack pointer and return address and other context like normal context
>>> switch (function call)? While in interrupt context (simple return), I
>>> am saving almost all registers with some other necessary registers
>>> related to exceptions.
>> Please see http://rtems.org/onlinedocs/doc-current/share/rtems/html/porting/Interrupts-Interrupt-Dispatching.html#Interrupts-Interrupt-Dispatching
>> Summarizing:
>> You need to update a few variables before calling the user ISR:
>> _Thread_Dispatch_disable_level += 1
>> _ISR_Nest_level += 1
>> And decrement them after returning.
>> If ISRs are nested you do a simple return.
>> Then you need to check if _CPU_ISR_Dispatch_disable is set, if so do a
>> simple return.
>> Then you need to check if DISPATCH_NEEDED, if so you need to do the
>> ISR_Dispatch.
>>> One thing I have a problem with, is when using some macros like
>>> DISPATCH_NEEDED (it's a variable address right?) I am normally
>>> including rtems/score/percpu.h from the assembly file (which does the
>>> magic) to get these definitions but the compiler suffers. I think I
>>> have to provide compiler option or something to just include #define
>>> macros? If yes, where to add it?
>> Make sure to include rtems/asm.h before including percpu.h so you get
>> the ASM defines instead of C defines, since you are (presumably)
>> writing this in assembly. You could also use inline assembly, but then
>> you need to use expression operands [1] to provide access to these
>> variables instead.
>> [1]  https://gcc.gnu.org/onlinedocs/gcc/Extended-Asm.html
>> -Gedare
>>> > Otherwise, you need to some CPU specific magic to get our of the IRQ and
>>> > back to the thread. Make it look like it called _Thread_Dispatch with
>>> > sufficient saved registers (e.g. callee destroyed). This is usually called
>>> > _ISR_Dispatch.  When the call from _ISR_Dispatch to _Thread_Dispatch
>>> > returns, you do the magic needed to return tot he interrupted thread
>>> > (IDLE in this case) as if nothing happened.
