[PATCH 2/3] rbtree: Remove superfluous NULL pointer checks
Mon Jul 21 16:59:41 UTC 2014
One comment inline.
On 7/21/2014 11:31 AM, Sebastian Huber wrote:
>  cpukit/score/include/rtems/score/rbtree.h |  7 +++----
>  cpukit/score/src/rbtree.c                 |  3 ---
>  cpukit/score/src/rbtreeextract.c          | 10 ----------
>  cpukit/score/src/rbtreeinsert.c           |  3 ---
>  testsuites/sptests/sprbtree01/init.c      |  3 ---
>  5 files changed, 3 insertions(+), 23 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/rbtree.h b/cpukit/score/include/rtems/score/rbtree.h
> index a219a6e..aa7b86e 100644
> --- a/cpukit/score/include/rtems/score/rbtree.h
> +++ b/cpukit/score/include/rtems/score/rbtree.h
> @@ -229,10 +229,9 @@ RBTree_Node *_RBTree_Find(
>   * @param[in] is_unique If true, then reject nodes with a duplicate key, else
>   *   otherwise.
> - *  @retval 0 Successfully inserted.
> - *  @retval -1 NULL @a the_node.
> - *  @retval RBTree_Node* if one with equal value to @a the_node 's key exists
> - *          in an unique @a the_rbtree.
> + * @retval NULL Successfully inserted.
> + * @retval existing_node This is a unique insert and there exists a node with
> + *   an equal key in the tree already.
>  RBTree_Node *_RBTree_Insert(
>    RBTree_Control *the_rbtree,
> diff --git a/cpukit/score/src/rbtree.c b/cpukit/score/src/rbtree.c
> index 2138a81..064cc0c 100644
> --- a/cpukit/score/src/rbtree.c
> +++ b/cpukit/score/src/rbtree.c
> @@ -34,9 +34,6 @@ void _RBTree_Initialize(
>    size_t       count;
>    RBTree_Node *next;
> -  /* TODO: Error message? */
> -  if ( !the_rbtree ) return;
>    /* could do sanity checks here */
>    _RBTree_Initialize_empty( the_rbtree );
> diff --git a/cpukit/score/src/rbtreeextract.c b/cpukit/score/src/rbtreeextract.c
> index 2638f63..7775b2f 100644
> --- a/cpukit/score/src/rbtreeextract.c
> +++ b/cpukit/score/src/rbtreeextract.c
> @@ -11,7 +11,6 @@
>  #endif
>  #include <rtems/score/rbtreeimpl.h>
> -#include <rtems/score/isr.h>
>  /** @brief  Validate and fix-up tree properties after deleting a node
> @@ -90,13 +89,6 @@ static void _RBTree_Extract_validate( RBTree_Node *the_node )
>      the_node->color = RBT_BLACK;
> -/** @brief Extract a Node (unprotected)
> - *  This routine extracts (removes) @a the_node from @a the_rbtree.
> - *  @note It does NOT disable interrupts to ensure the atomicity
> - *        of the extract operation.
Is it assumed that all RBTree  operations are unprotected?
If so, should this be in the Doxygen group description. If not, then this
comment is meaningful and should be in the .h.
>  void _RBTree_Extract(
> @@ -106,8 +98,6 @@ void _RBTree_Extract(
>    RBTree_Color     victim_color;
>    RBTree_Direction dir;
> -  if ( !the_node ) return;
>    /* check if min needs to be updated */
>    if ( the_node == the_rbtree->first[ RBT_LEFT ] ) {
>      RBTree_Node *next;
> diff --git a/cpukit/score/src/rbtreeinsert.c b/cpukit/score/src/rbtreeinsert.c
> index 369ef26..b31c8e7 100644
> --- a/cpukit/score/src/rbtreeinsert.c
> +++ b/cpukit/score/src/rbtreeinsert.c
> @@ -11,7 +11,6 @@
>  #endif
>  /** @brief Validate and fix-up tree properties for a new insert/colored node
> @@ -67,8 +66,6 @@ RBTree_Node *_RBTree_Insert(
>    bool            is_unique
> -  if ( !the_node ) return (RBTree_Node *) -1;
>    RBTree_Node *iter_node = the_rbtree->root;
>    if ( !iter_node ) { /* special case: first node inserted */
> diff --git a/testsuites/sptests/sprbtree01/init.c b/testsuites/sptests/sprbtree01/init.c
> index acf7f68..ca79095 100644
> --- a/testsuites/sptests/sprbtree01/init.c
> +++ b/testsuites/sptests/sprbtree01/init.c
> @@ -149,9 +149,6 @@ rtems_task Init(
>    rb_insert_unique( &rbtree1, &node1.Node );
>    rb_insert_unique( &rbtree1, &node2.Node );
> -  p = rb_insert_unique( &rbtree1, NULL );
> -  if (p != (void *)(-1))
> -    puts( "INIT - FAILED NULL NODE INSERT" );
>    _RBTree_Rotate(NULL, RBT_LEFT);
>    i = (node1.Node.parent == &node2.Node);
