[PATCH 1/3] rbtree: Format
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Jul 21 20:40:53 UTC 2014
On 7/21/2014 3:23 PM, Gedare Bloom wrote:
> One issue with rbtree formatting is in some places if/while
> conditional expressions are put on the same line as the conditional
> statement. We should prefer to put them explicitly on separate lines,
> since that is the prevailing style of score and I have added such a
> convention to our style wiki page.
You are right. That also helps statement coverage imply decision coverage.
if ( X ) return -1
is counted as executing for true and false.
if ( X )
return -1
must execute true and false to get statement coverage.
Good catch. This style has a reason. :)
> On Mon, Jul 21, 2014 at 12:57 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
> There could be something wrong here but I don't see it on a quick
> review.
> On 7/21/2014 11:31 AM, Sebastian Huber wrote:
> > cpukit/score/src/rbtree.c | 7 +-
> > cpukit/score/src/rbtreeextract.c | 152
> > cpukit/score/src/rbtreefind.c | 7 +-
> > cpukit/score/src/rbtreeinsert.c | 69 ++++++++++--------
> > cpukit/score/src/rbtreeiterate.c | 12 ++--
> > cpukit/score/src/rbtreenext.c | 13 ++--
> > 6 files changed, 143 insertions(+), 117 deletions(-)
> > diff --git a/cpukit/score/src/rbtree.c b/cpukit/score/src/rbtree.c
> > index 5e8520d..2138a81 100644
> > --- a/cpukit/score/src/rbtree.c
> > +++ b/cpukit/score/src/rbtree.c
> > @@ -31,17 +31,18 @@ void _RBTree_Initialize(
> > bool is_unique
> > - size_t count;
> > + size_t count;
> > RBTree_Node *next;
> > /* TODO: Error message? */
> > - if (!the_rbtree) return;
> > + if ( !the_rbtree ) return;
> Like here.
> > /* could do sanity checks here */
> > _RBTree_Initialize_empty( the_rbtree );
> > count = number_nodes;
> > - next = starting_address;
> > + next = starting_address;
> > while ( count-- ) {
> > _RBTree_Insert( the_rbtree, next, compare, is_unique );
> > next = (RBTree_Node *) _Addresses_Add_offset( next,
> node_size );
> > diff --git a/cpukit/score/src/rbtreeextract.c
> b/cpukit/score/src/rbtreeextract.c
> > index 9e87868..2638f63 100644
> > --- a/cpukit/score/src/rbtreeextract.c
> > +++ b/cpukit/score/src/rbtreeextract.c
> > @@ -21,45 +21,45 @@
> > * @note It does NOT disable interrupts to ensure the atomicity
> > * of the extract operation.
> > -static void _RBTree_Extract_validate(
> > - RBTree_Node *the_node
> > +static void _RBTree_Extract_validate( RBTree_Node *the_node )
> > - RBTree_Node *parent, *sibling;
> > + RBTree_Node *parent, *sibling;
> > RBTree_Direction dir;
> > parent = the_node->parent;
> > - if(!parent->parent) return;
> > - sibling = _RBTree_Sibling(the_node);
> > + if ( !parent->parent ) return;
> > - /* continue to correct tree as long as the_node is black and
> not the root */
> > - while (!_RBTree_Is_red(the_node) && parent->parent) {
> > + sibling = _RBTree_Sibling( the_node );
> > + /* continue to correct tree as long as the_node is black and
> not the root */
> > + while ( !_RBTree_Is_red( the_node ) && parent->parent ) {
> > /* if sibling is red, switch parent (black) and sibling colors,
> > * then rotate parent left, making the sibling be
> the_node's grandparent.
> > * Now the_node has a black sibling and red parent. After
> rotation,
> > * update sibling pointer.
> > - if (_RBTree_Is_red(sibling)) {
> > + if ( _RBTree_Is_red( sibling ) ) {
> > parent->color = RBT_RED;
> > sibling->color = RBT_BLACK;
> > - dir = the_node != parent->child[0];
> > - _RBTree_Rotate(parent, dir);
> > - sibling = parent->child[_RBTree_Opposite_direction(dir)];
> > + dir = the_node != parent->child[ 0 ];
> > + _RBTree_Rotate( parent, dir );
> > + sibling = parent->child[ _RBTree_Opposite_direction( dir ) ];
> > /* sibling is black, see if both of its children are also
> black. */
> > - if (!_RBTree_Is_red(sibling->child[RBT_RIGHT]) &&
> > - !_RBTree_Is_red(sibling->child[RBT_LEFT])) {
> > - sibling->color = RBT_RED;
> > - if (_RBTree_Is_red(parent)) {
> > - parent->color = RBT_BLACK;
> > - break;
> > - the_node = parent; /* done if parent is red */
> > - parent = the_node->parent;
> > + if ( !_RBTree_Is_red( sibling->child[ RBT_RIGHT ] ) &&
> > + !_RBTree_Is_red( sibling->child[ RBT_LEFT ] ) ) {
> > + sibling->color = RBT_RED;
> > + if ( _RBTree_Is_red( parent ) ) {
> > + parent->color = RBT_BLACK;
> > + break;
> > + the_node = parent; /* done if parent is red */
> > + parent = the_node->parent;
> > } else {
> > /* at least one of sibling's children is red. we now
> proceed in two
> > * cases, either the_node is to the left or the right of
> the parent.
> > @@ -67,21 +67,27 @@ static void _RBTree_Extract_validate(
> > * and if so rotate in the proper direction and update
> sibling pointer.
> > * Then switch the sibling and parent colors, and rotate
> through parent.
> > - if
> (!_RBTree_Is_red(sibling->child[_RBTree_Opposite_direction(dir)])) {
> > + if (
> _RBTree_Opposite_direction( dir ) ] )
> > - sibling->child[dir]->color = RBT_BLACK;
> > - _RBTree_Rotate(sibling, _RBTree_Opposite_direction(dir));
> > + sibling->child[ dir ]->color = RBT_BLACK;
> > + _RBTree_Rotate( sibling, _RBTree_Opposite_direction(
> dir ) );
> dir ) ];
> > sibling->color = parent->color;
> > - sibling->child[_RBTree_Opposite_direction(dir)]->color =
> RBT_BLACK;
> > + sibling->child[ _RBTree_Opposite_direction( dir )
> > break; /* done */
> > } /* while */
> > - if(!the_node->parent->parent) the_node->color = RBT_BLACK;
> > + if ( !the_node->parent->parent )
> > + the_node->color = RBT_BLACK;
> > /** @brief Extract a Node (unprotected)
> > @@ -92,29 +98,29 @@ static void _RBTree_Extract_validate(
> > void _RBTree_Extract(
> > - RBTree_Control *the_rbtree,
> > + RBTree_Control *the_rbtree,
> > + RBTree_Node *the_node
> > - RBTree_Node *leaf, *target;
> > - RBTree_Color victim_color;
> > + RBTree_Node *leaf, *target;
> > + RBTree_Color victim_color;
> > - if (!the_node) return;
> > + if ( !the_node ) return;
> > /* check if min needs to be updated */
> > - if (the_node == the_rbtree->first[RBT_LEFT]) {
> > + if ( the_node == the_rbtree->first[ RBT_LEFT ] ) {
> > RBTree_Node *next;
> > - next = _RBTree_Successor(the_node);
> > - the_rbtree->first[RBT_LEFT] = next;
> > + next = _RBTree_Successor( the_node );
> > + the_rbtree->first[ RBT_LEFT ] = next;
> > /* Check if max needs to be updated. min=max for 1 element
> trees so
> > * do not use else if here. */
> > - if (the_node == the_rbtree->first[RBT_RIGHT]) {
> > + if ( the_node == the_rbtree->first[ RBT_RIGHT ] ) {
> > RBTree_Node *previous;
> > - previous = _RBTree_Predecessor(the_node);
> > - the_rbtree->first[RBT_RIGHT] = previous;
> > + previous = _RBTree_Predecessor( the_node );
> > + the_rbtree->first[ RBT_RIGHT ] = previous;
> > /* if the_node has at most one non-null child then it is safe
> to proceed
> > @@ -124,9 +130,11 @@ void _RBTree_Extract(
> > * search tree property, but may violate the red-black
> properties.
> > - if (the_node->child[RBT_LEFT] && the_node->child[RBT_RIGHT]) {
> > - target = the_node->child[RBT_LEFT]; /* find max in
> node->child[RBT_LEFT] */
> > - while (target->child[RBT_RIGHT]) target =
> target->child[RBT_RIGHT];
> > + if ( the_node->child[ RBT_LEFT ] && the_node->child[
> RBT_RIGHT ] ) {
> > + target = the_node->child[ RBT_LEFT ]; /* find max in
> > + while ( target->child[ RBT_RIGHT ] )
> > + target = target->child[ RBT_RIGHT ];
> > /* if the target node has a child, need to move it up the
> tree into
> > * target's position (target is the right child of
> target->parent)
> > @@ -134,28 +142,33 @@ void _RBTree_Extract(
> > * should become NULL. This may cause the coloring to be
> violated.
> > * For now we store the color of the node being deleted in
> victim_color.
> > - leaf = target->child[RBT_LEFT];
> > - if(leaf) {
> > + leaf = target->child[ RBT_LEFT ];
> > + if ( leaf ) {
> > leaf->parent = target->parent;
> > } else {
> > /* fix the tree here if the child is a null leaf. */
> > - _RBTree_Extract_validate(target);
> > + _RBTree_Extract_validate( target );
> > victim_color = target->color;
> > - dir = target != target->parent->child[0];
> > - target->parent->child[dir] = leaf;
> > + dir = target != target->parent->child[ 0 ];
> > + target->parent->child[ dir ] = leaf;
> > /* now replace the_node with target */
> > - dir = the_node != the_node->parent->child[0];
> > - the_node->parent->child[dir] = target;
> > + dir = the_node != the_node->parent->child[ 0 ];
> > + the_node->parent->child[ dir ] = target;
> > /* set target's new children to the original node's children */
> > - target->child[RBT_RIGHT] = the_node->child[RBT_RIGHT];
> > - if (the_node->child[RBT_RIGHT])
> > - the_node->child[RBT_RIGHT]->parent = target;
> > - target->child[RBT_LEFT] = the_node->child[RBT_LEFT];
> > - if (the_node->child[RBT_LEFT])
> > - the_node->child[RBT_LEFT]->parent = target;
> > + target->child[ RBT_RIGHT ] = the_node->child[ RBT_RIGHT ];
> > + if ( the_node->child[ RBT_RIGHT ] )
> > + the_node->child[ RBT_RIGHT ]->parent = target;
> > + target->child[ RBT_LEFT ] = the_node->child[ RBT_LEFT ];
> > + if ( the_node->child[ RBT_LEFT ] )
> > + the_node->child[ RBT_LEFT ]->parent = target;
> > /* finally, update the parent node and recolor. target has
> completely
> > * replaced the_node, and target's child has moved up the
> tree if needed.
> > @@ -170,19 +183,21 @@ void _RBTree_Extract(
> > * violated. We will fix it later.
> victim_color.
> > - leaf = the_node->child[RBT_LEFT] ?
> > - the_node->child[RBT_LEFT] :
> > - if( leaf ) {
> > + leaf = the_node->child[ RBT_LEFT ] ?
> > + the_node->child[ RBT_LEFT ] : the_node->child[
> RBT_RIGHT ];
> > + if ( leaf ) {
> > leaf->parent = the_node->parent;
> > } else {
> > - _RBTree_Extract_validate(the_node);
> > + _RBTree_Extract_validate( the_node );
> > victim_color = the_node->color;
> > /* remove the_node from the tree */
> > - the_node->parent->child[dir] = leaf;
> > + the_node->parent->child[ dir ] = leaf;
> > /* fix coloring. leaf has moved up the tree. The color of the
> deleted
> > @@ -190,15 +205,16 @@ void _RBTree_Extract(
> > * 1. Deleted a red node, its child must be black. Nothing
> must be done.
> > * 2. Deleted a black node, its child must be red. Paint
> child black.
> > - if (victim_color == RBT_BLACK) { /* eliminate case 1 */
> > - if (leaf) {
> > + if ( victim_color == RBT_BLACK ) { /* eliminate case 1 */
> > + if ( leaf ) {
> > leaf->color = RBT_BLACK; /* case 2 */
> > /* Wipe the_node */
> > - _RBTree_Set_off_rbtree(the_node);
> > + _RBTree_Set_off_rbtree( the_node );
> > /* set root to black, if it exists */
> > - if (the_rbtree->root) the_rbtree->root->color = RBT_BLACK;
> > + if ( the_rbtree->root )
> > + the_rbtree->root->color = RBT_BLACK;
> > diff --git a/cpukit/score/src/rbtreefind.c
> b/cpukit/score/src/rbtreefind.c
> > index ad0c9fd..f767626 100644
> > --- a/cpukit/score/src/rbtreefind.c
> > +++ b/cpukit/score/src/rbtreefind.c
> > @@ -26,15 +26,16 @@ RBTree_Node *_RBTree_Find(
> > bool is_unique
> > - RBTree_Node* iter_node = the_rbtree->root;
> > - RBTree_Node* found = NULL;
> > + RBTree_Node *iter_node = the_rbtree->root;
> > + RBTree_Node *found = NULL;
> > while ( iter_node != NULL ) {
> > - int compare_result = ( *compare )( the_node, iter_node );
> > + int compare_result = ( *compare )( the_node,
> iter_node );
> > if ( _RBTree_Is_equal( compare_result ) ) {
> > found = iter_node;
> > if ( is_unique )
> > break;
> > diff --git a/cpukit/score/src/rbtreeinsert.c
> b/cpukit/score/src/rbtreeinsert.c
> > index 7174529..369ef26 100644
> > --- a/cpukit/score/src/rbtreeinsert.c
> > +++ b/cpukit/score/src/rbtreeinsert.c
> > @@ -21,42 +21,43 @@
> atomicity of the
> > * append operation.
> > -static void _RBTree_Validate_insert(
> > +static void _RBTree_Validate_insert( RBTree_Node *the_node )
> > - RBTree_Node *u,*g;
> > + RBTree_Node *u, *g;
> > /* note: the insert root case is handled already */
> > /* if the parent is black, nothing needs to be done
> > * otherwise may need to loop a few times */
> > - while (_RBTree_Is_red(_RBTree_Parent(the_node))) {
> > - u = _RBTree_Parent_sibling(the_node);
> > + while ( _RBTree_Is_red( _RBTree_Parent( the_node ) ) ) {
> > + u = _RBTree_Parent_sibling( the_node );
> > g = the_node->parent->parent;
> > /* if uncle is red, repaint uncle/parent black and
> grandparent red */
> > - if(_RBTree_Is_red(u)) {
> > + if ( _RBTree_Is_red( u ) ) {
> > the_node->parent->color = RBT_BLACK;
> > u->color = RBT_BLACK;
> > g->color = RBT_RED;
> > the_node = g;
> > } else { /* if uncle is black */
> > - RBTree_Direction dir = the_node !=
> > - RBTree_Direction pdir = the_node->parent != g->child[0];
> > + RBTree_Direction dir = the_node !=
> > + RBTree_Direction pdir = the_node->parent != g->child[ 0 ];
> > /* ensure node is on the same branch direction as parent */
> > - if (dir != pdir) {
> > - _RBTree_Rotate(the_node->parent, pdir);
> > - the_node = the_node->child[pdir];
> > + if ( dir != pdir ) {
> > + _RBTree_Rotate( the_node->parent, pdir );
> > + the_node = the_node->child[ pdir ];
> > g->color = RBT_RED;
> > /* now rotate grandparent in the other branch direction
> (toward uncle) */
> > - _RBTree_Rotate(g, (1-pdir));
> > + _RBTree_Rotate( g, ( 1 - pdir ) );
> > RBTree_Node *_RBTree_Insert(
> > @@ -66,47 +67,53 @@ RBTree_Node *_RBTree_Insert(
> > bool is_unique
> > - if(!the_node) return (RBTree_Node*)-1;
> > + if ( !the_node ) return (RBTree_Node *) -1;
> > - int compare_result;
> > - if (!iter_node) { /* special case: first node inserted */
> > + if ( !iter_node ) { /* special case: first node inserted */
> > the_rbtree->root = the_node;
> > - the_rbtree->first[0] = the_rbtree->first[1] = the_node;
> > + the_rbtree->first[ 0 ] = the_rbtree->first[ 1 ] = the_node;
> > the_node->parent = (RBTree_Node *) the_rbtree;
> > - the_node->child[RBT_LEFT] = the_node->child[RBT_RIGHT] = NULL;
> > + the_node->child[ RBT_LEFT ] = the_node->child[ RBT_RIGHT ]
> = NULL;
> > } else {
> > /* typical binary search tree insert, descend tree to leaf
> and insert */
> > - while (iter_node) {
> > - compare_result = ( *compare )( the_node, iter_node );
> > + while ( iter_node ) {
> > + int compare_result = ( *compare )( the_node, iter_node );
> > if ( is_unique && _RBTree_Is_equal( compare_result ) )
> > return iter_node;
> > RBTree_Direction dir = !_RBTree_Is_lesser( compare_result );
> > - if (!iter_node->child[dir]) {
> = NULL;
> > + if ( !iter_node->child[ dir ] ) {
> RBT_RIGHT ] = NULL;
> > the_node->color = RBT_RED;
> > - iter_node->child[dir] = the_node;
> > + iter_node->child[ dir ] = the_node;
> > the_node->parent = iter_node;
> > /* update min/max */
> > the_node,
> > _RBTree_First( the_rbtree, dir )
> > - if ( (!dir && _RBTree_Is_lesser(compare_result)) ||
> > - (dir && _RBTree_Is_greater(compare_result)) ) {
> > - the_rbtree->first[dir] = the_node;
> > + if (
> > + ( !dir && _RBTree_Is_lesser( compare_result ) )
> > + || ( dir && _RBTree_Is_greater( compare_result ) )
> > + the_rbtree->first[ dir ] = the_node;
> > break;
> > } else {
> > - iter_node = iter_node->child[dir];
> > + iter_node = iter_node->child[ dir ];
> > } /* while(iter_node) */
> > /* verify red-black properties */
> > - _RBTree_Validate_insert(the_node);
> > + _RBTree_Validate_insert( the_node );
> > - return (RBTree_Node*)0;
> > + return (RBTree_Node *) 0;
> > diff --git a/cpukit/score/src/rbtreeiterate.c
> b/cpukit/score/src/rbtreeiterate.c
> > index f325567..8b5da1e 100644
> > --- a/cpukit/score/src/rbtreeiterate.c
> > +++ b/cpukit/score/src/rbtreeiterate.c
> > @@ -28,17 +28,17 @@
> > void _RBTree_Iterate(
> > const RBTree_Control *rbtree,
> > - RBTree_Direction dir,
> > - RBTree_Visitor visitor,
> > - void *visitor_arg
> > + RBTree_Direction dir,
> > + RBTree_Visitor visitor,
> > + void *visitor_arg
> > - RBTree_Direction opp_dir = _RBTree_Opposite_direction( dir );
> > + RBTree_Direction opp_dir = _RBTree_Opposite_direction( dir );
> > const RBTree_Node *current = _RBTree_First( rbtree, opp_dir );
> > - bool stop = false;
> > + bool stop = false;
> > while ( !stop && current != NULL ) {
> > - stop = (*visitor)( current, dir, visitor_arg );
> > + stop = ( *visitor )( current, dir, visitor_arg );
> > current = _RBTree_Next( current, dir );
> > diff --git a/cpukit/score/src/rbtreenext.c
> b/cpukit/score/src/rbtreenext.c
> > index fde0bc6..2128ae5 100644
> > --- a/cpukit/score/src/rbtreenext.c
> > +++ b/cpukit/score/src/rbtreenext.c
> > @@ -29,25 +29,26 @@
> > RBTree_Node *_RBTree_Next(
> > const RBTree_Node *node,
> > - RBTree_Node *current = node->child [dir];
> > - RBTree_Node *next = NULL;
> > + RBTree_Node *current = node->child[ dir ];
> > + RBTree_Node *next = NULL;
> > if ( current != NULL ) {
> > next = current;
> > - while ( (current = current->child [opp_dir]) != NULL ) {
> > + while ( ( current = current->child[ opp_dir ] ) != NULL ) {
> > next = current;
> > } else {
> > RBTree_Node *parent = node->parent;
> > - if ( parent->parent && node == parent->child [opp_dir] ) {
> > + if ( parent->parent && node == parent->child[ opp_dir ] ) {
> > next = parent;
> > } else {
> > - while ( parent->parent && node == parent->child [dir] ) {
> > + while ( parent->parent && node == parent->child[ dir ] ) {
> > node = parent;
> > parent = parent->parent;
> > 1.8.1.4
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> <tel:%28256%29%20722-9985>
> devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140721/4fd4ecbd/attachment-0001.html>
