[PATCH] rbtree: Update maximum node in LIFO order
Sebastian Huber
Tue Jul 22 13:15:37 UTC 2014
The test sptests/sp35 showed a NULL pointer access due to an invalid
maximum node field (e.g. a tree with one element and NULL as the maximum
node).
cpukit/score/include/rtems/score/rbtree.h | 16 ++--
cpukit/score/src/rbtreeinsert.c | 4 +-
testsuites/sptests/sprbtree01/init.c | 111 +++++++++++++++++++++++++--
testsuites/sptests/sprbtree01/sprbtree01.scn | 5 +-
4 files changed, 118 insertions(+), 18 deletions(-)
diff --git a/cpukit/score/include/rtems/score/rbtree.h b/cpukit/score/include/rtems/score/rbtree.h
index b3f2ed4..2ec77ea 100644
--- a/cpukit/score/include/rtems/score/rbtree.h
+++ b/cpukit/score/include/rtems/score/rbtree.h
@@ -219,15 +219,16 @@ RBTree_Node *_RBTree_Find(
- * @brief Insert @a the_node on the Red-Black Tree @a the_rbtree.
+ * @brief Inserts the node into the red-black tree.
- * This routine inserts @a the_node on the Red-Black Tree @a the_rbtree.
+ * In case the node is already a node of a tree, then this function yields
+ * unpredictable results.
* @param[in] the_rbtree The red-black tree control.
* @param[in] the_node The node to insert.
* @param[in] compare The node compare function.
* @param[in] is_unique If true, then reject nodes with a duplicate key, else
- * otherwise.
+ * insert nodes in FIFO order in case the key value is equal to existing nodes.
* @retval NULL Successfully inserted.
* @retval existing_node This is a unique insert and there exists a node with
@@ -487,19 +488,20 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Successor(
- * @brief Gets a node with an extremal key value.
+ * @brief Gets a node with an extremal key value from the red-black tree.
* This function extracts a node with the minimum or maximum key value from
* tree and returns a pointer to that node if it exists. In case multiple
- * nodes with an extremal key value exist, then they are extracted in FIFO
- * order.
+ * nodes with a minimum key value exist, then they are extracted in FIFO order.
+ * In case multiple nodes with a maximum key value exist, then they are
+ * extracted in LIFO order.
* @param[in] dir Specifies whether to get a node with the minimum (RBT_LEFT)
* or maximum (RBT_RIGHT) key value.
* @retval NULL The tree is empty.
- * @retval extremal_node A node with the minimal or maximal key value on the
+ * @retval extremal_node A node with a minimal or maximal key value on the
* tree.
RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Get(
diff --git a/cpukit/score/src/rbtreeinsert.c b/cpukit/score/src/rbtreeinsert.c
index b31c8e7..afff1ef 100644
--- a/cpukit/score/src/rbtreeinsert.c
+++ b/cpukit/score/src/rbtreeinsert.c
@@ -96,8 +96,8 @@ RBTree_Node *_RBTree_Insert(
if (
- ( !dir && _RBTree_Is_lesser( compare_result ) )
- || ( dir && _RBTree_Is_greater( compare_result ) )
+ ( dir == RBT_LEFT && _RBTree_Is_lesser( compare_result ) )
+ || ( dir == RBT_RIGHT && !_RBTree_Is_lesser( compare_result ) )
the_rbtree->first[ dir ] = the_node;
diff --git a/testsuites/sptests/sprbtree01/init.c b/testsuites/sptests/sprbtree01/init.c
index 956271b..2c62d12 100644
--- a/testsuites/sptests/sprbtree01/init.c
+++ b/testsuites/sptests/sprbtree01/init.c
@@ -19,11 +19,13 @@ const char rtems_test_name[] = "SPRBTREE 1";
/* forward declarations to avoid warnings */
rtems_task Init(rtems_task_argument argument);
-int numbers[20] = {
-52, 99, 0, 85, 43, 44, 10, 60, 50, 19, 8, 68, 48, 57, 17, 67, 90, 12, 77, 71};
+static const int numbers[20] = {
+ 52, 99, 0, 85, 43, 44, 10, 60, 50, 19, 8, 68, 48, 57, 17, 67, 90, 12, 77, 71
-int numbers_sorted[20] = {
- 0, 8, 10, 12, 17, 19, 43, 44, 48, 50, 52, 57, 60, 67, 68, 71, 77, 85, 90, 99};
+static const int numbers_sorted[20] = {
+ 0, 8, 10, 12, 17, 19, 43, 44, 48, 50, 52, 57, 60, 67, 68, 71, 77, 85, 90, 99
typedef struct {
int id;
@@ -121,11 +123,104 @@ static int rb_assert ( rtems_rbtree_node *root )
+static test_node some_nodes[] = {
+ { .key = 1 },
+ { .key = 1 },
+ { .key = 1 },
+ { .key = 2 },
+ { .key = 2 },
+ { .key = 2 }
+static void min_max_insert(
+ rtems_rbtree_control *tree,
+ rtems_rbtree_node *node,
+ rtems_rbtree_node *min,
+ rtems_rbtree_node *max
+ rb_insert_multi( tree, node );
+ rtems_test_assert( rb_assert( tree->root ) != -1 );
+ rtems_test_assert( tree->first[ 0 ] == min );
+ rtems_test_assert( tree->first[ 1 ] == max );
+static void min_max_extract(
+ rtems_rbtree_extract( tree, node );
+static void test_rbtree_min_max(void)
+ rtems_rbtree_control tree;
+ rtems_rbtree_node *node;
+ rtems_rbtree_node *min;
+ rtems_rbtree_node *max;
+ puts( "INIT - Verify min/max node updates" );
+ rtems_rbtree_initialize_empty( &tree );
+ rtems_test_assert( rb_assert( tree.root ) == 1 );
+ node = &some_nodes[ 0 ].Node;
+ min = node;
+ max = node;
+ min_max_insert( &tree, node, min, max );
+ node = &some_nodes[ 1 ].Node;
+ max = node;
-rtems_task Init(
- rtems_task_argument ignored
+ node = &some_nodes[ 2 ].Node;
+ max = node;
+ node = &some_nodes[ 3 ].Node;
+ max = node;
+ node = &some_nodes[ 4 ].Node;
+ max = node;
+ node = &some_nodes[ 5 ].Node;
+ max = node;
+ min_max_extract( &tree, node, min, max );
+ min = &some_nodes[ 2 ].Node;
+ max = &some_nodes[ 3 ].Node;
+ min = &some_nodes[ 3 ].Node;
+ min = NULL;
+ max = NULL;
+ rtems_test_assert( rtems_rbtree_is_empty( &tree ) );
+rtems_task Init( rtems_task_argument ignored )
rtems_rbtree_control rbtree1;
rtems_rbtree_node *p;
@@ -682,6 +777,8 @@ rtems_task Init(
rtems_test_exit(0);
+ test_rbtree_min_max();
TEST_END();
rtems_test_exit(0);
diff --git a/testsuites/sptests/sprbtree01/sprbtree01.scn b/testsuites/sptests/sprbtree01/sprbtree01.scn
index 0bf2007..0d37566 100644
--- a/testsuites/sptests/sprbtree01/sprbtree01.scn
+++ b/testsuites/sptests/sprbtree01/sprbtree01.scn
@@ -1,4 +1,4 @@
-*** TEST OF RTEMS RBTREE API ***
+*** BEGIN OF TEST SPRBTREE 1 ***
Init - Initialize rbtree empty
INIT - Verify rtems_rbtree_insert with two nodes
INIT - Verify rtems_rbtree_insert with the same value twice
@@ -31,4 +31,5 @@ INIT - Removing 100 nodes
INIT - Verify rtems_rbtree_insert with 100 nodes value [99,0]
INIT - Verify rtems_rbtree_find in a duplicate tree
-*** END OF RTEMS RBTREE API TEST ***
+INIT - Verify min/max node updates
+*** END OF TEST SPRBTREE 1 ***
1.8.1.4
