[PATCH v2] cpukit/cpu/i386: RTEMS_PARAVIRT guards, functionality and virt.layer
Tue Jul 22 17:37:42 UTC 2014
At a high-level, I think it best to avoid calls to unlinked library
functions. Instead implement them in the BSP where possible. We can
refactor score code to support such call-outs, but I would rather not
be using symbols in score that are not defined anywhere in RTEMS.
The way to do this will be to change CPU_PROVIDES_IDLE_THREAD_BODY to
FALSE in i386/rtems/score/cpu.h, and move the Thread_Idle_body to the
pc386 bsp.
The tricky part is para-virtualizing the interrupt enable/disable
code. Historically speaking, Joel has been against having this code be
changed into a function call, but I wonder if the simplification here
is worth the cost. If you post a patch with the isr enable/disable
also refactored into the BSP layer, we could test it out at least.
Gedare
On Fri, Jul 18, 2014 at 12:34 PM, Philipp Eppelt
<philipp.eppelt at mailbox.tu-dresden.de> wrote:
> This is an updated version of an earlier unmerged patch, which extends the
> cpukit/score/cpu/i386/ model with guards to distinguish between
> paravirtualized (--enable-paravirt) and native environments.
>  cpukit/score/cpu/i386/Makefile.am                  |  1 +
>  cpukit/score/cpu/i386/cpu.c                        | 18 +++++
>  cpukit/score/cpu/i386/preinstall.am                |  3 +
>  cpukit/score/cpu/i386/rtems/score/cpu.h            | 48 +++++++++---
>  cpukit/score/cpu/i386/rtems/score/interrupts.h     | 38 ++++++++-
>  .../cpu/i386/rtems/score/virtualizationlayercpu.h  | 91 ++++++++++++++++++++++
>  6 files changed, 185 insertions(+), 14 deletions(-)
>  create mode 100644 cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h
> diff --git a/cpukit/score/cpu/i386/Makefile.am b/cpukit/score/cpu/i386/Makefile.am
> index 494cd67..2293a3b 100644
> --- a/cpukit/score/cpu/i386/Makefile.am
> +++ b/cpukit/score/cpu/i386/Makefile.am
> @@ -11,6 +11,7 @@ include_rtems_score_HEADERS += rtems/score/interrupts.h
>  include_rtems_score_HEADERS += rtems/score/registers.h
>  include_rtems_score_HEADERS += rtems/score/idtr.h
>  include_rtems_score_HEADERS += rtems/score/cpuatomic.h
> +include_rtems_score_HEADERS += rtems/score/virtualizationlayercpu.h
>  noinst_LIBRARIES = libscorecpu.a
>  libscorecpu_a_SOURCES = cpu.c cpu_asm.S
> diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
> index 38b84e6..fb89df1 100644
> --- a/cpukit/score/cpu/i386/cpu.c
> +++ b/cpukit/score/cpu/i386/cpu.c
> @@ -26,6 +26,8 @@
>  #include <rtems/bspIo.h>
>  #include <rtems/score/thread.h>
> +#include <rtems/score/virtualizationlayercpu.h>
>  #define I386_ASSERT_OFFSET(field, off) \
>    RTEMS_STATIC_ASSERT( \
>      offsetof(Context_Control, field) \
> @@ -115,6 +117,19 @@ uint32_t   _CPU_ISR_Get_level( void )
>    return level;
> +#if defined(RTEMS_PARAVIRT)
> +void *_CPU_Thread_Idle_body( uintptr_t ignored )
> +  while(1)
> +    _CPU_Virtual_Idle_thread();
> +  return NULL;
> +#else
>    while(1){
> @@ -123,6 +139,8 @@ void *_CPU_Thread_Idle_body( uintptr_t ignored )
>    return NULL;
> +#endif /*RTEMS_PARAVIRT*/
>  struct Frame_ {
>         struct Frame_  *up;
>         uintptr_t               pc;
> diff --git a/cpukit/score/cpu/i386/preinstall.am b/cpukit/score/cpu/i386/preinstall.am
> index 060176b..4fd8533 100644
> --- a/cpukit/score/cpu/i386/preinstall.am
> +++ b/cpukit/score/cpu/i386/preinstall.am
> @@ -55,3 +55,6 @@ $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h: rtems/score/cpuatomic.h $(PROJECT_IN
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
> +$(PROJECT_INCLUDE)/rtems/score/virtualizationlayercpu.h: rtems/score/virtualizationlayercpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/virtualizationlayercpu.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/virtualizationlayercpu.h
> diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
> index 2d1472d..7567777 100644
> --- a/cpukit/score/cpu/i386/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
> @@ -35,6 +35,8 @@ extern "C" {
>  #include <rtems/score/registers.h>     /* formerly part of libcpu */
>  #endif
>  /* conditional compilation parameters */
>  #define CPU_INLINE_ENABLE_DISPATCH       TRUE
> @@ -400,11 +402,22 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
>  #define _CPU_ISR_Flash( _level )   i386_flash_interrupts( _level )
> -#define _CPU_ISR_Set_level( _new_level ) \
> -    if ( _new_level ) __asm__ volatile ( "cli" ); \
> -    else              __asm__ volatile ( "sti" ); \
> +  #define _CPU_ISR_Set_level( _new_level ) \
> +      if( _new_level )  _CPU_Virtual_Interrupts_close(); \
> +      else             _CPU_Virtual_Interrupts_open(); \
> +#else
> +      if ( _new_level ) __asm__ volatile ( "cli" ); \
> +      else              __asm__ volatile ( "sti" ); \
>  uint32_t   _CPU_ISR_Get_level( void );
> @@ -525,16 +538,27 @@ uint32_t   _CPU_ISR_Get_level( void );
>   *    + disable interrupts and halt the CPU
> -#define _CPU_Fatal_halt( _error ) \
> +  #define _CPU_Fatal_halt( _error ) \
> -    uint32_t _error_lvalue = ( _error ); \
> -    __asm__ volatile ( "cli ; \
> -                    movl %0,%%eax ; \
> -                    hlt" \
> -                    : "=r" ((_error_lvalue)) : "0" ((_error_lvalue)) \
> +    _CPU_Virtual_Interrupts_close(); \
> +    _CPU_Virtual_Stop_with_error( _error ); \
> +#else
> +      uint32_t _error_lvalue = ( _error ); \
> +      __asm__ volatile ( "cli ; \
> +                      movl %0,%%eax ; \
> +                      hlt" \
> +                      : "=r" ((_error_lvalue)) : "0" ((_error_lvalue)) \
>  #endif /* ASM */
>  /* end of Fatal Error manager macros */
> diff --git a/cpukit/score/cpu/i386/rtems/score/interrupts.h b/cpukit/score/cpu/i386/rtems/score/interrupts.h
> index 5ae172a..4233a34 100644
> --- a/cpukit/score/cpu/i386/rtems/score/interrupts.h
> +++ b/cpukit/score/cpu/i386/rtems/score/interrupts.h
> @@ -8,6 +8,8 @@
>   *  COPYRIGHT (c) 1998 valette at crf.canon.fr
> + *  COPYRIGHT (c) 2014 Philipp Eppelt.
> + *     philipp.eppelt at mailbox.tu-dresden.de
>   *  The license and distribution terms for this file may be
>   *  found in the file LICENSE in this distribution or at
> @@ -19,6 +21,8 @@
>  #ifndef _RTEMS_SCORE_INTERRUPTS_H
>  #define _RTEMS_SCORE_INTERRUPTS_H
>  #ifndef ASM
>  struct         __rtems_raw_irq_connect_data__;
> @@ -33,6 +37,35 @@ typedef int  (*rtems_raw_irq_is_enabled)     (const struct __rtems_raw_irq_connect_d
> +#define i386_disable_interrupts( _level ) \
> +    _CPU_Virtual_Interrupts_disable( _level ); \
> +#define i386_enable_interrupts( _level )  \
> +    _CPU_Virtual_Interrupts_enable( _level ); \
> +#define i386_flash_interrupts( _level ) \
> +    _CPU_Virtual_Interrupts_enable(_level); \
> +    _CPU_Virtual_Interrupts_disable(_level); \
> +#define i386_get_interrupt_level( _level ) \
> +    _CPU_Virtual_Interrupts_get_level( _level ); \
> +#define _CPU_ISR_Disable( _level ) i386_disable_interrupts( _level )
> +#define _CPU_ISR_Enable( _level ) i386_enable_interrupts( _level )
> +#else /*RTEMS_PARAVIRT*/
> @@ -75,7 +108,8 @@ typedef int  (*rtems_raw_irq_is_enabled)     (const struct __rtems_raw_irq_connect_d
> -#endif
> -#endif
> +#endif /* ASM */
> +#endif /* _RTEMS_SCORE_INTERRUPTS_H */
> diff --git a/cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h b/cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h
> new file mode 100644
> index 0000000..9834f82
> --- /dev/null
> +++ b/cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h
> @@ -0,0 +1,91 @@
> + * COPYRIGHT (c) 2013 Philipp Eppelt.
> + *  Purpose:   CPU part of the virtualization layer.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.com/license/LICENSE.
> +#ifndef RTEMS_VIRT_LAYER_CPU_H
> +#define RTEMS_VIRT_LAYER_CPU_H
> +#ifndef ASM
> +/* Interrupts */
> + * \brief Requests an interrupt vector.
> +int
> +_CPU_Virtual_Irq_request( int vector );
> + * \brief Releases an interrupt vector.
> +void
> +_CPU_Virtual_Irq_detach( int vector );
> + * \brief Enables interrupt delivery or sets it to the specified level.
> + * Use this function in collaboration with _CPU_Virtual_Interrupts_disable and
> + * use its returned _level as argument to this function to assure proper
> + * behaviour.
> +void
> +_CPU_Virtual_Interrupts_enable( int _level );
> + * \brief Disables interrupt delivery and returns the previous level.
> +void
> +_CPU_Virtual_Interrupts_disable( int _level );
> + * \brief Enables and directly disables interrupt delivery.
> +void
> +_CPU_Virtual_Interrupts_flash( int _level );
> + * \brief Requests the current interrupt level.
> +int
> +_CPU_Virtual_Interrupts_get_level( int _level );
> +void
> +_CPU_Virtual_Interrupts_open(void);
> +void
> +_CPU_Virtual_Interrupts_close( void );
> +/* Idle Thread */
> + * \brief Lowest priority thread, doing nothing, never returns;
> +void
> +_CPU_Virtual_Idle_thread( void );
> +/* Error handling */
> + * \brief Handlers execution errors.
> +void
> +_CPU_Virtual_Stop_with_error( int _error );
> +#endif /* ASM */
> +#endif /* RTEMS_VIRT_LAYER_CPU_H */
> 1.9.3
> devel mailing list
> devel at rtems.org
