[PATCH] capture: change to use malloc/vs/rtems_workspace_alloc.
Thu Jul 24 23:01:34 UTC 2014
On 24/07/2014 11:54 pm, Jennifer Averett wrote:
>   cpukit/libmisc/capture/capture.c | 17 ++++++++---------
>   1 file changed, 8 insertions(+), 9 deletions(-)
> diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
> index 9ec07b8..1fac4a0 100644
> --- a/cpukit/libmisc/capture/capture.c
> +++ b/cpukit/libmisc/capture/capture.c
> @@ -339,9 +339,9 @@ rtems_capture_create_control (rtems_name name, rtems_id id)
This one is ok.
>     if (control == NULL)
> -    bool ok = rtems_workspace_allocate (sizeof (*control), (void **) &control);
> +    control = malloc (sizeof (*control));
> -    if (!ok)
> +    if (control == NULL)
>         capture_flags |= RTEMS_CAPTURE_NO_MEMORY;
>         return NULL;
> @@ -386,11 +386,10 @@ rtems_capture_create_capture_task (rtems_tcb* new_task)
>     rtems_capture_control_t*     control;
>     rtems_name                   name;
>     rtems_capture_time_t         time;
> -  bool                         ok;
> -  ok = rtems_workspace_allocate (sizeof (*task), (void **) &task);
> +  task = malloc (sizeof (*task));
Can malloc be called while in a user extension such as the context switch ?
Calls to this function happen during a context switch as the capture
engine discovers existing tasks.
When this code was written calling malloc crashed the target during a
context switch.
> -  if (!ok)
> +  if (task == NULL)
>       return NULL;
> @@ -480,7 +479,7 @@ rtems_capture_destroy_capture_task (rtems_capture_task_t* task)
>       rtems_interrupt_lock_release (&capture_lock, &lock_context);
> -    rtems_workspace_free (task);
> +    free (task);
> @@ -1027,7 +1026,7 @@ rtems_capture_close (void)
>       rtems_capture_task_t* delete = task;
>       task = task->forw;
> -    rtems_workspace_free (delete);
> +    free (delete);
>     capture_tasks = NULL;
> @@ -1038,7 +1037,7 @@ rtems_capture_close (void)
>       rtems_capture_control_t* delete = control;
>       control = control->next;
> +    free (delete);
>     capture_controls = NULL;
> @@ -1216,7 +1215,7 @@ rtems_capture_watch_del (rtems_name name, rtems_id id)
> -      rtems_workspace_free (control);
> +      free (control);
>         control = *prev_control;
