[PATCH 3/3] bsp/altera-cyclone-v: Add RTC driver.
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jul 25 09:49:31 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am  |   4 +
 c/src/lib/libbsp/arm/altera-cyclone-v/README       |  15 +-
 .../lib/libbsp/arm/altera-cyclone-v/preinstall.am  |   6 +-
 c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c    | 360 +++++++++++++++++++++
 4 files changed, 381 insertions(+), 4 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
index 01b0272..939ccc7 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
@@ -200,6 +200,10 @@ libbsp_a_SOURCES += i2c/i2cdrv.c
 libbsp_a_SOURCES += i2c/i2cdrv-config.c
 include_bsp_HEADERS += include/i2cdrv.h
+# RTC
+libbsp_a_SOURCES += ../../shared/tod.c
+libbsp_a_SOURCES += rtc/rtc.c
 # Cache
 libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
 libbsp_a_SOURCES += ../shared/include/arm-cache-l1.h
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/README b/c/src/lib/libbsp/arm/altera-cyclone-v/README
index 575b72e..0a5bc05 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/README
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/README
@@ -1,3 +1,16 @@
+Overview
 Evaluation board for this BSP:
 - Cyclone V SoC FPGA Development Kit
-- DK-DEV-5CSXC6N/ES-0L
\ No newline at end of file
+- DK-DEV-5CSXC6N/ES-0L
+RTC
+The evaluation board contains a DS1339C RTC connected to I2C0. To use it you
+have to set the following options:
+  #define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+  #define CONFIGURE_BSP_PREREQUISITE_DRIVERS I2C_DRIVER_TABLE_ENTRY
+Additional there has to be one free file descriptor to access the i2c. Set the
+CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS accordingly.
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am b/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
index c13ef6a..4e3b586 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
@@ -5,14 +5,14 @@ $(srcdir)/preinstall.am: Makefile.am
 	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
 endif
+PREINSTALL_DIRS =
+DISTCLEANFILES += $(PREINSTALL_DIRS)
 all-am: $(PREINSTALL_FILES)
 PREINSTALL_FILES =
 CLEANFILES = $(PREINSTALL_FILES)
-PREINSTALL_DIRS =
-DISTCLEANFILES += $(PREINSTALL_DIRS)
 all-local: $(TMPINSTALL_FILES)
 TMPINSTALL_FILES =
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c b/c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c
new file mode 100644
index 0000000..3c18d1c
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c
@@ -0,0 +1,360 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <info at embedded-brains.de>
+ * Driver for the DS1339 RTC.
+ * Please note the following points:
+ * - The day of week is ignored.
+ * - The century bit is interpreted the following way:
+ *   - century not set: TOD_BASE_YEAR .. 1999
+ *   - century set: 2000 .. 2099
+ *   - century not set: 2100 .. (TOD_BASE_YEAR + 200)
+#include <libchip/rtc.h>
+#include <assert.h>
+#include <rtems/score/todimpl.h>
+#include <sys/filio.h>
+#include <fcntl.h>
+#include <unistd.h>
+#include <bsp/i2cdrv.h>
+#define ALTERA_CYCLONE_V_RTC_NUMBER 1
+#define DS1339_I2C_ADDRESS 0x68
+#define DS1339_I2C_BUS_DEVICE "/dev/i2c0"
+#define DS1339_ADDR_CTRL 0x0E
+#define DS1339_CTRL_EOSC 0x80
+#define DS1339_CTRL_BBSQI 0x20
+#define DS1339_CTRL_RS2 0x10
+#define DS1339_CTRL_RS1 0x08
+#define DS1339_CTRL_INTCN 0x04
+#define DS1339_CTRL_A2IE 0x02
+#define DS1339_CTRL_A1IE 0x01
+#define DS1339_CTRL_DEFAULT (0x00)
+#define DS1339_ADDR_TIME 0x00
+#define DS1339_ADDR_STATUS 0x0F
+#define DS1339_STATUS_OSF 0x80
+#define DS1339_STATUS_A2F 0x02
+#define DS1339_STATUS_A1F 0x01
+#define DS1339_STATUS_CLEAR (0x00)
+typedef struct {
+  uint8_t seconds;
+  uint8_t minutes;
+  uint8_t hours;
+#define DS1339_HOURS_12_24_FLAG 0x40
+#define DS1339_HOURS_AM_PM_FLAG_OR_20_HOURS 0x20
+#define DS1339_HOURS_10_HOURS 0x10
+  uint8_t weekday;
+  uint8_t date;
+  uint8_t month;
+#define DS1339_MONTH_CENTURY 0x80
+  uint8_t year;
+} ds1339_time_t;
+/* The longest write transmission is writing the time + one address bit */
+#define DS1339_MAX_WRITE_SIZE (sizeof(ds1339_time_t) + 1)
+/* Functions for converting the fields */
+static unsigned int get_seconds (ds1339_time_t *time) {
+  uint8_t tens = time->seconds >> 4;
+  uint8_t ones = time->seconds & 0x0F;
+  return tens * 10 + ones;
+static unsigned int get_minutes (ds1339_time_t *time) {
+  uint8_t tens = time->minutes >> 4;
+  uint8_t ones = time->minutes & 0x0F;
+static unsigned int get_hours (ds1339_time_t *time) {
+  uint8_t value = time->hours & 0x0F;
+  if(time->hours & DS1339_HOURS_10_HOURS) {
+    value += 10;
+  if(time->hours & DS1339_HOURS_AM_PM_FLAG_OR_20_HOURS) {
+    if(time->hours & DS1339_HOURS_12_24_FLAG) {
+      value += 12;
+    } else {
+      value += 20;
+  return value;
+static unsigned int get_day_of_month (ds1339_time_t *time) {
+  uint8_t tens = time->date >> 4;
+  uint8_t ones = time->date & 0x0F;
+static unsigned int get_month (ds1339_time_t *time) {
+  uint8_t tens = (time->month >> 4) & 0x07;
+  uint8_t ones = time->month & 0x0F;
+static unsigned int get_year (ds1339_time_t *time) {
+  unsigned int year = 1900;
+  year += (time->year >> 4) * 10;
+  year += time->year & 0x0F;
+  if(time->month & DS1339_MONTH_CENTURY) {
+    year += 100;
+  if(year < TOD_BASE_YEAR) {
+    year += 200;
+  return year;
+static void set_time (
+  ds1339_time_t *time,
+  unsigned int second,
+  unsigned int minute,
+  unsigned int hour,
+  unsigned int day,
+  unsigned int month,
+  unsigned int year
+  unsigned int tens;
+  unsigned int ones;
+  uint8_t century = 0;
+  tens = second / 10;
+  ones = second % 10;
+  time->seconds = tens << 4 | ones;
+  tens = minute / 10;
+  ones = minute % 10;
+  time->minutes = tens << 4 | ones;
+  tens = hour / 10;
+  ones = hour % 10;
+  time->hours = tens << 4 | ones;
+  /* Weekday is not used. Therefore it can be set to an arbitrary valid value */
+  time->weekday = 1;
+  tens = day / 10;
+  ones = day % 10;
+  time->date = tens << 4 | ones;
+  tens = month / 10;
+  ones = month % 10;
+  if(year >= 2000 && year < 2100) {
+    century = DS1339_MONTH_CENTURY;
+  time->month = century | tens << 4 | ones;
+  tens = (year % 100) / 10;
+  ones = year % 10;
+  time->year = tens << 4 | ones;
+static rtems_status_code ds1339_open_file(int *fd)
+  int rv = 0;
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  *fd = open(DS1339_I2C_BUS_DEVICE, O_RDWR);
+  if ( *fd == -1 ) {
+    sc = RTEMS_IO_ERROR;
+  if ( sc == RTEMS_SUCCESSFUL ) {
+    rv = ioctl(*fd, I2C_IOC_SET_SLAVE_ADDRESS, DS1339_I2C_ADDRESS);
+    if ( rv == -1 ) {
+  return sc;
+/* Read size bytes from ds1339 register address addr to buf. */
+static rtems_status_code ds1339_read(uint8_t addr, void *buf, size_t size)
+  int fd = -1;
+  int rv = 0;
+  sc = ds1339_open_file(&fd);
+    rv = write(fd, &addr, sizeof(addr));
+    if ( rv != sizeof(addr) ) {
+    rv = read(fd, buf, size);
+    if ( rv != size ) {
+  rv = close(fd);
+  if ( rv != 0 ) {
+  return sc;
+/* Write size bytes from buf to ds1339 register address addr. */
+static rtems_status_code ds1339_write(uint8_t addr, void *buf, size_t size)
+  int fd = -1;
+  int rv = 0;
+  /* The driver never writes many bytes. Therefore it should be less expensive
+   * to reserve the maximum number of bytes that will be written in one go than
+   * use a malloc. */
+  uint8_t local_buf[DS1339_MAX_WRITE_SIZE];
+  int write_size = size + 1;
+  assert(write_size <= DS1339_MAX_WRITE_SIZE);
+  local_buf[0] = addr;
+  memcpy(&local_buf[1], buf, size);
+    rv = write(fd, local_buf, write_size);
+    if ( rv != write_size ) {
+  rv = close(fd);
+  if ( rv != 0 ) {
+  return RTEMS_SUCCESSFUL;
+static void altera_cyclone_v_rtc_initialize(int minor)
+  uint8_t status = 0;
+  /* Check RTC valid */
+  sc = ds1339_read(DS1339_ADDR_STATUS, &status, sizeof(status));
+  assert(sc == RTEMS_SUCCESSFUL);
+  if(status & DS1339_STATUS_OSF) {
+    /* RTC has been stopped. Initialise it. */
+    ds1339_time_t time;
+    uint8_t write = DS1339_CTRL_DEFAULT;
+    sc = ds1339_write(DS1339_ADDR_CTRL, &write, sizeof(write));
+    write = DS1339_STATUS_CLEAR;
+    sc = ds1339_write(DS1339_ADDR_STATUS, &write, sizeof(write));
+    set_time(&time, 0, 0, 0, 1, 1, TOD_BASE_YEAR);
+    sc = ds1339_write(DS1339_ADDR_TIME, &time, sizeof(time));
+static int altera_cyclone_v_rtc_get_time(int minor, rtems_time_of_day *tod)
+  rtems_time_of_day temp_tod;
+  sc = ds1339_read(DS1339_ADDR_TIME, &time, sizeof(time));
+    temp_tod.ticks = 0;
+    temp_tod.second = get_seconds(&time);
+    temp_tod.minute = get_minutes(&time);
+    temp_tod.hour = get_hours(&time);
+    temp_tod.day = get_day_of_month(&time);
+    temp_tod.month = get_month(&time);
+    temp_tod.year = get_year(&time);
+    if ( _TOD_Validate(&temp_tod) ) {
+      memcpy(tod, &temp_tod, sizeof(temp_tod));
+    } else {
+      sc = RTEMS_INVALID_CLOCK;
+  return -sc;
+static int altera_cyclone_v_rtc_set_time(int minor, const rtems_time_of_day *tod)
+  set_time (
+    &time,
+    tod->second,
+    tod->minute,
+    tod->hour,
+    tod->day,
+    tod->month,
+    tod->year
+  return -sc;
+static bool altera_cyclone_v_rtc_probe(int minor)
+  /* FIXME: Probe for i2c device */
+  return true;
+const rtc_fns altera_cyclone_v_rtc_ops = {
+  .deviceInitialize = altera_cyclone_v_rtc_initialize,
+  .deviceGetTime = altera_cyclone_v_rtc_get_time,
+  .deviceSetTime = altera_cyclone_v_rtc_set_time
+size_t RTC_Count = ALTERA_CYCLONE_V_RTC_NUMBER;
+rtems_device_minor_number RTC_Minor = 0;
+rtc_tbl RTC_Table [ALTERA_CYCLONE_V_RTC_NUMBER] = {
+    .sDeviceName = "/dev/rtc",
+    .deviceType = RTC_CUSTOM,
+    .pDeviceFns = &altera_cyclone_v_rtc_ops,
+    .deviceProbe = altera_cyclone_v_rtc_probe,
+    .pDeviceParams = NULL,
+    .ulCtrlPort1 = 0,
+    .ulDataPort = 0,
+    .getRegister = NULL,
+    .setRegister = NULL
1.8.4.5
