[PATCH 4/6] spintrcritical20: Fix incorrect assumption
Joel Sherrill Joel.Sherrill at OARcorp.com
Thu Jul 10 13:24:31 UTC 2014
On Jul 10, 2014 2:14 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 2014-07-09 16:37, Joel Sherrill wrote:
> > I think this patch is wrong. Subsequent changes to the thread queue after I
> > posted this resulted in the test breaking again.
> > What is the test trying to do? I think sometimes through the loop, the
> > condition the test expects is not occurring and it fails.
>  From the doc file we have:
>    - Ensure that _Thread_queue_Process_timeout() works in case it is
>      interrupted and _Thread_queue_Dequeue() is called.
> It simulates a nested interrupt case.  Since we can use only the clock tick to
> work with interrupts I had to do the following:
> 1. Create a high priority task which creates the base state (semaphore locked).
> 2. Use a low priority task to simulate the timeout process.
> 3. Use a timer to simulate the high priority nested interrupt.
> I think this is the only test which uses this approach so far.  This partly
> explains why bugs like this prevailed for such a long time:
> https://www.rtems.org/bugzilla/show_bug.cgi?id=2140
> Do you not hit the test case or do you hit an assertion failure?
I hit the assertion case and suspect that it happens when the blocking thread has not gotten far enough along to be in a state where process timeout even sees it. I will debug more.
I don't think it is very broken. Just asserting conditions that are true most but not all of the time.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140710/96ff12e0/attachment-0002.html>
