[GSOC] GPIO status and I2C start
Alan Cudmore
alan.cudmore at gmail.com
Fri Jul 18 13:06:30 UTC 2014
Hi André,
I have a couple of SPI devices to try now. I have the SPI FRAM chip:
https://www.adafruit.com/product/1897
and something that could be interesting, an SPI based LCD/touchscreen:
https://www.adafruit.com/products/1601
I can also verify that the RTEMS BSP works fine on the new Raspberry Pi
Model B+
Alan
On Sat, Jul 5, 2014 at 6:58 PM, Andre Marques <andre.lousa.marques at gmail.com
> wrote:
> Hello,
> The Raspberry Pi GPIO interrupts are already working, and a test case is
> available to test that [1]. A function is also provided to debounce a
> switch if needed. The test case requires two switches and two LEDS using
> the same setup described at [2] by only changing the pin numbers.
> The test works by setting interrupts on both edges of the switches, which
> handlers will turn on or off the corresponding LED. One of the LEDs also
> has a level interrupt which prints a message on the screen when the LED is
> on (high level).
> While I wait for some feedback on that, I will be looking at the next
> step: the I2C interface. To test both the I2C and the SPI interfaces I have
> here a simple display [3]. The idea is to create a low level driver for I2C
> to provide the needed directives for the libi2c API, so the driver for the
> display will actually use the libi2c API. Any thoughts here are welcome too!
> Thanks,
> André Marques.
> [1] - https://github.com/asuol/rtems/blob/GPIO_API/
> testsuites/samples/LIBGPIO_TEST_IQR/init.c
> [2] - http://asuolgsoc2014.wordpress.com/2014/06/22/testing-the-gpio-api/
> [3] - http://www.newhavendisplay.com/nhd0216k3zflgbwv3-p-5738.html
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140718/3b42e41e/attachment-0002.html>
