[PATCH 4/4] score: Use Resource Handler for MrsP semaphores
Joel Sherrill Joel.Sherrill at OARcorp.com
Mon Jun 2 13:24:52 UTC 2014
On Jun 2, 2014 9:18 AM, Gedare Bloom <gedare at rtems.org> wrote:
> >> @@ -200,27 +250,36 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Obtain(
> >>    MRSP_Status status;
> >>    const Scheduler_Control *scheduler = _Scheduler_Get( executing );
> >>    uint32_t scheduler_index = _Scheduler_Get_index( scheduler );
> >> +  Priority_Control initial_priority = executing->current_priority;
> >>    Priority_Control ceiling_priority =
> >>      _MRSP_Get_ceiling_priority( mrsp, scheduler_index );
> >>    bool priority_ok = !_Scheduler_Is_priority_higher_than(
> >>      scheduler,
> >> -    executing->current_priority,
> >> +    initial_priority,
> >>      ceiling_priority
> >> +  Resource_Node *owner = _Resource_Get_owner( &mrsp->Resource );
> > I'd put this after the priority_ok check, for better readability by
> > keeping the error check closer to the cause. (Ahem, this should
> > probably be in our conventions too, eh?)
> >>    if ( !priority_ok) {
> >>      return MRSP_INVALID_PRIORITY;
> I guess I wasn't clear, I meant you should do owner =
> _Resource_Get_owner() here. e.g.
> Resource_Node *owner;
>       scheduler,
>       initial_priority,
>       ceiling_priority
> Also, at one point in time we discussed about a rule of not having
> function calls in variable initialization. I will look if that is an
> actual convention or not, but it would make this code easier to read.
I personally find function calls in variable initialization a potential source of undesirable side-effects.
Does this resource tracking replace the code for strict order mutex?
> -Gedare
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140602/94428a3c/attachment.html>
