[PATCH] shell: Add rtems_shell_dup_current_env to get a default env.
Sebastian Huber
Wed Jun 4 06:28:05 UTC 2014
On 2014-05-29 07:10, Chris Johns wrote:
> Remove rtems_current_shell_env as this is dangerous because
> the env can be NULL if used outside of a valid shell with the
> POSIX key to an env set up.
> Clean up the usage of rtems_current_shell_env.
The cleanup looks good, but we should keep the rtems_global_shell_env. I
underestimated its widespread use, so it was an error that we removed it. Now
it is a constant, so you can use it only for the initialization with default
values.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
