[PATCH] shell: Add rtems_shell_dup_current_env to get a default env.
Wed Jun 4 11:07:05 UTC 2014
On 2014-06-04 12:55, Chris Johns wrote:
> On 4/06/2014 4:28 pm, Sebastian Huber wrote:
>> On 2014-05-29 07:10, Chris Johns wrote:
>>> Remove rtems_current_shell_env as this is dangerous because
>>> the env can be NULL if used outside of a valid shell with the
>>> POSIX key to an env set up.
>>> Clean up the usage of rtems_current_shell_env.
>> The cleanup looks good, but we should keep the rtems_global_shell_env.
>> I underestimated its widespread use, so it was an error that we removed
>> it.  Now it is a constant, so you can use it only for the initialization
>> with default values.
> I would rather this API cleaned up and only a single way for applications to do
> this. It is a simple and clean change.
> The change I have uses the environment of a caller if the caller has a specific
> environment in the key else the base it used, ie inherits the environment if
> present.
This is definitely better and we should add this rtems_shell_dup_current_env(),
but I would nonetheless keep the rtems_global_shell_env for backward compatibility.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
