[PATCH] shell: Add rtems_shell_dup_current_env to get a default env.
Wed Jun 4 12:58:53 UTC 2014
On Wed, Jun 4, 2014 at 7:07 AM, Sebastian Huber
> On 2014-06-04 12:55, Chris Johns wrote:
>> On 4/06/2014 4:28 pm, Sebastian Huber wrote:
>>> On 2014-05-29 07:10, Chris Johns wrote:
>>>> Remove rtems_current_shell_env as this is dangerous because
>>>> the env can be NULL if used outside of a valid shell with the
>>>> POSIX key to an env set up.
>>>> Clean up the usage of rtems_current_shell_env.
>>> The cleanup looks good, but we should keep the rtems_global_shell_env.
>>> I underestimated its widespread use, so it was an error that we removed
>>> it.  Now it is a constant, so you can use it only for the initialization
>>> with default values.
>> I would rather this API cleaned up and only a single way for applications
>> to do
>> this. It is a simple and clean change.
>> The change I have uses the environment of a caller if the caller has a
>> specific
>> environment in the key else the base it used, ie inherits the environment
>> if
>> present.
> This is definitely better and we should add this
> rtems_shell_dup_current_env(), but I would nonetheless keep the
> rtems_global_shell_env for backward compatibility.
Is it feasible to provide a macro for rtems_global_shell_env that
provides the compatibility?
We should definitely put it on the list to eliminate at least after
4.11 (*prod*)
-Gedare
> rtems-devel mailing list
> rtems-devel at rtems.org
