BSP submitting requirements
Marcos Díaz marcos.diaz at tallertechnologies.com
Wed Jun 4 20:58:07 UTC 2014
Here is a patch in order to configure the minimum stack size for a
task for a bsp. We tested it with our bsp to be submitted.
On Wed, Jun 4, 2014 at 12:50 PM, Joel Sherrill
<Joel.Sherrill at oarcorp.com> wrote:
> The patch I sent you needs be reflected I user docs. Conf.t in doc/user. But
> it is a prerequisite and independent.
> I am at an Open Group meeting and can't code much.
> On Jun 4, 2014 10:43 AM, =?ISO-8859-1?Q?Marcos_D=EDaz?=
> <marcos.diaz at tallertechnologies.com> wrote:
> Our tests passed report was made with that configuration (1k stack
> size for tasks), shall we first submit this patch and then our bsp, or
> is the same.
> On Wed, Jun 4, 2014 at 12:11 PM, Marcos Díaz
>> Ok thanks!
>> On Wed, Jun 4, 2014 at 11:57 AM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>>> On 6/4/2014 9:48 AM, Marcos Díaz wrote:
>>>> Ok, but with that modification, just our bsp will be changed, my
>>>> suggestion is to put a macro defined in our bsp:
>>>>  # ifdef ARM_LPC1768_MBED
>>>>   #define ARM_CPU_STACK_MINIMUM_SIZE 1024
>>>> # else
>>>>   #define ARM_CPU_STACK_MINIMUM_SIZE 4096
>>>> # endif
>>>> And if I change it in confdefs should I put it with the same macro?
>>> That is not a good way to do it. This is an uncompiled shot at it:
>>> $ git diff cpukit/sapi/
>>> diff --git a/cpukit/sapi/include/confdefs.h
>>> b/cpukit/sapi/include/confdefs.h
>>> index 9a4149e..e5037d9 100644
>>> --- a/cpukit/sapi/include/confdefs.h
>>> +++ b/cpukit/sapi/include/confdefs.h
>>> @@ -52,6 +52,7 @@
>>>    #undef BSP_IDLE_TASK_BODY
>>>    #undef BSP_IDLE_TASK_STACK_SIZE
>>>    #undef BSP_INITIAL_EXTENSION
>>> +  #undef BSP_MINIMUM_TASK_STACK_SIZE
>>>    #undef BSP_INTERRUPT_STACK_SIZE
>>>    #undef BSP_MAXIMUM_DEVICES
>>>    #undef BSP_ZERO_WORKSPACE_AUTOMATICALLY
>>> @@ -1013,7 +1014,11 @@ const rtems_libio_helper rtems_fs_init_helper =
>>>   * By default, use the minimum stack size requested by this port.
>>>  #ifndef CONFIGURE_MINIMUM_TASK_STACK_SIZE
>>> -  #define CONFIGURE_MINIMUM_TASK_STACK_SIZE CPU_STACK_MINIMUM_SIZE
>>> +  #ifdef BSP_MINIMUM_TASK_STACK_SIZE
>>> +    #define CONFIGURE_MINIMUM_TASK_STACK_SIZE CPU_STACK_MINIMUM_SIZE
>>> +  #else
>>> +  #endif
>>>  #endif
>>>  #define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE \
>>>> I don't know what is that test configuration file, where can i learn
>>>> more about it?
>>> There isn't much to it except a list of tests by name that the BSP
>>> cannot link
>>> or has a known execution failure with that can't be fixed. Then they get
>>> skipped during the build process. Look in this directory for *.tcfg
>>> c/src/lib/libbsp/sh/gensh1/make/custom/
>>>> On Wed, Jun 4, 2014 at 11:38 AM, Joel Sherrill
>>>>> On 6/4/2014 9:22 AM, Marcos Díaz wrote:
>>>>>> Thanks!
>>>>>> I have another question:
>>>>>> We are developing a bsp for a board with very little memory (32k) when
>>>>>> we tried to run tmtest (and others) we encounter that couldnt allocate
>>>>>> more RAM, and one of the things that we saw we could improve is the
>>>>>> stack size passed for each task.
>>>>>> For this there exists the CPU_STACK_MINIMUM_SIZE macro, but
>>>>>> unfortunately it is defined to 4k for ARM, which is too much for us
>>>>>> (http://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/rtems/score/cpu.h#n176)
>>>>>> The question is:
>>>>>> Can we change this macro like for the m68k boards:
>>>>>> http://git.rtems.org/rtems/tree/cpukit/score/cpu/m68k/rtems/score/cpu.h#n384
>>>>>> and
>>>>>> http://git.rtems.org/rtems/tree/cpukit/score/cpu/m68k/rtems/score/m68k.h#n160
>>>>>> Is this the correct way to do this?
>>>>> The answer comes down to whether this multilib variant always has low
>>>>> memory
>>>>> or not. If some boards with this CPU core have plenty of RAM, then you
>>>>> shouldn't
>>>>> do it this way.
>>>>> One simple solution that comes to mind is a simple modification to
>>>>> confdefs.h
>>>>> (and the documentation) to allow for a BSP specific override of minimum
>>>>> stack
>>>>> size. We have a similar pattern in place for the idle thread body so
>>>>> there is
>>>>> precedence.  See cpukit/sapi/include/confdefs.h. It is a large file but
>>>>> largely
>>>>> mechanical. This would be a very clean way to do it.
>>>>> Also you have the option of a test configuration file. Did you use
>>>>> that? It
>>>>> is a new thing Chris Johns and I worked through recently.
>>>>>> Thanks!
>>>>>> On Wed, Jun 4, 2014 at 11:10 AM, Joel Sherrill
>>>>>>> On 6/4/2014 8:52 AM, Marcos Díaz wrote:
>>>>>>>> Hi, we were running the check_submission script and we were fixing
>>>>>>>> some issues. but now we are having two problems:
>>>>>>> The script is far from perfect and the structure of a BSP is a moving
>>>>>>> target.
>>>>>>>> One is that a missing file, for example bsp_interrupt_vector_enable,
>>>>>>>> which is defined in the shared folder outside our bsp's folder,
>>>>>>>> gives
>>>>>>>> a warning (only with verbose set), but also sets faults to 1, so, we
>>>>>>>> think it should be just a warning.
>>>>>>> Can you provide the output and a candidate patch?
>>>>>>>> Other is the missing sbrk. Thanks!
>>>>>>> A BSP provides its own sbrk(). Most use the default one in
>>>>>>> libbsp/shared.
>>>>>>> Should just be a matter of including in in Makefile.am.
>>>>>>> --joel
>>>>>>>> On Fri, May 30, 2014 at 12:38 PM, Marcos Díaz
>>>>>>>>> It doesn't run in any simulator..
>>>>>>>>> when
>>>>>>>>> allocate
>>>>>>>>> The question is:
>>>>>>>>> and
>>>>>>>>> Thanks!
>>>>>>>>> On Fri, May 30, 2014 at 12:33 PM, Joel Sherrill
>>>>>>>>>> On 5/30/2014 9:51 AM, Marcos Díaz wrote:
>>>>>>>>>>> thanks to all! We will try to submit it soon!
>>>>>>>>>> Does the BSP run on any simulator? If so, there are a
>>>>>>>>>> couple of other things we like to have to aid automated
>>>>>>>>>> testing.
>>>>>>>>>> Also there is a new file .tcfg which can list the files
>>>>>>>>>> which do not link or run with a known/expected
>>>>>>>>>> failure on your BSP.  See
>>>>>>>>>> libbsp/arm/gdbarmsim/make/custom/arm1136jfs-testsuite.tcfg
>>>>>>>>>> for an example. This is a great way to ignore tests
>>>>>>>>>> which do not fit on the target.
>>>>>>>>>>> On Thu, May 29, 2014 at 5:16 PM, Joel Sherrill
>>>>>>>>>>>> On 5/29/2014 2:34 PM, Gedare Bloom wrote:
>>>>>>>>>>>>> On Thu, May 29, 2014 at 3:02 PM, Marcos Díaz
>>>>>>>>>>>>>> Hi! We are about to submit a BSP but we have some doubts:
>>>>>>>>>>>>>> In http://www.rtems.org/wiki/index.php/Submitting_a_BSP
>>>>>>>>>>>>>> there is a point that refers to:
>>>>>>>>>>>>>> Do all files have a CVS $Id$ in them?
>>>>>>>>>>>>>> What does this mean?
>>>>>>>>>>>>> That is outdated and shouldn't be there. There is a script in
>>>>>>>>>>>>> the
>>>>>>>>>>>>> rtems-testing.git repository located at
>>>>>>>>>>>>> merge-helpers/check_submission
>>>>>>>>>>>>> that may be useful to run. I don't know there is much
>>>>>>>>>>>>> documentation
>>>>>>>>>>>>> for it, but you just run it from your bsp directory and it does
>>>>>>>>>>>>> some
>>>>>>>>>>>>> checks about what is expected to exist in a bsp.
>>>>>>>>>>>>>> There is other:
>>>>>>>>>>>>>> Did you provide a TIMES files with the results of the tmtests?
>>>>>>>>>>>>>> is there any example of a file like this in order to see how
>>>>>>>>>>>>>> it should be
>>>>>>>>>>>>> I think this is old too and can be ignored for now, I only see
>>>>>>>>>>>>> one
>>>>>>>>>>>>> example in the tree under libbsp/m68k/uC5282/TIMES
>>>>>>>>>>>> There are more times* files in the tree.
>>>>>>>>>>>> These are certainly optional but give the next person a good
>>>>>>>>>>>> handle on
>>>>>>>>>>>> what the expected performance is.
>>>>>>>>>>>>> -Gedare
>>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>> ______________________________
>>>>>>>>>>>>>> Marcos Díaz
>>>>>>>>>>>>>> Software Engineer
>>>>>>>>>>>>>> San Lorenzo 47, 3rd Floor, Office 5
>>>>>>>>>>>>>> Córdoba, Argentina
>>>>>>>>>>>>>> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>>>>>>>>>>>> Skype: markdiaz22
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> rtems-devel mailing list
>>>>>>>>>>>>>> rtems-devel at rtems.org
>>>>>>>>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>>>>>>>>>>> Joel Sherrill, Ph.D.             Director of Research &
>>>>>>>>>>>> Development
>>>>>>>>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>>>>>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>>>>>>>> Support Available                (256) 722-9985
>>>>>>>>>> Development
>>>>>>>>> Marcos Díaz
>>>>>>>>> Software Engineer
>>>>>>>>> Córdoba, Argentina
>>>>>>>>> Skype: markdiaz22
>>>>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>> Marcos Díaz
>> Software Engineer
>> Córdoba, Argentina
>> Skype: markdiaz22
> Marcos Díaz
> Software Engineer
> Córdoba, Argentina
> Skype: markdiaz22
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 9a4149e..24bccbf 100644
@@ -50,6 +50,7 @@
 #ifdef CONFIGURE_DISABLE_BSP_SETTINGS
   #undef BSP_DEFAULT_UNIFIED_WORK_AREAS
+  #ifndef BSP_MINIMUM_TASK_STACK_SIZE
+  #else
+    #define CONFIGURE_MINIMUM_TASK_STACK_SIZE BSP_MINIMUM_TASK_STACK_SIZE
+  #endif
 #endif
diff --git a/doc/user/conf.t b/doc/user/conf.t
index d72ff06..c5e7681 100644
--- a/doc/user/conf.t
+++ b/doc/user/conf.t
@@ -3222,6 +3222,46 @@ and peripheral buses, a BSP specific IDLE task may be capable of turning
 components off to save power during extended periods of no task activity
 @c
+ at c === BSP_MINIMUM_TASK_STACK_SIZE ===
+ at c
+ at subsection Specify BSP Suggested Value for Minimum Task Stack Size
+ at findex BSP_MINIMUM_TASK_STACK_SIZE
+ at table @b
+ at item CONSTANT:
+ at code{BSP_MINIMUM_TASK_STACK_SIZE}
+ at item DATA TYPE:
+Unsigned integer (@code{size_t}).
+ at item RANGE:
+Undefined or positive.
+ at item DEFAULT VALUE:
+This option is BSP specific.
+ at end table
+ at subheading DESCRIPTION:
+If @code{BSP_MINIMUM_TASK_STACK_SIZE} is defined by the BSP and
+ at code{CONFIGURE_MINIMUM_TASK_STACK_SIZE} is not defined by the application,
+then this BSP suggested minimum task stack size will be used.
+ at subheading NOTES:
+The order of precedence for configuring the minimum task stack size is:
+ at itemize @bullet
+ at item RTEMS default minimum stack size.
+ at item If defined, then the BSP specific @code{BSP_MINIMUM_TASK_STACK_SIZE}.
+ at item If defined, then the application specified
+ at code{CONFIGURE_MINIMUM_TASK_STACK_SIZE}.
+ at end itemize
+ at c XXX - add cross references to other related values.
+ at c
 @c === BSP_IDLE_TASK_STACK_SIZE ===
 @c
 @subsection Specify BSP Suggested Value for IDLE Task Stack Size
@@ -3255,9 +3295,9 @@ The order of precedence for configuring the IDLE task stack size is:
 @itemize @bullet
 @item RTEMS default minimum stack size.
 @item If defined, then @code{CONFIGURE_MINIMUM_TASK_STACK_SIZE}.
- at item If defined, then the BSP specific @code{BSP_IDLE_TASK_SIZE}.
+ at item If defined, then the BSP specific @code{BSP_IDLE_TASK_STACK_SIZE}.
 @item If defined, then the application specified
- at code{CONFIGURE_IDLE_TASK_SIZE}.
+ at code{CONFIGURE_IDLE_TASK_STACK_SIZE}.
 @end itemize
 @c XXX - add cross references to other related values.
