BSP submitting requirements
Marcos Díaz marcos.diaz at tallertechnologies.com
Thu Jun 5 13:04:01 UTC 2014
Yes, we made this patch in order to the testsuites work correctly. So
you think we should change the macro value in cpu.h and arm.h as i
proposed before?
On Thu, Jun 5, 2014 at 8:37 AM, Sebastian Huber
> On 2014-06-04 23:05, Joel Sherrill wrote:
>> FWIW I wrote the confdefs.h part and Marcos wrote the documentation.
>> He spotted a typo and missed that also.
> I am not sure if the BSP should be responsible for a default task stack
> size. The BSP has nothing to do with the code generation and the general
> architecture specifics that determine the typical stack usage.
> Which problem does this new define address?  Is this the test suite?  In
> case the tests pass with a stack size of 1024 on this BSP, then they will
> pass on all ARM BSPs using the same instruction set.
> rtems-devel mailing list
> rtems-devel at rtems.org
Marcos Díaz
Software Engineer
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
Skype: markdiaz22
