BSP submitting requirements
Thu Jun 5 13:54:44 UTC 2014
On 2014-06-05 15:04, Marcos Díaz wrote:
> Yes, we made this patch in order to the testsuites work correctly. So
> you think we should change the macro value in cpu.h and arm.h as i
> proposed before?
So you can run the complete test suite with a default stack size of 1024?
I wouldn't change the default for ARM, since this can break existing
applications that rely on the 4k.
I think this new BSP specific setting makes it harder for users to know what is
going on.  Since I don't have a better alternative, your patch is fine.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
