[PATCH] bsps/powerpc: Fix potential relocation truncation
    Sebastian Huber
    Fri Jun  6 14:24:02 UTC 2014
See also
https://sourceware.org/ml/binutils/2014-06/msg00059.html
On Fri, Jun 06, 2014 at 11:01:10AM +0200, Sebastian Huber wrote:
> I performed a git bisect and found this:
> 93d1b056cb396d6468781fe0e40dd769891bed32 is the first bad commit
> commit 93d1b056cb396d6468781fe0e40dd769891bed32
> Author: Alan Modra <amodra at gmail.com>
> Date:   Tue May 20 11:42:42 2014 +0930
>     Rewrite ppc32 backend .sdata and .sdata2 handling
Hmm, I'm surprised that your git bisect found this patch.  Was
_SDA_BASE_ set differently before this?
>                 0x00000000000dfc00                _SDA_BASE_
>                 0x00000000000d7f78                ppc_exc_lock_std
>      4b8:       28 05 00 00     cmplwi  r5,0
>                         4ba: R_PPC_SDAREL16     ppc_exc_lock_std
ppc_exc_lock_std at sdarel will be calculating 0xd7f78 - 0xdfc00
which is 0xf...fff8378, and that falls foul of
commit 86c9573369616e7437481b6e5533aef3a435cdcf
Date:   Sat Mar 8 13:05:06 2014 +1030
    Better overflow checking for powerpc32 relocations
cmplwi has an *unsigned* 16-bit field, and we now check the overflow
properly.
I wonder how many more of these we'll hit, and whether the uproar will
be enough that I'll be forced to relax the checks?
 .../new-exceptions/bspsupport/ppc_exc_asm_macros.h |   25 +++++++++++--------
 1 files changed, 14 insertions(+), 11 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h
index 0e3bc96..bdcfb78 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h
@@ -147,8 +147,9 @@ ppc_exc_min_prolog_sync_\_NAME:
  * MACRO: TEST_1ST_OPCODE_crit
- * USES:    REG, cr0
- * ON EXIT: REG available (contains *pc - STW_R1_R13(0)),
+ * USES:    REG, REG2, cr0
+ * ON EXIT: REG available (contains *pc),
+ *          REG2 available (contains 'stw r1, ppc_exc_lock_std at sdarel(r13)')
  *          return value in cr0.
  * test opcode interrupted by critical (asynchronous) exception; set CR_LOCK if
@@ -156,19 +157,21 @@ ppc_exc_min_prolog_sync_\_NAME:
  *   *SRR0 == 'stw r1, ppc_exc_lock_std at sdarel(r13)'
-	.macro	TEST_1ST_OPCODE_crit _REG
+	.macro	TEST_1ST_OPCODE_crit _REG _REG2
 	lwz	\_REG, SRR0_FRAME_OFFSET(FRAME_REGISTER)
+	/*	set lower 16bits of 'stw r1, ppc_exc_lock_std at sdarel(r13)' instruction */
+	addi	\_REG2, r0, ppc_exc_lock_std at sdarel
+	rlwinm	\_REG2, \_REG2, 0, 16, 31
 	lwz	\_REG, 0(\_REG)
 	/*	opcode now in REG */
-	/*	subtract upper 16bits of 'stw r1, 0(r13)' instruction */
-	subis	\_REG, \_REG, STW_R1_R13(0)@h
-	 * if what's left compares against the 'ppc_exc_lock_std at sdarel'
-	 * address offset then we have a match...
-	cmplwi	cr0, \_REG, ppc_exc_lock_std at sdarel
+	/*	set upper 16bits of 'stw r1, ppc_exc_lock_std at sdarel(r13)' instruction */
+	oris	\_REG2, \_REG2, STW_R1_R13(0)@h
+	cmpw	cr0, \_REG, \_REG2
 	.endm
@@ -215,7 +218,7 @@ ppc_exc_min_prolog_sync_\_NAME:
 	 * instruction which sets the lock; check this case by looking at the
 	 * opcode present at the interrupted PC location.
-	TEST_1ST_OPCODE_crit	_REG=SCRATCH_REGISTER_0
+	TEST_1ST_OPCODE_crit	_REG=SCRATCH_REGISTER_0 _REG2=SCRATCH_REGISTER_1
 	 * At this point cr0 is set if
1.7.7
