Check submission script
Tue Jun 10 06:51:19 UTC 2014
Hello,
the check submission script
http://git.rtems.org/rtems-testing/tree/merge-helpers/check_submission
contains a test for timing values
   # Hopefully have some output from the tmtests
   echo "=== Checking for timing information"
   c=$(ls -1 times* 2>/dev/null | wc -l)
   if [[ ${c} -eq 0 ]]; then
     echo "Please run the timing tests and include the results."
   fi
Is it really useful to add such timing values to the sources?  They may be out
of date right with the next commit.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
