[PATCH 2/5] SPARC: add BSP specific error handler
Tue Jun 10 07:34:00 UTC 2014
On 2014-06-09 11:06, Daniel Hellstrom wrote:
> On 06/05/2014 04:54 PM, Sebastian Huber wrote:
>> On 2014-06-04 20:48, Daniel Hellstrom wrote:
>>> On 06/04/2014 11:51 AM, Sebastian Huber wrote:
>>>> On 2014-06-04 11:23, Daniel Hellstrom wrote:
>>>>> Instead of calling the system call TA instruction directly it
>>>>> is better paractise to isolate the trap implementation to the
>>>>> system call functions.
>>>>> The BSP_fatal_return() should always exist, regardless of SPARC
>>>>> CPU.
>>>> Why do we need BSP_fatal_return() and bsp_reset()?
>>> The LEON3 doesn't, it does not define bsp_reset. I tried to preserve the
>>> behaviour of LEON2 and ERC32 BSPs, the bsp_reset is called from the fatal
>>> handler. On all SPARC BSPs, ending up in BSP_fatal_return is a result of
>>> bootcard or bsp_start_on_secondary_processor returning which they should never
>>> do. The two functions also have different error exit codes.
>> Ok, so this BSP_fatal_return() is used to mark unreachable code. Maybe we
>> should just remove these two special cases since its impossible to test this
>> code or we could also add a general _Unreachable_code() function.
> I'm fine with removing them. I'm not sure why it was originally this way, there
> was probably some reason for it in the first place.
Originally the _Thread_Start_multitasking() and thus boot_card() returned to
the caller.  I changed _Thread_Start_multitasking() to a no-return function
recently since it simplified some things.  I didn't touch the low-level start
code of the BSPs to eliminate some bytes of dead code, but it should go away
step by step.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
