Check submission script
Tue Jun 10 12:32:03 UTC 2014
On Tue, Jun 10, 2014 at 2:51 AM, Sebastian Huber
> Hello,
> the check submission script
> http://git.rtems.org/rtems-testing/tree/merge-helpers/check_submission
> contains a test for timing values
>   # Hopefully have some output from the tmtests
>   echo "=== Checking for timing information"
>   c=$(ls -1 times* 2>/dev/null | wc -l)
>   if [[ ${c} -eq 0 ]]; then
>     echo "Please run the timing tests and include the results."
>   fi
> Is it really useful to add such timing values to the sources?  They may be
> out of date right with the next commit.
I agree. The only place timing results make sense is for a release.
Using the tmtests can also be important when making changes in
supercore, but that is less often done and should be better handled by
the developer/tester.
-Gedare
> rtems-devel mailing list
> rtems-devel at rtems.org
