Re: 回复:Re: The design of vCPU.
Thu Jun 12 14:47:33 UTC 2014
On Thu, Jun 12, 2014 at 10:34 AM, shenyouren <shenyouren at gmail.com> wrote:
> Philipp Eppelt <philipp.eppelt at mailbox.tu-dresden.de>于 2014年6月12日 下午9:50写道:
>> Hi,
>> can you please evaluate, which pieces already implemented in
>> pok/kernel/* can be reused to build the vCPU structure?
> I don't think there are lot of code which can be reused. The vCPU is a new
> concept in POK. I can only figure out that the context store/resume function
> can be reused.
It seems to me that most of the code related to partitions within pok
should be reused for the vCPU concept, since there is little
difference right now between a vCPU and a partition.
-Gedare
>> Also, how the vCPU structure can be build on top of / merged into the
>> partition structure.
> I think we can put a point on vCPU structure, a point point to partition
> bond with the vCPU.
> This vCPU structure, as you said do not need SMP for now, and a partition is
> a vCPU(I understand this as we do not need scheduler for vCPU now), is just
> a structure for interrupt store, also maybe for the context store.
> If my understanding is correct, the implementation of vCPU is a realistic
> target for midterm.
> Best Regards.
> Youren Shen.
> 发自我的小米手机
