[PATCH 4/6] score: Decouple thread and scheduler nodes on SMP
Fri Jun 13 15:50:33 UTC 2014
On Fri, Jun 13, 2014 at 10:37 AM, Sebastian Huber
> Add a chain node to the scheduler node to decouple the thread and
> scheduler nodes.  It is now possible to enqueue a thread in a thread
> wait queue and use its scheduler node at the same for other threads,
> e.g. a resouce owner.
>  cpukit/score/include/rtems/score/scheduler.h       |   19 ++-
>  cpukit/score/include/rtems/score/schedulerimpl.h   |   22 ++
>  .../include/rtems/score/schedulerprioritysmpimpl.h |   48 ++--
>  .../score/include/rtems/score/schedulersimplesmp.h |    8 +-
>  cpukit/score/include/rtems/score/schedulersmp.h    |    5 +
>  .../score/include/rtems/score/schedulersmpimpl.h   |  251 +++++++++++---------
>  cpukit/score/src/schedulerpriorityaffinitysmp.c    |  175 +++++++-------
>  cpukit/score/src/schedulerprioritysmp.c            |   43 ++--
>  cpukit/score/src/schedulersimplesmp.c              |   98 +++++----
>  cpukit/score/src/schedulersmpstartidle.c           |    2 +-
>  10 files changed, 392 insertions(+), 279 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
> index 542e4ae..918c6df 100644
> --- a/cpukit/score/include/rtems/score/scheduler.h
> +++ b/cpukit/score/include/rtems/score/scheduler.h
> @@ -165,7 +165,24 @@ struct Scheduler_Control {
>   * @brief Scheduler node for per-thread data.
>  struct Scheduler_Node {
> -  /* No fields yet */
> +#if defined(RTEMS_SMP)
> +   * @brief Chain node for usage in various scheduler data structures.
> +   * Strictly this is the wrong place for this field since the data structures
> +   * to manage scheduler nodes belong to the particular scheduler
> +   * implementation.  Currently all SMP scheduler implementations use chains.
> +   * The node is here to simplify things, just like the object node in the
> +   * thread control block.  It may be replaced with a union to add a red-black
> +   * tree node in the future.
> +  Chain_Node Node;
> +   * @brief The thread owning this node.
> +  Thread_Control *owner;
> +#endif
> diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
> index 364c658..391a8d7 100644
> --- a/cpukit/score/include/rtems/score/schedulerimpl.h
> +++ b/cpukit/score/include/rtems/score/schedulerimpl.h
> @@ -652,6 +652,28 @@ RTEMS_INLINE_ROUTINE Scheduler_Node *_Scheduler_Node_get(
>    return the_thread->Scheduler.node;
> +RTEMS_INLINE_ROUTINE void _Scheduler_Node_do_initialize(
I'd just use "Node_initialize".
> diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h b/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
> index d3e2106..8671035 100644
> --- a/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
> +++ b/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
> @@ -26,6 +26,7 @@
>  #include <rtems/score/schedulerprioritysmp.h>
>  #include <rtems/score/schedulerpriorityimpl.h>
>  #include <rtems/score/schedulersimpleimpl.h>
> +#include <rtems/score/schedulersmpimpl.h>
>  #ifdef __cplusplus
>  extern "C" {
> @@ -50,26 +51,25 @@ static inline Scheduler_priority_SMP_Node *_Scheduler_priority_SMP_Node_get(
>    return (Scheduler_priority_SMP_Node *) _Scheduler_Node_get( thread );
> -static Scheduler_priority_SMP_Node *_Scheduler_priority_SMP_Node_downcast(
> -  Scheduler_Node *node
> +static inline Scheduler_priority_SMP_Node *
> +_Scheduler_priority_SMP_Node_downcast( Scheduler_Node *node )
>    return (Scheduler_priority_SMP_Node *) node;
Is there a reason not to just cast it where it is used?
>  static inline void _Scheduler_priority_SMP_Insert_ready_lifo(
>    Scheduler_Context *context,
> -  Thread_Control *thread
> +  Scheduler_Node    *thread
It's no longer a thread, I'd change the parameter name. Repeated a few times.
> diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
> index f5ab8cf..f1dcacd 100644
> --- a/cpukit/score/src/schedulerpriorityaffinitysmp.c
> +++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
> @@ -134,28 +137,34 @@ static inline void _Scheduler_SMP_Allocate_processor_exact(
>   * the highest ready thread must have affinity such that it can
>   * be executed on the victim's processor.
> -static Thread_Control *_Scheduler_priority_affinity_SMP_Get_highest_ready(
> +static Scheduler_Node *_Scheduler_priority_affinity_SMP_Get_highest_ready(
> -  Thread_Control    *victim
> +  Scheduler_Node    *victim
> -  Scheduler_priority_SMP_Context *self =
> +  Scheduler_priority_SMP_Context       *self =
>      _Scheduler_priority_SMP_Get_self( context );
> -  Priority_Control                index;
> -  Thread_Control                 *highest = NULL;
> -  int                             victim_cpu;
> +  Priority_Control                      index;
> +  Scheduler_Node                       *highest = NULL;
> +  Thread_Control                       *victim_thread;
> +  uint32_t                              victim_cpu_index;
> +  Scheduler_priority_affinity_SMP_Node *node;
>     * This is done when we need to check if reevaluations are needed.
>    if ( victim == NULL ) {
> -    return _Scheduler_priority_Ready_queue_first(
> +    node = (Scheduler_priority_affinity_SMP_Node *)
> +      _Scheduler_priority_Ready_queue_first(
>          &self->Bit_map,
>          &self->Ready[ 0 ]
> +    return &node->Base.Base.Base;
This Base.Base.Base is quite awkward and not at all clear what it
means. Shouldn't this be using a downcast() function? Repeated a few
times.
-Gedare
