[PATCH] score: Fix thread deletion on SMP
Sebastian Huber
Wed Jun 18 13:23:27 UTC 2014
All blocking operations using _Thread_Get() in the corresponding release
operation must check for thread termination after
_Thread_Disable_dispatch() on SMP.
cpukit/rtems/src/eventreceive.c | 7 +
cpukit/rtems/src/systemeventreceive.c | 7 +
cpukit/rtems/src/tasksuspend.c | 6 +
testsuites/smptests/smpthreadlife01/init.c | 169 ++++++++++++++++++--
.../smptests/smpthreadlife01/smpthreadlife01.doc | 6 +
5 files changed, 182 insertions(+), 13 deletions(-)
diff --git a/cpukit/rtems/src/eventreceive.c b/cpukit/rtems/src/eventreceive.c
index 49fdb2a..0ff350f 100644
--- a/cpukit/rtems/src/eventreceive.c
+++ b/cpukit/rtems/src/eventreceive.c
@@ -22,6 +22,7 @@
+#include <rtems/score/threadimpl.h>
rtems_status_code rtems_event_receive(
rtems_event_set event_in,
@@ -39,6 +40,12 @@ rtems_status_code rtems_event_receive(
if ( !_Event_sets_Is_empty( event_in ) ) {
_Thread_Disable_dispatch();
+#if defined(RTEMS_SMP)
+ if ( _Thread_Is_life_terminating( executing->Life.state ) ) {
+ _Thread_Enable_dispatch();
+ _Assert_Not_reached();
+#endif
_Event_Seize(
event_in,
option_set,
diff --git a/cpukit/rtems/src/systemeventreceive.c b/cpukit/rtems/src/systemeventreceive.c
index c24e19a..c38962d 100644
--- a/cpukit/rtems/src/systemeventreceive.c
+++ b/cpukit/rtems/src/systemeventreceive.c
@@ -28,6 +28,7 @@
rtems_status_code rtems_event_system_receive(
@@ -45,6 +46,12 @@ rtems_status_code rtems_event_system_receive(
+#endif
_Event_Seize(
event_in,
option_set,
diff --git a/cpukit/rtems/src/tasksuspend.c b/cpukit/rtems/src/tasksuspend.c
index f8c43a7..24f60fd 100644
--- a/cpukit/rtems/src/tasksuspend.c
+++ b/cpukit/rtems/src/tasksuspend.c
@@ -32,6 +32,12 @@ rtems_status_code rtems_task_suspend(
switch ( location ) {
case OBJECTS_LOCAL:
+ if ( _Thread_Is_life_terminating( the_thread->Life.state ) ) {
+ _Objects_Put( &the_thread->Object );
+#endif
if ( !_States_Is_suspended( the_thread->current_state ) ) {
_Thread_Suspend( the_thread );
diff --git a/testsuites/smptests/smpthreadlife01/init.c b/testsuites/smptests/smpthreadlife01/init.c
index 65d8709..2d0cce5 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -45,6 +45,11 @@ static test_context test_instance = {
.worker_barrier_state = SMP_BARRIER_STATE_INITIALIZER
+static void barrier(test_context *ctx, SMP_barrier_State *state)
+ _SMP_barrier_Wait(&ctx->barrier, state, CPU_COUNT);
static void restart_extension(
Thread_Control *executing,
Thread_Control *restarted
@@ -74,7 +79,10 @@ static void switch_extension(Thread_Control *executing, Thread_Control *heir)
if (ctx->delay_switch_for_executing == executing) {
ctx->delay_switch_for_executing = NULL;
- _SMP_barrier_Wait(&ctx->barrier, &ctx->worker_barrier_state, CPU_COUNT);
+ /* (A) */
+ barrier(ctx, &ctx->worker_barrier_state);
rtems_counter_delay_nanoseconds(100000000);
/* Avoid bad profiling statisitics */
@@ -90,7 +98,8 @@ static void worker_task(rtems_task_argument arg)
ctx->worker_arg = arg;
+ /* (B) */
while (true) {
/* Do nothing */
@@ -120,7 +129,8 @@ static void test_restart(void)
sc = rtems_task_start(id, worker_task, 0);
rtems_test_assert(sc == RTEMS_SUCCESSFUL);
- _SMP_barrier_Wait(&ctx->barrier, &ctx->main_barrier_state, CPU_COUNT);
+ /* (B) */
+ barrier(ctx, &ctx->main_barrier_state);
for (arg = 1; arg < 23; ++arg) {
ctx->main_arg = arg;
@@ -129,7 +139,8 @@ static void test_restart(void)
sc = rtems_task_restart(id, arg);
+ /* (B) */
rtems_test_assert(ctx->worker_arg == arg);
@@ -168,7 +179,8 @@ static void test_delete(void)
sc = rtems_task_start(id, worker_task, arg);
+ /* (B) */
rtems_test_assert(!ctx->terminated);
@@ -190,7 +202,8 @@ static void delay_ipi_task(rtems_task_argument variant)
_ISR_Disable_without_giant(level);
(void) level;
+ /* (C) */
* Interrupts are disabled, so the inter-processor interrupt deleting us will
@@ -237,7 +250,8 @@ static void test_set_life_protection(rtems_task_argument variant)
sc = rtems_task_start(id, delay_ipi_task, variant);
+ /* (C) */
sc = rtems_task_delete(id);
@@ -256,7 +270,8 @@ static void delay_switch_task(rtems_task_argument arg)
ctx->delay_switch_for_executing = _Thread_Get_executing();
+ /* (D) */
sc = rtems_task_delete(RTEMS_SELF);
@@ -284,11 +299,11 @@ static void test_wait_for_execution_stop(void)
sc = rtems_task_start(id, delay_switch_task, 0);
- /* Wait for delay switch task */
+ /* (D) */
- /* Wait for delay switch extension */
+ /* (A) */
sc = rtems_task_create(
rtems_build_name('W', 'A', 'I', 'T'),
@@ -306,6 +321,131 @@ static void test_wait_for_execution_stop(void)
rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
+static void suspend_task(rtems_task_argument arg)
+ test_context *ctx = &test_instance;
+ ISR_Level level;
+ _ISR_Disable_without_giant(level);
+ (void) level;
+ /* (E) */
+ /* (F) */
+ rtems_task_suspend(RTEMS_SELF);
+ rtems_test_assert(0);
+static void event_task(rtems_task_argument arg)
+ ISR_Level level;
+ rtems_event_set events;
+ (void) level;
+ /* (E) */
+ /* (F) */
+ rtems_event_receive(
+ RTEMS_EVENT_0,
+ RTEMS_EVENT_ALL | RTEMS_WAIT,
+ RTEMS_NO_TIMEOUT,
+ &events
+static void system_event_task(rtems_task_argument arg)
+ ISR_Level level;
+ (void) level;
+ /* (E) */
+ /* (F) */
+ rtems_event_system_receive(
+ RTEMS_EVENT_0,
+ RTEMS_NO_TIMEOUT,
+ &events
+static void help_task(rtems_task_argument arg)
+ /* (F) */
+static void test_operation_with_delete_in_progress(rtems_task_entry entry)
+ rtems_status_code sc;
+ rtems_id worker_id;
+ rtems_id help_id;
+ rtems_resource_snapshot snapshot;
+ rtems_resource_snapshot_take(&snapshot);
+ sc = rtems_task_create(
+ rtems_build_name('W', 'O', 'R', 'K'),
+ 1,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &worker_id
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_start(worker_id, entry, 0);
+ /* (E) */
+ rtems_build_name('H', 'E', 'L', 'P'),
+ 2,
+ &help_id
+ sc = rtems_task_start(help_id, help_task, 0);
+ sc = rtems_task_delete(worker_id);
+ sc = rtems_task_delete(help_id);
+ rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
static void Init(rtems_task_argument arg)
TEST_BEGIN();
@@ -316,6 +456,9 @@ static void Init(rtems_task_argument arg)
test_set_life_protection(0);
test_set_life_protection(1);
test_wait_for_execution_stop();
+ test_operation_with_delete_in_progress(suspend_task);
+ test_operation_with_delete_in_progress(event_task);
+ test_operation_with_delete_in_progress(system_event_task);
TEST_END();
@@ -329,7 +472,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
-#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TASKS (CPU_COUNT + 1)
#define CONFIGURE_INITIAL_EXTENSIONS \
diff --git a/testsuites/smptests/smpthreadlife01/smpthreadlife01.doc b/testsuites/smptests/smpthreadlife01/smpthreadlife01.doc
index 54fb858..818284d 100644
--- a/testsuites/smptests/smpthreadlife01/smpthreadlife01.doc
+++ b/testsuites/smptests/smpthreadlife01/smpthreadlife01.doc
@@ -7,6 +7,9 @@ directives:
- rtems_task_restart()
- _Thread_Set_life_protection()
- _Thread_Wait_for_execution_stop()
+ - rtems_task_suspend()
+ - rtems_event_receive()
+ - rtems_event_system_receive()
concepts:
@@ -14,3 +17,6 @@ concepts:
- Ensure that a _Thread_Set_life_protection() works on SMP in case interrupt
processing is delayed.
- Ensure that _Thread_Wait_for_execution_stop() works on SMP.
+ - Ensure that rtems_task_suspend(), rtems_event_receive() and
+ rtems_event_system_receive() aborts in case a thread deletion is in
+ progress on SMP.
1.7.7
