[PATCH 1/2] bsps/xtratum: New BSP
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Jun 18 14:50:11 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
It is necessary that the environment variable XTRATUM_PATH is set to the
XtratuM installation path, e.g.
XTRATUM_PATH="/opt/xtratum/xm"
By default the example_xm_cf.xml will be used for building the tests.
It can be overwritten with setting the XTRATUM_CONFIG environment
variable to another XML file, e.g.
XTRATUM_CONFIG="/some/path/to/rtems_xm_cf.xml"
 c/src/lib/libbsp/shared/include/fatal.h            |    8 +-
 c/src/lib/libbsp/sparc/acinclude.m4                |    2 +
 c/src/lib/libbsp/sparc/shared/cpu.c                |    5 +
 c/src/lib/libbsp/sparc/shared/irq_asm.S            |   97 ++++++++++++++++
 c/src/lib/libbsp/sparc/shared/start/start.S        |   65 ++++++++++-
 .../lib/libbsp/sparc/shared/startup/linkcmds.base  |   19 +++
 c/src/lib/libbsp/sparc/xtratum/Makefile.am         |  115 +++++++++++++++++++
 c/src/lib/libbsp/sparc/xtratum/README              |   56 +++++++++
 c/src/lib/libbsp/sparc/xtratum/bsp_specs           |   17 +++
 c/src/lib/libbsp/sparc/xtratum/clock/clock-gpt.c   |  120 ++++++++++++++++++++
 .../sparc/xtratum/clock/clock-xtratum-exec.c       |   23 ++++
 .../libbsp/sparc/xtratum/clock/clock-xtratum-hw.c  |   21 ++++
 .../lib/libbsp/sparc/xtratum/clock/clock-xtratum.h |   94 +++++++++++++++
 c/src/lib/libbsp/sparc/xtratum/configure.ac        |   33 ++++++
 .../libbsp/sparc/xtratum/console/console-config.c  |   27 +++++
 .../libbsp/sparc/xtratum/console/printk-support.c  |   28 +++++
 .../sparc/xtratum/console/xtratum-hyper-console.c  |   71 ++++++++++++
 c/src/lib/libbsp/sparc/xtratum/include/bsp.h       |  117 +++++++++++++++++++
 c/src/lib/libbsp/sparc/xtratum/include/cache_.h    |  113 ++++++++++++++++++
 c/src/lib/libbsp/sparc/xtratum/include/irq.h       |    2 +
 c/src/lib/libbsp/sparc/xtratum/include/tm27.h      |   30 +++++
 .../sparc/xtratum/include/xtratum-hyper-console.h  |   30 +++++
 c/src/lib/libbsp/sparc/xtratum/include/xtratum.h   |   87 ++++++++++++++
 c/src/lib/libbsp/sparc/xtratum/irq/irq.c           |   90 +++++++++++++++
 .../libbsp/sparc/xtratum/make/custom/xtratum.cfg   |   55 +++++++++
 c/src/lib/libbsp/sparc/xtratum/preinstall.am       |  115 +++++++++++++++++++
 c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c  |   52 +++++++++
 c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c    |  105 +++++++++++++++++
 c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c  |   53 +++++++++
 .../libbsp/sparc/xtratum/startup/example_xm_cf.xml |   69 +++++++++++
 .../lib/libbsp/sparc/xtratum/startup/isr-en-dis.S  |   50 ++++++++
 .../libbsp/sparc/xtratum/startup/linkcmds.xtratum  |   23 ++++
 c/src/lib/libbsp/sparc/xtratum/startup/psr.c       |   26 ++++
 c/src/lib/libbsp/sparc/xtratum/startup/setvec.c    |   61 ++++++++++
 c/src/lib/libbsp/sparc/xtratum/startup/spurious.c  |   35 ++++++
 c/src/lib/libbsp/sparc/xtratum/startup/tbr.c       |   30 +++++
 c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c          |   36 ++++++
 testsuites/smptests/smpfatal08/init.c              |    3 +-
 38 files changed, 1977 insertions(+), 6 deletions(-)
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/Makefile.am
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/README
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/bsp_specs
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-gpt.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-exec.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-hw.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum.h
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/configure.ac
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/console-config.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/printk-support.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/xtratum-hyper-console.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/bsp.h
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/cache_.h
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/irq.h
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/tm27.h
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/xtratum-hyper-console.h
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/xtratum.h
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/irq/irq.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/make/custom/xtratum.cfg
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/preinstall.am
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/example_xm_cf.xml
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/isr-en-dis.S
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/linkcmds.xtratum
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/psr.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/setvec.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/tbr.c
 create mode 100644 c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c
diff --git a/c/src/lib/libbsp/shared/include/fatal.h b/c/src/lib/libbsp/shared/include/fatal.h
index e928bba..4f18fc9 100644
--- a/c/src/lib/libbsp/shared/include/fatal.h
+++ b/c/src/lib/libbsp/shared/include/fatal.h
@@ -101,7 +101,13 @@ typedef enum {
   PPC_FATAL_EXCEPTION_INITIALIZATION = BSP_FATAL_CODE_BLOCK(7),
   /* Libchip fatal codes */
-  DWMAC_FATAL_TOO_MANY_RBUFS_CONFIGURED = BSP_FATAL_CODE_BLOCK(8)
+  DWMAC_FATAL_TOO_MANY_RBUFS_CONFIGURED = BSP_FATAL_CODE_BLOCK(8),
+  /* XtratuM fatal codes */
+  XTRATUM_FATAL_CLOCK_IRQ_INSTALL = BSP_FATAL_CODE_BLOCK(9),
+  XTRATUM_FATAL_CPU_SMP_INITIALIZE,
+  XTRATUM_FATAL_SET_TBR_NOT_IMPLEMENTED,
+  XTRATUM_FATAL_GPT_CLOCK_IRQ_INSTALL,
 } bsp_fatal_code;
 RTEMS_COMPILER_NO_RETURN_ATTRIBUTE static inline void
diff --git a/c/src/lib/libbsp/sparc/acinclude.m4 b/c/src/lib/libbsp/sparc/acinclude.m4
index 4d40305..0e053fa 100644
--- a/c/src/lib/libbsp/sparc/acinclude.m4
+++ b/c/src/lib/libbsp/sparc/acinclude.m4
@@ -8,6 +8,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
     AC_CONFIG_SUBDIRS([leon2]);;
   leon3 )
     AC_CONFIG_SUBDIRS([leon3]);;
+  xtratum )
+    AC_CONFIG_SUBDIRS([xtratum]);;
     AC_MSG_ERROR([Invalid BSP]);;
   esac
diff --git a/c/src/lib/libbsp/sparc/shared/cpu.c b/c/src/lib/libbsp/sparc/shared/cpu.c
index 12d3475..1856646 100644
--- a/c/src/lib/libbsp/sparc/shared/cpu.c
+++ b/c/src/lib/libbsp/sparc/shared/cpu.c
@@ -14,6 +14,7 @@
 #include <rtems/score/cpu.h>
+#include <bspopts.h>
  *  This initializes the set of opcodes placed in each trap
@@ -29,7 +30,11 @@
 const CPU_Trap_table_entry _CPU_Trap_slot_template = {
+#if defined(RTEMS_PARAVIRT_XTRATUM)
+  0x01000000,      /* nop                       */
+#else /* RTEMS_PARAVIRT_XTRATUM */
   0xa1480000,      /* mov   %psr, %l0           */
+#endif /* RTEMS_PARAVIRT_XTRATUM */
   0x29000000,      /* sethi %hi(_handler), %l4  */
   0x81c52000,      /* jmp   %l4 + %lo(_handler) */
   0xa6102000       /* mov   _vector, %l3        */
diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
index bf2dca9..69522a2 100644
--- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
+++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
@@ -23,6 +23,10 @@
+#ifdef RTEMS_PARAVIRT_XTRATUM
+#include <xm.h>
  *  void _CPU_Context_switch(
  *    Context_Control  *run,
@@ -54,7 +58,15 @@ SYM(_CPU_Context_switch):
         ld      [%g6 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE], %o4
         ! save it a bit later so we do not waste a couple of cycles
+        mov     %o0, %l6
+        mov     sparc_get_psr_nr, %o0
+        __XM_AHC
+        mov     %o0, %o2
+        mov     %l6, %o0
         rd      %psr, %o2
         st      %o2, [%o0 + PSR_OFFSET]      ! save status register
         ! Now actually save ISR stack nesting prevention flag
@@ -110,6 +122,23 @@ SYM(_CPU_Context_restore_heir):
                                               ! g1 = psr w/o cwp
         andn    %g1, SPARC_PSR_ET_MASK | SPARC_PSR_CWP_MASK, %g1
         or      %g1, %g3, %g1                 ! g1 = heirs psr
+        mov     %o0, %g2
+        mov     %o1, %g5
+        mov     sparc_flush_regwin_nr, %o0
+        __XM_AHC
+        or      %g1, SPARC_PSR_ET_MASK, %g1
+        mov     sparc_set_psr_nr, %o0
+        mov     %g1, %o1
+       __XM_AHC
+        mov     %g2, %o0
+        mov     %g5, %o1
         mov     %g1, %psr                     ! restore status register and
                                               ! **** DISABLE TRAPS ****
         mov     %wim, %g2                     ! g2 = wim
@@ -163,6 +192,8 @@ done_flushing:
         nop
         nop
 #if defined(RTEMS_SMP)
         ! The executing context no longer executes on this processor
         stb     %g0, [%o0 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
@@ -216,7 +247,14 @@ done_flushing:
         PUBLIC(_CPU_Context_restore)
 SYM(_CPU_Context_restore):
         save    %sp, -CPU_MINIMUM_STACK_FRAME_SIZE, %sp
+        __XM_AHC
+        mov     %o0, %o2
         rd      %psr, %o2
 	! On SPARC the restore path needs also a valid executing context on SMP
 	! to update the is executing indicator.
@@ -268,6 +306,7 @@ win_ovflow:
         mov     %g4, %l4                 ! save the globals this block uses
         mov     %g5, %l5
+#ifndef RTEMS_PARAVIRT_XTRATUM
          *  When at a "window overflow" trap, (wim == (1 << cwp)).
          *  If we get here like that, then process a window overflow.
@@ -324,6 +363,7 @@ win_ovflow:
         restore
         nop
 dont_do_the_window:
@@ -432,7 +472,14 @@ dont_switch_stacks:
 dont_fix_pil:
         or       %g5, SPARC_PSR_PIL_MASK, %g5
 pil_fixed:
+        mov     %g5, %o1
+        or      %o1, SPARC_PSR_ET_MASK, %o1
+        __XM_AHC
         wr       %g5, SPARC_PSR_ET_MASK, %psr ! **** ENABLE TRAPS ****
 dont_fix_pil2:
@@ -476,8 +523,14 @@ profiling_not_outer_most_exit:
          *  NOTE: %l0 has the PSR which was in place when we took the trap.
+        mov     %l0, %o1
+        __XM_AHC
         mov      %l0, %psr             ! **** DISABLE TRAPS ****
         nop; nop; nop
          *  Decrement ISR nest level and Thread dispatch disable level.
@@ -538,10 +591,16 @@ profiling_not_outer_most_exit:
         sub      %fp, CPU_MINIMUM_STACK_FRAME_SIZE, %sp
         or      %l0, SPARC_PSR_ET_MASK, %l7    ! l7 = PSR with ET=1
+        mov     %l7, %o1
+        __XM_AHC
         mov     %l7, %psr                      !  **** ENABLE TRAPS ****
         nop
         nop
         nop
 isr_dispatch:
         call    SYM(_Thread_Dispatch), 0
         nop
@@ -554,8 +613,15 @@ isr_dispatch:
 	 *  with the register windowing.  In particular, the CWP in the PSR
 	 *  is fragile during this period. (See PR578.)
+        mov %o0, %g1
+        set sparc_set_pil_nr, %o0
+        __XM_AHC
+        mov %g1, %o0
 	mov	2,%g1				! syscall (disable interrupts)
 	ta	0				! syscall (disable interrupts)
          *  While we had ISR dispatching disabled in this thread,
@@ -571,8 +637,15 @@ isr_dispatch:
         ! Yes, then invoke the dispatcher
 dispatchAgain:
+        mov %o0, %g1
+        set sparc_clear_pil_nr, %o0
+        __XM_AHC
+        mov %g1, %o0
 	mov	3,%g1				! syscall (enable interrupts)
 	ta	0				! syscall (enable interrupts)
         ba      isr_dispatch
         nop
@@ -596,12 +669,23 @@ simple_return:
         ldd     [%fp + ISF_PSR_OFFSET], %l0    ! restore psr, PC
         ld      [%fp + ISF_NPC_OFFSET], %l2    ! restore nPC
+        __XM_AHC
+        mov %o0, %l3
         rd      %psr, %l3
         and     %l3, SPARC_PSR_CWP_MASK, %l3   ! want "current" CWP
         andn    %l0, SPARC_PSR_CWP_MASK, %l0   ! want rest from task
         or      %l3, %l0, %l0                  ! install it later...
         andn    %l0, SPARC_PSR_ET_MASK, %l0
+        mov     sparc_ctrl_winflow_nr, %o0
+        __XM_AHC
          *  Restore tasks global and out registers
@@ -618,6 +702,7 @@ simple_return:
         ldd     [%fp + ISF_I4_OFFSET], %i4    ! restore i4, i5
         ldd     [%fp + ISF_I6_FP_OFFSET], %i6 ! restore i6/fp, i7
          *  Registers:
@@ -680,14 +765,26 @@ simple_return:
         ldd     [%g1 + CPU_STACK_FRAME_I6_FP_OFFSET], %i6
                                            ! reload of sp clobbers ISF
         save                               ! Back to ISR dispatch window
 good_task_window:
+        mov     %l0, %o1
+        __XM_AHC
 	nop; nop; nop
                                            !  and restore condition codes.
         ld      [%g1 + ISF_G1_OFFSET], %g1 ! restore g1
+        mov sparc_iret_nr, %o0
+        __XM_AHC
         jmp     %l1                        ! transfer control and
         rett    %l2                        ! go back to tasks window
 /* end of file */
diff --git a/c/src/lib/libbsp/sparc/shared/start/start.S b/c/src/lib/libbsp/sparc/shared/start/start.S
index 070387f..43e64f7 100644
--- a/c/src/lib/libbsp/sparc/shared/start/start.S
+++ b/c/src/lib/libbsp/sparc/shared/start/start.S
@@ -19,8 +19,13 @@
-#if defined(RTEMS_SMP) && defined(BSP_LEON3_SMP)
-  #define START_LEON3_ENABLE_SMP
+#include <xm.h>
+#endif
+#if defined(RTEMS_SMP) && \
+    (defined(BSP_LEON3_SMP) || defined(RTEMS_PARAVIRT_XTRATUM))
+  #define START_ON_SECONDARY_PROCESSOR
 #endif
@@ -72,8 +77,13 @@ SYM(trap_table):
   BAD_TRAP;                                     ! 02 illegal instruction
   BAD_TRAP;                                     ! 03 privileged instruction
   BAD_TRAP;                                     ! 04 fp disabled
+  BAD_TRAP;                                     ! 05 window overflow
+  BAD_TRAP;                                     ! 06 window underflow
   TRAP( 5, SYM(window_overflow_trap_handler) ); ! 05 window overflow
   TRAP( 6, SYM(window_underflow_trap_handler) );! 06 window underflow
   BAD_TRAP;                                     ! 07 memory address not aligned
   BAD_TRAP;                                     ! 08 fp exception
   BAD_TRAP;                                     ! 09 data access exception
@@ -165,9 +175,17 @@ SYM(CLOCK_SPEED):
    *        installed before.
+  SOFT_TRAP;
   SYSCALL_TRAP( 0x80, SYM(syscall) );		! 80 syscall SW trap
   SOFT_TRAP; SOFT_TRAP;  	            	! 81 - 82
+  SOFT_TRAP;
   TRAP( 0x83, SYM(window_flush_trap_handler) ); ! 83 flush windows SW trap
   SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 84 - 87
   SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 88 - 8B
@@ -214,6 +232,25 @@ SYM(hard_reset):
 /* Common initialisation */
+        /* Set up a valid stack */
+        set     SYM(_RAM_START), %l1
+        set     SYM(_RAM_SIZE), %l2
+        add     %l1, %l2, %sp
+        mov     %g1, %g7
+        /* Initialize TBR */
+        set     sparc_write_tbr_nr, %o0
+        set     trap_table, %o1
+        __XM_HC
+        /* Enable traps */
+        __XM_AHC
+        or      %o0, SPARC_PSR_ET_MASK, %o1
+        __XM_AHC
         set     SYM(trap_table), %g1    ! Initialize TBR
         mov     %g1, %tbr
@@ -230,13 +267,19 @@ SYM(hard_reset):
         nop
         nop
         nop
 	sethi	%hi(_Per_CPU_Information), %g6 ! get per-CPU control
 	add	%g6, %lo(_Per_CPU_Information), %g6
-#if defined(START_LEON3_ENABLE_SMP)
+#if defined(START_ON_SECONDARY_PROCESSOR)
+        set get_vcpuid_nr, %o0          ! get virtual CPU identifier
+	__XM_HC
+#else
 	rd	%asr17, %o0		! get CPU identifier
 	srl	%o0, LEON3_ASR17_PROCESSOR_INDEX_SHIFT, %o0
+#endif
 	cmp	%o0, 0
 	beq	cpu0
@@ -250,6 +293,13 @@ SYM(hard_reset):
 	andn	%sp, 0x0f, %sp		! align stack on 16-byte boundary
 	mov	%sp, %fp		! set frame pointer
+        mov     %g7, %o0
+        call    init_libxm              ! initialize libxm
+         sub     %sp, 0x60, %sp
+        add     %sp, 0x60, %sp
 	call	SYM(bsp_start_on_secondary_processor) ! does not return
 	 sub	%sp, CPU_MINIMUM_STACK_FRAME_SIZE, %sp
 	ba	SYM(bsp_reset)		! just in case
@@ -363,12 +413,19 @@ zerobss:
         bleu,a zerobss
         nop
+        mov     %g7, %o0
         mov     %0, %o0                 ! command line
         call    SYM(boot_card)
         sub     %sp, 0x60, %sp          ! room for boot_card to save args
         nop
-#if !defined(START_LEON3_ENABLE_SMP)
+#if !defined(START_ON_SECONDARY_PROCESSOR)
         PUBLIC(BSP_fatal_return)
         PUBLIC(bsp_reset)
 SYM(BSP_fatal_return):
diff --git a/c/src/lib/libbsp/sparc/shared/startup/linkcmds.base b/c/src/lib/libbsp/sparc/shared/startup/linkcmds.base
index c09e1c6..3d6eebd 100644
--- a/c/src/lib/libbsp/sparc/shared/startup/linkcmds.base
+++ b/c/src/lib/libbsp/sparc/shared/startup/linkcmds.base
@@ -106,6 +106,15 @@ SECTIONS
     *(.shdata)
     . = ALIGN (16);
   } > ram
+   * Special section for XtratuM hypervisor.  It must have exactly this name and
+   * content.
+  .xmImageHdr : {
+    KEEP (*(.xmImageHdr))
+  } > ram
   .tdata : {
     _TLS_Data_begin = .;
     *(.tdata .tdata.* .gnu.linkonce.td.*)
@@ -178,6 +187,16 @@ SECTIONS
     *(.shbss)
   } > ram
+   * Special section for read-write data which will be not zero initialized by
+   * the BSS loop.
+  .rwextra :
+    *(.bsp_rwextra)
+  } > ram
   .bss :
     __bss_start = ALIGN(0x8);
diff --git a/c/src/lib/libbsp/sparc/xtratum/Makefile.am b/c/src/lib/libbsp/sparc/xtratum/Makefile.am
new file mode 100644
index 0000000..a772def
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/Makefile.am
@@ -0,0 +1,115 @@
+ACLOCAL_AMFLAGS = -I ../../../../aclocal
+include $(top_srcdir)/../../../../automake/compile.am
+include_bspdir = $(includedir)/bsp
+dist_project_lib_DATA = bsp_specs
+include_HEADERS = include/bsp.h
+include_HEADERS += include/tm27.h
+include_HEADERS += ../../sparc/shared/include/debug_defs.h
+include_bsp_HEADERS =
+nodist_include_HEADERS = include/bspopts.h
+nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
+DISTCLEANFILES = include/bspopts.h
+noinst_PROGRAMS =
+include_HEADERS += include/xtratum.h
+include_HEADERS += ../../shared/include/coverhd.h
+noinst_LIBRARIES = libbspstart.a
+CPPFLAGS += -I$(XTRATUM_PATH)/include -D"__XM_INCFLD(_fld)=<xm_inc/_fld>"
+libbspstart_a_SOURCES = ../../sparc/shared/start/start.S
+project_lib_DATA = start.$(OBJEXT)
+dist_project_lib_DATA += ../shared/startup/linkcmds.base
+dist_project_lib_DATA += startup/linkcmds
+dist_project_lib_DATA += startup/linkcmds.xtratum
+dist_project_lib_DATA += startup/example_xm_cf.xml
+noinst_LIBRARIES += libbsp.a
+libbsp_a_SOURCES =
+libbsp_a_LIBADD =
+libbsp_a_CPPFLAGS =
+libbsp_a_CPPFLAGS += -I$(XTRATUM_PATH)/include -D"__XM_INCFLD(_fld)=<xm_inc/_fld>"
+# XtratuM header
+libbsp_a_SOURCES += xm/xmhdr.c
+# startup
+libbsp_a_SOURCES += ../../shared/bspclean.c
+libbsp_a_SOURCES += ../../shared/bsplibc.c
+libbsp_a_SOURCES += ../../shared/bsppost.c
+libbsp_a_SOURCES += ../../shared/bootcard.c
+libbsp_a_SOURCES += startup/bspstart.c
+libbsp_a_SOURCES += ../../sparc/shared/startup/bspgetworkarea.c
+libbsp_a_SOURCES += ../../shared/sbrk.c
+libbsp_a_SOURCES += ../../shared/bspinit.c
+libbsp_a_SOURCES += startup/isr-en-dis.S
+libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
+libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
+libbsp_a_SOURCES += startup/psr.c
+libbsp_a_SOURCES += startup/tbr.c
+libbsp_a_SOURCES += startup/setvec.c
+libbsp_a_SOURCES += startup/spurious.c
+libbsp_a_SOURCES += ../../shared/timerstub.c
+libbsp_a_SOURCES += startup/bspreset.c
+if HAS_SMP
+libbsp_a_SOURCES += startup/bspsmp.c
+endif
+# ISR Handler
+libbsp_a_SOURCES += ../../sparc/shared/cpu.c
+libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
+# AMBA bus
+include_HEADERS += ../../sparc/shared/include/ambapp.h
+include_HEADERS += ../../sparc/shared/include/ambapp_ids.h
+include_HEADERS += ../../sparc/shared/include/grlib.h
+# Console
+include_bsp_HEADERS += include/xtratum-hyper-console.h
+libbsp_a_SOURCES += console/printk-support.c
+libbsp_a_SOURCES += ../../shared/console.c
+libbsp_a_SOURCES += ../../shared/console_control.c
+libbsp_a_SOURCES += ../../shared/console_read.c
+libbsp_a_SOURCES += ../../shared/console_select.c
+libbsp_a_SOURCES += ../../shared/console_write.c
+libbsp_a_SOURCES += ../../shared/console-output-char.c
+libbsp_a_SOURCES += console/console-config.c
+libbsp_a_SOURCES += console/xtratum-hyper-console.c
+# Clock
+libbsp_a_SOURCES += clock/clock-xtratum-hw.c
+libbsp_a_SOURCES += clock/clock-xtratum-exec.c
+libbsp_a_SOURCES += clock/clock-gpt.c
+# IRQ
+include_bsp_HEADERS += ../../shared/include/irq-generic.h
+include_bsp_HEADERS += ../../shared/include/irq-info.h
+include_bsp_HEADERS += include/irq.h
+libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
+libbsp_a_SOURCES += ../../shared/src/irq-generic.c
+libbsp_a_SOURCES += ../../shared/src/irq-info.c
+libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
+libbsp_a_SOURCES += ../../shared/src/irq-server.c
+libbsp_a_SOURCES += ../../shared/src/irq-shell.c
+libbsp_a_SOURCES += irq/irq.c
+# Cache
+libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
+libbsp_a_SOURCES += include/cache_.h
+libbsp_a_CPPFLAGS += -I$(srcdir)/../../shared/include
+libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/access.rel
+include $(srcdir)/preinstall.am
+include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/sparc/xtratum/README b/c/src/lib/libbsp/sparc/xtratum/README
index 0000000..1563cbd
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/README
@@ -0,0 +1,56 @@
+Overview
+BSP for use with XtratuM 4 hypervisor.
+It is necessary that the environment variable XTRATUM_PATH is set to the
+XtratuM installation path, e.g.
+XTRATUM_PATH="/opt/xtratum/xm"
+By default the example_xm_cf.xml will be used for building the tests.  It can
+be overwritten with setting the XTRATUM_CONFIG environment variable to another
+XML file, e.g.
+XTRATUM_CONFIG="/some/path/to/rtems_xm_cf.xml"
+List of open points
+- Implement or remove _SPARC_Set_TBR(). This function is not currently used by
+  anyone.
+- Find a better solution for setting the CPPFLAGS for libbspstart_a_SOURCES in
+  Makefile.am
+- Fix C++ support: The C++ exceptions (i.e. in testsuite/samples/cdtest) don't
+  work correctly. The reason is a broken window flush trap procedure (ta 0x3).
+Problems with XtratuM API
+- The functions XM_sparc_set_pil and XM_sparc_clear_pil can only write all 0 or
+  all 1 to the PIL. Therefore a read modify write operation with two hypercalls
+  is necessary in the sparc_disable_interrupts and sparc_enable_interrupts
+  functions.
+- XM_write_console misses the const attribute for the character array that
+  should be written. Therefore there are warnings when passing the constant
+  string in xtratum_hyper_console_write_support_polled.
+- The XtratuM documentation does not clearly specify state and / or value of
+  registers at some points. Therefore this has to be guessed with help of
+  XtratuM sources. That is true for the following points:
+  - register usage and values when entering traps
+  - register values on the partition entry point
+  - which registers are preserved over XtratuM hypercalls
+- The thread context switch uses too many hypercalls.
+- The interrupt handling uses too many hypercalls.
+- The lazy hypercall implementation on XtratuM 4.2 is potentially broken on
+  SMP.
+- The init_libxm() implementation on XtratuM 4.2 is potentially broken on SMP.
diff --git a/c/src/lib/libbsp/sparc/xtratum/bsp_specs b/c/src/lib/libbsp/sparc/xtratum/bsp_specs
index 0000000..93d6e75
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/bsp_specs
@@ -0,0 +1,17 @@
+%rename endfile old_endfile
+%rename startfile old_startfile
+%rename link old_link
+%rename lib old_lib
+*endfile:
+crtend.o%s crtn.o%s
+*startfile:
+%{!qrtems: %(old_startfile)} \
+%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s}}
+*link:
+%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
+*lib:
+%(old_lib) -lxm
diff --git a/c/src/lib/libbsp/sparc/xtratum/clock/clock-gpt.c b/c/src/lib/libbsp/sparc/xtratum/clock/clock-gpt.c
index 0000000..1a40a0a
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/clock/clock-gpt.c
@@ -0,0 +1,120 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <info at embedded-brains.de>
+#include <bsp.h>
+#include <bsp/fatal.h>
+#include <xm.h>
+ * First timer generates one interrupt per underflow.  Setup that it underflows
+ * once per tick.
+#define CLOCK_GPT_IDX_AUTO_RELOAD 0
+ * Second timer is decremented on each underflow of first timer.  So it counts
+ * the ticks.
+#define CLOCK_GPT_IDX_TICK_CTR (CLOCK_GPT_IDX_AUTO_RELOAD + 1)
+#define TRAP_NUMBER XTRATUM_TRAP_FROM_XM_HW_IRQ(XM_VT_HW_TIMER2_TRAP_NR)
+static volatile uint32_t lasttime;
+static void gpt_clock_handler(void *notused)
+  rtems_interrupt_level level;
+  (void) notused;
+  clock_gpt_regs.timer[CLOCK_GPT_IDX_AUTO_RELOAD].ctrl
+    |= GPTIMER_TIMER_CTRL_IP;
+  /* This prevents infinite nesting of this interrupt */
+  rtems_interrupt_disable(level);
+  (void) level;
+  bsp_unmask_interrupt(TRAP_NUMBER);
+  while (lasttime > clock_gpt_regs.timer[CLOCK_GPT_IDX_TICK_CTR].value) {
+    --lasttime;
+    rtems_clock_tick();
+static uint32_t nanoseconds_since_last_tick(void)
+  uint32_t fast_timer_value;
+  uint32_t lasttime_value_0;
+  uint32_t slow_timer_value_0;
+  uint32_t slow_timer_value_1;
+  uint32_t usecs;
+  uint32_t usecs_per_tick = rtems_configuration_get_microseconds_per_tick();
+  do {
+    slow_timer_value_0 = clock_gpt_regs.timer[CLOCK_GPT_IDX_TICK_CTR].value;
+    lasttime_value_0 = lasttime;
+    fast_timer_value = clock_gpt_regs.timer[CLOCK_GPT_IDX_AUTO_RELOAD].value;
+    slow_timer_value_1 = clock_gpt_regs.timer[CLOCK_GPT_IDX_TICK_CTR].value;
+  } while (slow_timer_value_0 != slow_timer_value_1);
+  usecs = (lasttime_value_0 - slow_timer_value_0) * usecs_per_tick
+          + usecs_per_tick - fast_timer_value;
+  return usecs * 1000;
+static void clock_handler_install(void)
+  rtems_status_code sc;
+  sc = rtems_interrupt_handler_install(
+    TRAP_NUMBER,
+    "Clock",
+    RTEMS_INTERRUPT_UNIQUE,
+    gpt_clock_handler,
+    NULL
+  if (sc != RTEMS_SUCCESSFUL) {
+    bsp_fatal(XTRATUM_FATAL_GPT_CLOCK_IRQ_INSTALL);
+rtems_device_driver clock_gpt_initialize(
+  rtems_device_major_number major,
+  rtems_device_minor_number minor,
+  void *pargp
+  clock_gpt_regs.timer[CLOCK_GPT_IDX_AUTO_RELOAD].ctrl = GPTIMER_TIMER_CTRL_IP;
+  clock_gpt_regs.timer[CLOCK_GPT_IDX_TICK_CTR].ctrl = GPTIMER_TIMER_CTRL_IP;
+  clock_handler_install();
+  rtems_clock_set_nanoseconds_extension(nanoseconds_since_last_tick);
+  clock_gpt_regs.timer[CLOCK_GPT_IDX_TICK_CTR].reload = 0xFFFFFFFF;
+  lasttime = clock_gpt_regs.timer[CLOCK_GPT_IDX_TICK_CTR].reload;
+  clock_gpt_regs.timer[CLOCK_GPT_IDX_TICK_CTR].ctrl = GPTIMER_TIMER_CTRL_EN
+    | GPTIMER_TIMER_CTRL_LD | GPTIMER_TIMER_CTRL_IP | GPTIMER_TIMER_CTRL_CH;
+  clock_gpt_regs.timer[CLOCK_GPT_IDX_AUTO_RELOAD].reload =
+    rtems_configuration_get_microseconds_per_tick() - 1;
+  clock_gpt_regs.timer[CLOCK_GPT_IDX_AUTO_RELOAD].ctrl = GPTIMER_TIMER_CTRL_EN
+    | GPTIMER_TIMER_CTRL_RS | GPTIMER_TIMER_CTRL_LD | GPTIMER_TIMER_CTRL_IE
+    | GPTIMER_TIMER_CTRL_IP;
+  return RTEMS_SUCCESSFUL;
diff --git a/c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-exec.c b/c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-exec.c
index 0000000..c0d36ec
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-exec.c
@@ -0,0 +1,23 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <bsp.h>
+#define XTRATUM_CLOCK XM_EXEC_CLOCK
+#define CLOCK_EXT_TRAP_NUMBER \
+  XTRATUM_TRAP_FROM_XM_EXT_IRQ( XM_VT_EXT_EXEC_TIMER )
+#define XTRATUM_CLOCK_INITIALIZE clock_xtratum_exec_initialize
+#include "clock-xtratum.h"
diff --git a/c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-hw.c b/c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-hw.c
index 0000000..48a7efa
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-hw.c
@@ -0,0 +1,21 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#define XTRATUM_CLOCK XM_HW_CLOCK
+  XTRATUM_TRAP_FROM_XM_EXT_IRQ( XM_VT_EXT_HW_TIMER )
+#define XTRATUM_CLOCK_INITIALIZE Clock_initialize
diff --git a/c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum.h b/c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum.h
index 0000000..af930e4
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum.h
@@ -0,0 +1,94 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <xm.h>
+static uint32_t lasttime;
+static uint32_t xtratum_get_time(void)
+  xmTime_t clocktime;
+  XM_get_time(XTRATUM_CLOCK, &clocktime);
+  return (uint32_t) clocktime;
+static uint32_t xtratum_clock_nanoseconds_since_last_tick(void)
+  uint32_t now = xtratum_get_time();
+  return (now - lasttime) * 1000;
+static void xtratum_clock_handler(void *arg)
+  uint32_t us_per_tick = rtems_configuration_get_microseconds_per_tick();
+  (void) arg;
+  /* FIXME: What prevents infinite interrupt nesting here? */
+  while (lasttime + us_per_tick <= now) {
+    lasttime += us_per_tick;
+static void xtratum_clock_handler_install(void)
+    CLOCK_EXT_TRAP_NUMBER,
+    "Clock",
+    xtratum_clock_handler,
+    NULL
+    bsp_fatal(XTRATUM_FATAL_CLOCK_IRQ_INSTALL);
+rtems_device_driver XTRATUM_CLOCK_INITIALIZE(
+  void *arg
+  (void) major;
+  (void) minor;
+  (void) arg;
+  lasttime = (uint32_t) clocktime;
+  xtratum_clock_handler_install();
+    xtratum_clock_nanoseconds_since_last_tick
+  XM_set_timer(XTRATUM_CLOCK, clocktime + us_per_tick, us_per_tick);
diff --git a/c/src/lib/libbsp/sparc/xtratum/configure.ac b/c/src/lib/libbsp/sparc/xtratum/configure.ac
index 0000000..7dde9ac
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/configure.ac
@@ -0,0 +1,33 @@
+## Process this file with autoconf to produce a configure script.
+AC_PREREQ([2.69])
+AC_INIT([rtems-c-src-lib-libbsp-sparc-xtratum],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
+AC_CONFIG_SRCDIR([bsp_specs])
+RTEMS_TOP(../../../../../..)
+RTEMS_CANONICAL_TARGET_CPU
+AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
+RTEMS_BSP_CONFIGURE
+RTEMS_PROG_CC_FOR_TARGET
+RTEMS_CANONICALIZE_TOOLS
+RTEMS_PROG_CCAS
+RTEMS_CHECK_NETWORKING
+RTEMS_CHECK_SMP
+AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
+AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
+RTEMS_BSPOPTS_SET([RTEMS_PARAVIRT_XTRATUM],[*],[1])
+RTEMS_BSPOPTS_HELP([RTEMS_PARAVIRT_XTRATUM],[Should be defined, if it is an XtratuM BSP.])
+RTEMS_BSPOPTS_SET([XTRATUM_SIZE_PAGE_TABLE],[*],[256])
+RTEMS_BSPOPTS_HELP([XTRATUM_SIZE_PAGE_TABLE],[Size of the XtratuM page table in pages.])
+RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
+RTEMS_BSP_LINKCMDS
+# Explicitly list all Makefiles here
+AC_CONFIG_FILES([Makefile])
+AC_OUTPUT
diff --git a/c/src/lib/libbsp/sparc/xtratum/console/console-config.c b/c/src/lib/libbsp/sparc/xtratum/console/console-config.c
index 0000000..366422f
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/console/console-config.c
@@ -0,0 +1,27 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <libchip/serial.h>
+#include <bsp/xtratum-hyper-console.h>
+console_tbl Console_Configuration_Ports[] = {
+    .sDeviceName = "/dev/ttyS0",
+    .deviceType = SERIAL_CUSTOM,
+    .pDeviceFns = &xtratum_hyper_console_fns,
+unsigned long Console_Configuration_Count =
+  RTEMS_ARRAY_SIZE(Console_Configuration_Ports);
diff --git a/c/src/lib/libbsp/sparc/xtratum/console/printk-support.c b/c/src/lib/libbsp/sparc/xtratum/console/printk-support.c
index 0000000..9049f18
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/console/printk-support.c
@@ -0,0 +1,28 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <rtems/bspIo.h>
+#include <xm.h>
+static void console_output(char c)
+  if (c == '\n') {
+    char r = '\r';
+    XM_write_console(&r, sizeof(r));
+  XM_write_console(&c, sizeof(c));
+BSP_output_char_function_type BSP_output_char = console_output;
diff --git a/c/src/lib/libbsp/sparc/xtratum/console/xtratum-hyper-console.c b/c/src/lib/libbsp/sparc/xtratum/console/xtratum-hyper-console.c
index 0000000..1dd348b
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/console/xtratum-hyper-console.c
@@ -0,0 +1,71 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <libchip/sersupp.h>
+#include <xm.h>
+static void xtratum_hyper_console_initialize(int minor)
+static int xtratum_hyper_console_first_open(int major, int minor, void *arg)
+  return 0;
+static int xtratum_hyper_console_last_close(int major, int minor, void *arg)
+  return 0;
+static int xtratum_hyper_console_read_polled(int minor)
+  return -1;
+static void xtratum_hyper_console_write_polled(int minor, char c)
+static ssize_t xtratum_hyper_console_write_support_polled(
+  int minor,
+  const char *s,
+  size_t n
+  XM_write_console(s, n);
+  return n;
+static int xtratum_hyper_console_set_attribues(
+  int minor,
+  const struct termios *term
+  return -1;
+const console_fns xtratum_hyper_console_fns = {
+  .deviceProbe = libchip_serial_default_probe,
+  .deviceFirstOpen = xtratum_hyper_console_first_open,
+  .deviceLastClose = xtratum_hyper_console_last_close,
+  .deviceRead = xtratum_hyper_console_read_polled,
+  .deviceWrite = xtratum_hyper_console_write_support_polled,
+  .deviceInitialize = xtratum_hyper_console_initialize,
+  .deviceWritePolled = xtratum_hyper_console_write_polled,
+  .deviceSetAttributes = xtratum_hyper_console_set_attribues,
+  .deviceOutputUsesInterrupts = false
diff --git a/c/src/lib/libbsp/sparc/xtratum/include/bsp.h b/c/src/lib/libbsp/sparc/xtratum/include/bsp.h
index 0000000..b14130c
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/include/bsp.h
@@ -0,0 +1,117 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifndef LIBBSP_SPARC_XTRATUM_BSP_H
+#define LIBBSP_SPARC_XTRATUM_BSP_H
+#ifndef ASM
+#include <rtems.h>
+#include <xtratum.h>
+#include <grlib.h>
+#include <rtems/console.h>
+#include <rtems/clockdrv.h>
+#include <rtems/irq-extension.h>
+#include <bsp/default-initial-extension.h>
+#define BSP_FEATURE_IRQ_EXTENSION
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * This BSP provides three clock drivers.
+ * 1. The standard clock driver uses the XtratuM hardware clock (XM_HW_CLOCK).
+ *    Configuration:
+ *    #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+ * 2. The execution clock driver uses the XtratuM execution clock (XM_EXEC_CLOCK).
+ *    Configuration:
+ *    #define CONFIGURE_APPLICATION_EXTRA_DRIVERS \
+ *      { .initialization_entry = clock_xtratum_exec_initialize }
+ *    #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+ * 3. The GPTIMER clock driver uses a GPTIMER module defined via clock_gpt_regs.
+ *    Configuration:
+ *      { .initialization_entry = clock_gpt_initialize }
+ *    This GPTIMER module is also used for the CPU counter support if not
+ *    defined to CLOCK_GPT_NOT_PRESENT.  The clock_gpt_regs must be defined via
+ *    the linker.  It is assumed that XtratuM initialized the prescaler so that
+ *    the counter frequency is 1MHz.
+rtems_device_driver clock_xtratum_exec_initialize(
+  void *arg
+ * The first timer generates one interrupt per underflow it is set up so that
+ * it underflows once per tick.
+ * The second timer decrements on each underflow of first timer.  So it counts
+ * the ticks.
+ * The third timer is a free running counter used for the CPU counter support.
+#define CLOCK_GPT_IDX_CPU_CTR (CLOCK_GPT_IDX_TICK_CTR + 1)
+#define CLOCK_GPT_NOT_PRESENT ((volatile struct gptimer_regs *) 0xdeadbeef)
+extern volatile struct gptimer_regs clock_gpt_regs;
+  void *arg
+extern int end;
+rtems_isr_entry set_vector(
+  rtems_isr_entry handler,
+  rtems_vector_number vector,
+  int type
+void bsp_spurious_initialize(void);
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_SPARC_XTRATUM_BSP_H */
diff --git a/c/src/lib/libbsp/sparc/xtratum/include/cache_.h b/c/src/lib/libbsp/sparc/xtratum/include/cache_.h
index 0000000..94025d6
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/include/cache_.h
@@ -0,0 +1,113 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef XTRATUM_CACHE_H
+#define XTRATUM_CACHE_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
+#define CPU_INSTRUCTION_CACHE_ALIGNMENT 64
+#define CPU_DATA_CACHE_ALIGNMENT 64
+static inline void _CPU_cache_flush_data_range(
+  const void *d_addr,
+  size_t n_bytes
+  /* TODO */
+static inline void _CPU_cache_invalidate_data_range(
+  size_t n_bytes
+  /* TODO */
+static inline void _CPU_cache_freeze_data(void)
+  /* TODO */
+static inline void _CPU_cache_unfreeze_data(void)
+  /* TODO */
+static inline void _CPU_cache_invalidate_entire_instruction(void)
+  __asm__ volatile ("flush");
+static inline void _CPU_cache_invalidate_instruction_range(
+  const void *i_addr,
+  size_t n_bytes
+  _CPU_cache_invalidate_entire_instruction();
+static inline void _CPU_cache_freeze_instruction(void)
+  /* TODO */
+static inline void _CPU_cache_unfreeze_instruction(void)
+  /* TODO */
+static inline void _CPU_cache_flush_entire_data(void)
+  /* TODO */
+static inline void _CPU_cache_invalidate_entire_data(void)
+  /* TODO */
+static inline void _CPU_cache_enable_data(void)
+  /* TODO */
+static inline void _CPU_cache_disable_data(void)
+  /* TODO */
+static inline void _CPU_cache_enable_instruction(void)
+  /* TODO */
+static inline void _CPU_cache_disable_instruction(void)
+  /* TODO */
+#ifdef __cplusplus
+#endif /* XTRATUM_CACHE_H */
diff --git a/c/src/lib/libbsp/sparc/xtratum/include/irq.h b/c/src/lib/libbsp/sparc/xtratum/include/irq.h
index 0000000..afa99c0
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/include/irq.h
@@ -0,0 +1,2 @@
+#define BSP_INTERRUPT_VECTOR_MIN 0
+#define BSP_INTERRUPT_VECTOR_MAX (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
diff --git a/c/src/lib/libbsp/sparc/xtratum/include/tm27.h b/c/src/lib/libbsp/sparc/xtratum/include/tm27.h
index 0000000..85c4963
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/include/tm27.h
@@ -0,0 +1,30 @@
+ *  tm27.h
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+#define TEST_VECTOR SPARC_SYNCHRONOUS_TRAP( 0x90 )
+#define MUST_WAIT_FOR_INTERRUPT 1
+#define Install_tm27_vector( handler ) \
+  set_vector( (handler), TEST_VECTOR, 1 );
+#define Cause_tm27_intr() \
+  __asm__ volatile( "ta 0x10; nop " );
+#define Clear_tm27_intr() /* empty */
+#define Lower_tm27_intr() /* empty */
+#endif /* __tm27_h */
diff --git a/c/src/lib/libbsp/sparc/xtratum/include/xtratum-hyper-console.h b/c/src/lib/libbsp/sparc/xtratum/include/xtratum-hyper-console.h
index 0000000..73b7c17
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/include/xtratum-hyper-console.h
@@ -0,0 +1,30 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifndef LIBBSP_XTRATUM_HYPER_CONSOLE_H
+#define LIBBSP_XTRATUM_HYPER_CONSOLE_H
+#ifdef __cplusplus
+extern "C" {
+extern const console_fns xtratum_hyper_console_fns;
+#ifdef __cplusplus
+#endif /* LIBBSP_XTRATUM_HYPER_CONSOLE_H */
diff --git a/c/src/lib/libbsp/sparc/xtratum/include/xtratum.h b/c/src/lib/libbsp/sparc/xtratum/include/xtratum.h
index 0000000..659b804
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/include/xtratum.h
@@ -0,0 +1,87 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifndef _INCLUDE_XTRATUM_H
+#define _INCLUDE_XTRATUM_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifndef ASM
+/* XtratuM defines traps for the hardware interrupts as well as some XtratuM
+ * Extended interrupts.
+ *   TRAP[0x11..0x1F] <=> Hardware interrupts
+ *   TRAP[0x20..0x2F] <=> Reserved for future architectures
+ *   TRAP[0xE0..0xFF] <=> XtratuM Extended interrupts
+#define XTRATUM_TRAP_HW_OFFSET 0x10
+#define XTRATUM_TRAP_HW_FIRST (XTRATUM_TRAP_HW_OFFSET + 0x01)
+#define XTRATUM_TRAP_HW_LAST (XTRATUM_TRAP_HW_OFFSET + 0x0F)
+#define XTRATUM_TRAP_EXT_OFFSET 0xE0
+#define XTRATUM_TRAP_EXT_FIRST (XTRATUM_TRAP_EXT_OFFSET)
+#define XTRATUM_TRAP_EXT_LAST (XTRATUM_TRAP_EXT_OFFSET + 0x1F)
+/* Converter macros for the irq-numbers defined by XtratuM */
+#define XTRATUM_TRAP_FROM_XM_HW_IRQ( xm_vt_hw ) \
+    ((xm_vt_hw) + XTRATUM_TRAP_HW_OFFSET )
+#define XTRATUM_TRAP_FROM_XM_EXT_IRQ( xm_vt_ext ) \
+    ((xm_vt_ext) + XTRATUM_TRAP_EXT_OFFSET )
+/* Check for the trap number type */
+#define XTRATUM_TRAP_IS_HW( trap ) \
+  ((trap) >= XTRATUM_TRAP_HW_FIRST && (trap) <= XTRATUM_TRAP_HW_LAST)
+#define XTRATUM_TRAP_IS_EXT( trap ) \
+  ((trap) >= XTRATUM_TRAP_EXT_FIRST && (trap) <= XTRATUM_TRAP_EXT_LAST)
+#define XTRATUM_TRAP_IS_INTERRUPT( trap ) \
+  (XTRATUM_TRAP_IS_HW( trap ) || XTRATUM_TRAP_IS_EXT( trap ))
+/* get masks from trap number */
+static inline uint32_t xtratum_hw_mask( rtems_vector_number vector )
+  uint32_t hw_mask = 0;
+  if ( XTRATUM_TRAP_IS_HW( vector ) ) {
+    hw_mask = 1 << (vector - XTRATUM_TRAP_HW_OFFSET);
+  return hw_mask;
+static inline uint32_t xtratum_ext_mask( rtems_vector_number vector )
+  uint32_t ext_mask = 0;
+  if ( XTRATUM_TRAP_IS_EXT( vector ) ) {
+    ext_mask = 1 << (vector - XTRATUM_TRAP_EXT_OFFSET);
+  return ext_mask;
+#endif /* ASM */
+void bsp_clear_interrupt( rtems_vector_number vector );
+void bsp_unmask_interrupt( rtems_vector_number vector );
+void bsp_mask_interrupt( rtems_vector_number vector );
+void xtratum_interrupt_init(void);
+#ifdef __cplusplus
+#endif
+#endif /* _INCLUDE_XTRATUM_H */
diff --git a/c/src/lib/libbsp/sparc/xtratum/irq/irq.c b/c/src/lib/libbsp/sparc/xtratum/irq/irq.c
index 0000000..840f695
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/irq/irq.c
@@ -0,0 +1,90 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <rtems.h>
+#include <bsp.h>
+#include <bsp/irq-generic.h>
+#include <xm.h>
+static void bsp_isr_handler(rtems_vector_number vector)
+  bsp_interrupt_handler_dispatch(vector);
+  rtems_vector_number vector;
+  rtems_isr_entry previous_isr;
+  for (
+    vector = XTRATUM_TRAP_HW_FIRST;
+    vector <= XTRATUM_TRAP_HW_LAST;
+    vector++
+    rtems_interrupt_catch(bsp_isr_handler, vector, &previous_isr);
+  for (
+    vector = XTRATUM_TRAP_EXT_FIRST;
+    vector <= XTRATUM_TRAP_EXT_LAST;
+    vector++
+  bsp_interrupt_initialize();
+rtems_status_code bsp_interrupt_facility_initialize(void)
+rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
+  bsp_unmask_interrupt(vector);
+rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  bsp_mask_interrupt(vector);
+  uint32_t hw_mask = xtratum_hw_mask( vector );
+  uint32_t ext_mask = xtratum_ext_mask( vector );
+  XM_clear_irqpend( hw_mask, ext_mask );
+  XM_clear_irqmask( hw_mask, ext_mask );
+  XM_set_irqmask( hw_mask, ext_mask );
diff --git a/c/src/lib/libbsp/sparc/xtratum/make/custom/xtratum.cfg b/c/src/lib/libbsp/sparc/xtratum/make/custom/xtratum.cfg
index 0000000..26832b5
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/make/custom/xtratum.cfg
@@ -0,0 +1,55 @@
+#  Config file for the XtratuM Hypervisor on LEON3.
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU=sparc
+RTEMS_CPU_MODEL=leon3
+#  This contains the compiler options necessary to select the CPU model
+#  and (hopefully) optimize for it.
+CPU_CFLAGS = -mcpu=leon3 -muser-mode -msoft-float
+# optimize flag: typically -O2
+CFLAGS_OPTIMIZE_V = -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
+LDFLAGS += -L"$(XTRATUM_PATH)/lib"
+LDFLAGS += -u xmImageHdr
+# Variables for building XtratuM executable
+XMRSWBUILD = $(XTRATUM_PATH)/bin/rswbuild
+XMPACK = $(XTRATUM_PATH)/bin/xmpack
+XMEFORMAT = $(XTRATUM_PATH)/bin/xmeformat
+XMCPARSER = $(XTRATUM_PATH)/bin/xmcparser
+XMCORE = $(XTRATUM_PATH)/lib/xm_core.xef
+ifeq ($(XTRATUM_CONFIG),)
+	XTRATUM_CONFIG = $(PROJECT_LIB)/example_xm_cf.xml
+endif
+XM_BASENAME = $(basename $@)
+XM_INPUT = $(XM_BASENAME).exe
+XM_XEF = $(XM_BASENAME).xef
+XM_BIN_XMC = $(XM_BASENAME).xm_cf.bin.xmc
+XM_XEF_XMC = $(XM_BASENAME).xm_cf.bin.xmc
+XM_CONTAINER_BIN = $(XM_BASENAME).bin
+XM_EXECUTABLE = $(XM_BASENAME).ralf
+XMPACK_ARGS = -h $(XMCORE):$(XM_XEF_XMC) -p 0:$(XM_XEF)
+define bsp-post-link
+	$(default-bsp-post-link)
+	$(XMEFORMAT) build $(XM_INPUT) -o $(XM_XEF)
+	$(XMCPARSER) -o $(XM_BIN_XMC) $(XTRATUM_CONFIG)
+	$(XMEFORMAT) build -m $(XM_BIN_XMC) -c -o $(XM_XEF_XMC)
+	$(XMPACK) check $(XM_XEF_XMC) $(XMPACK_ARGS)
+	$(XMPACK) build $(XMPACK_ARGS) $(XM_CONTAINER_BIN)
+	$(XMRSWBUILD) $(XM_CONTAINER_BIN) $(XM_EXECUTABLE)
+endef
diff --git a/c/src/lib/libbsp/sparc/xtratum/preinstall.am b/c/src/lib/libbsp/sparc/xtratum/preinstall.am
index 0000000..6f6e07c
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/preinstall.am
@@ -0,0 +1,115 @@
+## Automatically generated by ampolish3 - Do not edit
+if AMPOLISH3
+$(srcdir)/preinstall.am: Makefile.am
+	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
+endif
+PREINSTALL_DIRS =
+DISTCLEANFILES += $(PREINSTALL_DIRS)
+all-local: $(TMPINSTALL_FILES)
+TMPINSTALL_FILES =
+CLEANFILES = $(TMPINSTALL_FILES)
+all-am: $(PREINSTALL_FILES)
+PREINSTALL_FILES =
+CLEANFILES += $(PREINSTALL_FILES)
+$(PROJECT_LIB)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_LIB)
+	@: > $(PROJECT_LIB)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
+$(PROJECT_INCLUDE)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)
+	@: > $(PROJECT_INCLUDE)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
+$(PROJECT_INCLUDE)/bsp/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
+	@: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
+PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
+$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
+$(PROJECT_INCLUDE)/tm27.h: include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
+$(PROJECT_INCLUDE)/debug_defs.h: ../../sparc/shared/include/debug_defs.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/debug_defs.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/debug_defs.h
+$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
+$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
+$(PROJECT_INCLUDE)/xtratum.h: include/xtratum.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/xtratum.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/xtratum.h
+$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
+$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
+TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
+$(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
+$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
+$(PROJECT_LIB)/linkcmds.xtratum: startup/linkcmds.xtratum $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.xtratum
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.xtratum
+$(PROJECT_LIB)/example_xm_cf.xml: startup/example_xm_cf.xml $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/example_xm_cf.xml
+PREINSTALL_FILES += $(PROJECT_LIB)/example_xm_cf.xml
+$(PROJECT_INCLUDE)/ambapp.h: ../../sparc/shared/include/ambapp.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/ambapp.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp.h
+$(PROJECT_INCLUDE)/ambapp_ids.h: ../../sparc/shared/include/ambapp_ids.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/ambapp_ids.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp_ids.h
+$(PROJECT_INCLUDE)/grlib.h: ../../sparc/shared/include/grlib.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grlib.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/grlib.h
+$(PROJECT_INCLUDE)/bsp/xtratum-hyper-console.h: include/xtratum-hyper-console.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/xtratum-hyper-console.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/xtratum-hyper-console.h
+$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
+$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
+$(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c b/c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c
index 0000000..3ac6595
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c
@@ -0,0 +1,52 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <xm.h>
+#include <bsp/bootcard.h>
+#ifdef RTEMS_SMP
+void bsp_reset(void)
+  uint32_t self_cpu = rtems_get_current_processor();
+  if (self_cpu == 0) {
+    /* Value should give us roughly something in the range of a few
+     * milliseconds. */
+    volatile uint32_t max_wait = 1234567;
+    uint32_t cpu_count = rtems_get_processor_count();
+    uint32_t cpus_halted = 0;
+    /* Wait some time for secondary processors to halt */
+    do {
+      xmVirtualCpuStatus_t status;
+      cpus_halted = 0;
+      uint32_t i;
+      for (i=1; i<cpu_count; ++i) {
+        XM_get_vcpu_status(i, &status);
+        if (status.state == XM_STATUS_HALTED) {
+          ++cpus_halted;
+      --max_wait;
+    } while (cpus_halted < cpu_count - 1 && max_wait > 0);
+    XM_halt_partition(XM_PARTITION_SELF);
+  } else {
+    XM_halt_vcpu(self_cpu);
+  while (1);
+#endif
diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c b/c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c
index 0000000..a486e3f
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c
@@ -0,0 +1,105 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <assert.h>
+#include <bsp.h>
+#include <xm.h>
+#include <rtems/score/smpimpl.h>
+#include <fatal.h>
+#define IPVI_NR( idx ) (XM_VT_EXT_IPVI0 + idx)
+#define IPVI_TRAP_NR( idx ) XTRATUM_TRAP_FROM_XM_EXT_IRQ( IPVI_NR( idx ) )
+void start(void);
+extern struct xmImageHdr xmImageHdr;
+uint32_t _CPU_SMP_Get_current_processor(void)
+  return XM_get_vcpuid();
+static rtems_isr bsp_inter_processor_interrupt(
+  _SMP_Inter_processor_interrupt_handler();
+void bsp_start_on_secondary_processor(void)
+  rtems_vector_number  vector = IPVI_TRAP_NR(_CPU_SMP_Get_current_processor());
+  _SMP_Start_multitasking_on_secondary_processor();
+static void install_vector_without_unmask(
+  rtems_isr_entry      new_isr_handler,
+    new_isr_handler,
+    vector,
+    &previous_isr
+  bsp_clear_interrupt( vector );
+  rtems_cache_invalidate_entire_instruction();
+uint32_t _CPU_SMP_Initialize(void)
+  uint32_t cpu_index_self = XM_get_vcpuid();
+  rtems_vector_number  vector = IPVI_TRAP_NR(cpu_index_self);
+  if (cpu_index_self != 0) {
+    bsp_fatal(XTRATUM_FATAL_CPU_SMP_INITIALIZE);
+  if (rtems_configuration_get_maximum_processors() > 1) {
+    install_vector_without_unmask(bsp_inter_processor_interrupt, vector);
+  return XM_get_number_vcpus();
+bool _CPU_SMP_Start_processor(uint32_t cpu_index)
+  int32_t rv;
+  rtems_vector_number vector = IPVI_TRAP_NR(cpu_index);
+  rv = XM_reset_vcpu(cpu_index, xmImageHdr.pageTable, (xm_s32_t) start, 0);
+  assert(rv == XM_OK);
+  return true;
+void _CPU_SMP_Finalize_initialization(uint32_t cpu_count)
+  (void) cpu_count;
+  /* Nothing to do */
+void _CPU_SMP_Send_interrupt(uint32_t target_processor_index)
+  XM_raise_ipvi(IPVI_NR(target_processor_index));
diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c b/c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c
index 0000000..f05bc10
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c
@@ -0,0 +1,53 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <bsp.h>
+#include <rtems/counter.h>
+static CPU_Counter_ticks free_counter_difference(
+  CPU_Counter_ticks second,
+  CPU_Counter_ticks first
+  return first - second;
+static void cpu_counter_init(void)
+  volatile struct gptimer_regs *gpt = &clock_gpt_regs;
+  if (&clock_gpt_regs != CLOCK_GPT_NOT_PRESENT) {
+    size_t timer_index = CLOCK_GPT_IDX_CPU_CTR;
+    gpt->timer[timer_index].reload = 0xffffffff;
+    gpt->timer[timer_index].ctrl = GPTIMER_TIMER_CTRL_EN
+      | GPTIMER_TIMER_CTRL_RS | GPTIMER_TIMER_CTRL_LD;
+    _SPARC_Counter_initialize(
+      (volatile const uint32_t *) &gpt->timer[timer_index].value,
+      free_counter_difference
+    rtems_counter_initialize_converter(1000000);
+void bsp_start(void)
+  cpu_counter_init();
+  xtratum_interrupt_init();
diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/example_xm_cf.xml b/c/src/lib/libbsp/sparc/xtratum/startup/example_xm_cf.xml
index 0000000..3780d3c
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/startup/example_xm_cf.xml
@@ -0,0 +1,69 @@
+<?xml version="1.0"?>
+<SystemDescription xmlns="http://www.xtratum.org/xm-3.x" version="1.0.0" name="hello_world">
+  <HwDescription>
+    <MemoryLayout>
+      <Region type="sdram" start="0x0" size="256MB"/>
+      <!-- UART1 -->
+      <Region type="sdram" start="0xFF901000" size="4096B"/>
+      <!-- GPTIMER4 -->
+      <Region type="sdram" start="0xFF90C000" size="4096B"/>
+    </MemoryLayout>
+    <ProcessorTable>
+      <Processor id="0" frequency="150Mhz">
+        <CyclicPlanTable>
+          <Plan id="0" majorFrame="1000ms">
+            <Slot id="0" start="0ms" duration="900ms" partitionId="0" vCpuId="0"/>
+          </Plan>
+        </CyclicPlanTable>
+      </Processor>
+      <Processor id="1" frequency="150Mhz">
+        <CyclicPlanTable>
+            <Slot id="0" start="0ms" duration="900ms" partitionId="0" vCpuId="1"/>
+          </Plan>
+      </Processor>
+      <Processor id="2" frequency="150Mhz">
+        <CyclicPlanTable>
+            <Slot id="0" start="0ms" duration="900ms" partitionId="0" vCpuId="2"/>
+          </Plan>
+      </Processor>
+      <Processor id="3" frequency="150Mhz">
+        <CyclicPlanTable>
+            <Slot id="0" start="0ms" duration="900ms" partitionId="0" vCpuId="3"/>
+          </Plan>
+      </Processor>
+    </ProcessorTable>
+    <Devices>
+      <Uart id="0" baudRate="115200" name="Uart"/>
+    </Devices>
+  </HwDescription>
+  <XMHypervisor console="Uart">
+    <PhysicalMemoryArea size="16MB"/>
+    <IoMmu>
+      <AhbMst id="0" partitionId="0" busRouting="memory" vendorId="0x1" deviceId="0x11" />
+    </IoMmu>
+  </XMHypervisor>
+  <PartitionTable>
+    <Partition id="0" name="Partition1" flags="system" console="Uart" noVCpus="4">
+      <PhysicalMemoryAreas>
+        <Area start="0x02000000" size="16MB"/>
+        <Area start="0xFF901000" size="4096B" mappedAt="0x40901000"/>
+        <Area start="0xFF90C000" size="4096B" mappedAt="0x4090C000" flags="uncacheable iommu"/>
+      </PhysicalMemoryAreas>
+      <HwResources>
+        <Interrupts lines="9"/>
+      </HwResources>
+    </Partition>
+  </PartitionTable>
+  <Channels>
+    <Ipvi id="0" sourceId="0" destinationId="0"/>
+    <Ipvi id="1" sourceId="0" destinationId="0"/>
+    <Ipvi id="2" sourceId="0" destinationId="0"/>
+    <Ipvi id="3" sourceId="0" destinationId="0"/>
+  </Channels>
+</SystemDescription>
diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/isr-en-dis.S b/c/src/lib/libbsp/sparc/xtratum/startup/isr-en-dis.S
index 0000000..c427df7
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/startup/isr-en-dis.S
@@ -0,0 +1,50 @@
+ *  irq_en_dis.S
+ *  Disabling or enabling the IRQ.
+ *  COPYRIGHT (c) 1995. European Space Agency.
+ *  COPYRIGHT (c) 2011 UPV (Universidad Politécnica de Valencia)
+ *  This terms of the RTEMS license apply to this file.
+#include <rtems/asm.h>
+#include <xm.h>
+        .seg    "text"
+        PUBLIC(sparc_disable_interrupts)
+SYM(sparc_disable_interrupts):
+	set	sparc_get_psr_nr, %o0
+	__XM_AHC
+	! psr is now in %o0
+	mov	%o0, %g1
+	__XM_AHC
+	retl
+	 mov	%g1, %o0
+        PUBLIC(sparc_enable_interrupts)
+SYM(sparc_enable_interrupts):
+	mov	%o0, %g1
+	__XM_AHC
+	! psr is now in %o0, old one in %g1
+	and	%g1, SPARC_PSR_PIL_MASK, %g1
+	andn	%o0, SPARC_PSR_PIL_MASK, %o0
+	or	%o0, %g1, %o1
+	set	sparc_set_psr_nr, %o0
+	__XM_AHC
+	retl
+	 nop
+/* end of file */
diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/linkcmds.xtratum b/c/src/lib/libbsp/sparc/xtratum/startup/linkcmds.xtratum
index 0000000..2926ce1
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/startup/linkcmds.xtratum
@@ -0,0 +1,23 @@
+/*  linkcmds
+/* Default values, can be overridden */
+_PROM_SIZE = DEFINED (_PROM_SIZE) ? _PROM_SIZE : 0;
+_PROM_START = DEFINED (_PROM_START) ? _PROM_START : 0x00000000;
+_RAM_SIZE = DEFINED (_RAM_SIZE) ? _RAM_SIZE : 16M;
+_RAM_START = DEFINED (_RAM_START) ? _RAM_START : 0x02000000;
+/* Define it to 0xdeadbeef to prevent usage of this GPTIMER */
+clock_gpt_regs = DEFINED (clock_gpt_regs) ? clock_gpt_regs : 0x4090c000;
+/* these are the maximum values */
+MEMORY
+  rom     : ORIGIN = 0x00000000, LENGTH = 0
+  ram     : ORIGIN = 0x02000000, LENGTH = 16M
+INCLUDE linkcmds.base
diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/psr.c b/c/src/lib/libbsp/sparc/xtratum/startup/psr.c
index 0000000..21a84e7
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/startup/psr.c
@@ -0,0 +1,26 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <rtems/score/sparc.h>
+#include <xm.h>
+uint32_t _SPARC_Get_PSR( void )
+  return XM_sparc_get_psr();
+void _SPARC_Set_PSR( uint32_t new_psr )
+  XM_sparc_set_psr( new_psr );
diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/setvec.c b/c/src/lib/libbsp/sparc/xtratum/startup/setvec.c
index 0000000..c370bc9
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/startup/setvec.c
@@ -0,0 +1,61 @@
+ * @file
+ * @ingroup sparc_xtratum
+ * @brief Install an interrupt vector on SPARC
+/*  This routine installs an interrupt vector on the SPARC simulator.
+ *  INPUT PARAMETERS:
+ *    handler - interrupt handler entry point
+ *    vector  - vector number
+ *    type    - 0 indicates raw hardware connect
+ *              1 indicates RTEMS interrupt connect
+ *  OUTPUT PARAMETERS:  NONE
+ *  RETURNS:
+ *    address of previous interrupt handler
+/*  COPYRIGHT (c) 1989-1998.
+ *  On-Line Applications Research Corporation (OAR).
+ *  Ported to LEON implementation of the SPARC by On-Line Applications
+ *  Research Corporation (OAR) under contract to the European Space
+ *  Agency (ESA).
+ *  LEON modifications of respective RTEMS file: COPYRIGHT (c) 1995.
+ *  European Space Agency.
+#include <bsp.h>
+#include <xm.h>
+rtems_isr_entry set_vector(                   /* returns old vector */
+  rtems_isr_entry     handler,                /* isr routine        */
+  rtems_vector_number vector,                 /* vector number      */
+  int                 type                    /* RTEMS or RAW intr  */
+  uint32_t      real_trap;
+  if ( type )
+    rtems_interrupt_catch( handler, vector, &previous_isr );
+  else
+    _CPU_ISR_install_raw_handler( vector, handler, (void *)&previous_isr );
+  real_trap = SPARC_REAL_TRAP_NUMBER( vector );
+  if ( XTRATUM_TRAP_IS_INTERRUPT( real_trap ) ) {
+    bsp_clear_interrupt( real_trap );
+    bsp_unmask_interrupt( real_trap );
+  return previous_isr;
diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c b/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
index 0000000..2d4428a
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
@@ -0,0 +1,35 @@
+ *  LEON Spurious Trap Handler
+ *  This is just enough of a trap handler to let us know what
+ *  the likely source of the trap was.
+ *  Developed as part of the port of RTEMS to the LEON implementation
+ *  of the SPARC by On-Line Applications Research Corporation (OAR)
+ *  under contract to the European Space Agency (ESA).
+ *  Modified for LEON3 BSP.
+ *  COPYRIGHT (c) 2004.
+ *  Gaisler Research.
+#include <bsp.h>
+void _BSP_Exception_frame_print( const CPU_Exception_frame *frame )
+  uint32_t trap;
+  const CPU_Interrupt_frame *isf;
+  trap = frame->trap;
+  real_trap = SPARC_REAL_TRAP_NUMBER(trap);
+  isf = frame->isf;
+  printk( "Unexpected trap (0x%02x) at address 0x%08x\n", real_trap, isf->tpc);
diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/tbr.c b/c/src/lib/libbsp/sparc/xtratum/startup/tbr.c
index 0000000..ca9d17e
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/startup/tbr.c
@@ -0,0 +1,30 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <xm.h>
+#include <fatal.h>
+uint32_t _SPARC_Get_TBR( void )
+  partitionControlTable_t * pct = XM_get_PCT();
+  xmAddress_t tbr = pct->arch.tbr;
+  return tbr;
+void _SPARC_Set_TBR( uint32_t new_tbr )
+  /* TODO: implement */
+  bsp_fatal( XTRATUM_FATAL_SET_TBR_NOT_IMPLEMENTED );
diff --git a/c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c b/c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c
index 0000000..d20da6b
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c
@@ -0,0 +1,36 @@
+ *  xmhdr.c
+ *  Partition header definition
+ *  Created for RTEMS/XM3 by Javier Coronel (jacopa at ai2.upv.es)
+ *  $Id: xmhdr.c, 2011/06/08
+ *  Porting of RTEMS to XM3.
+ *  It has been performed under IMA-SP project.
+ *  UPV (Universidad Politécnica de Valencia)
+ *  http://www.rtems.com/license/LICENSE.
+#include <xm.h>
+#include <xm_inc/arch/paging.h>
+#include <bsp.h>
+static xm_u8_t _pageTable[PAGE_SIZE*XTRATUM_SIZE_PAGE_TABLE] __attribute__((aligned(PAGE_SIZE))) __attribute__ ((section(".bsp_rwextra")));
+struct xmImageHdr xmImageHdr __XMIHDR = {
+    .sSignature=XMEF_PARTITION_MAGIC,
+    .compilationXmAbiVersion=XM_SET_VERSION(XM_ABI_VERSION, XM_ABI_SUBVERSION, XM_ABI_REVISION),
+    .compilationXmApiVersion=XM_SET_VERSION(XM_API_VERSION, XM_API_SUBVERSION, XM_API_REVISION),
+    .pageTable=(xmAddress_t)_pageTable,
+    .pageTableSize=XTRATUM_SIZE_PAGE_TABLE*PAGE_SIZE,
+    .noCustomFiles=0,
+    .eSignature=XMEF_PARTITION_MAGIC,
diff --git a/testsuites/smptests/smpfatal08/init.c b/testsuites/smptests/smpfatal08/init.c
index b005443..7387d23 100644
--- a/testsuites/smptests/smpfatal08/init.c
+++ b/testsuites/smptests/smpfatal08/init.c
@@ -56,7 +56,8 @@ void _CPU_SMP_Finalize_initialization(uint32_t cpu_count)
   assert(0);
-#if !defined(__leon__) && !defined(__PPC__) && !defined(__arm__)
+#if (!defined(__leon__) && !defined(__PPC__) && !defined(__arm__)) \
+    || defined(RTEMS_PARAVIRT)
   return 0;
1.7.7
