[PATCH v2] score: Fix thread deletion on SMP
Sebastian Huber
Fri Jun 20 07:21:04 UTC 2014
Close the thread object in _Thread_Make_zombie() so that all blocking
operations that use _Thread_Get() in the corresponding release directive
can find a terminating thread and can complete the operation.
cpukit/score/src/threadrestart.c | 10 +-
testsuites/smptests/smpthreadlife01/init.c | 200 ++++++++++++++++++--
.../smptests/smpthreadlife01/smpthreadlife01.doc | 6 +
3 files changed, 198 insertions(+), 18 deletions(-)
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 92470e5..cc2d8c3 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -55,6 +55,11 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
+ _Objects_Close(
+ _Objects_Get_information_id( the_thread->Object.id ),
+ &the_thread->Object
_Thread_Set_state( the_thread, STATES_ZOMBIE );
_Thread_queue_Extract_with_proxy( the_thread );
_Watchdog_Remove( &the_thread->Timer );
@@ -282,11 +287,6 @@ void _Thread_Close( Thread_Control *the_thread, Thread_Control *executing )
_Assert( _Thread_Is_life_protected( executing->Life.state ) );
- _Objects_Close(
- _Objects_Get_information_id( the_thread->Object.id ),
- &the_thread->Object
if ( _States_Is_dormant( the_thread->current_state ) ) {
_Thread_Make_zombie( the_thread );
} else {
diff --git a/testsuites/smptests/smpthreadlife01/init.c b/testsuites/smptests/smpthreadlife01/init.c
index 65d8709..12b6bd9 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -37,6 +37,7 @@ typedef struct {
SMP_barrier_State main_barrier_state;
SMP_barrier_State worker_barrier_state;
Thread_Control *delay_switch_for_executing;
+ rtems_id worker_id;
} test_context;
static test_context test_instance = {
@@ -45,6 +46,11 @@ static test_context test_instance = {
.worker_barrier_state = SMP_BARRIER_STATE_INITIALIZER
+static void barrier(test_context *ctx, SMP_barrier_State *state)
+ _SMP_barrier_Wait(&ctx->barrier, state, CPU_COUNT);
static void restart_extension(
Thread_Control *executing,
Thread_Control *restarted
@@ -74,7 +80,10 @@ static void switch_extension(Thread_Control *executing, Thread_Control *heir)
if (ctx->delay_switch_for_executing == executing) {
ctx->delay_switch_for_executing = NULL;
- _SMP_barrier_Wait(&ctx->barrier, &ctx->worker_barrier_state, CPU_COUNT);
+ /* (A) */
+ barrier(ctx, &ctx->worker_barrier_state);
rtems_counter_delay_nanoseconds(100000000);
/* Avoid bad profiling statisitics */
@@ -90,7 +99,8 @@ static void worker_task(rtems_task_argument arg)
ctx->worker_arg = arg;
+ /* (B) */
while (true) {
/* Do nothing */
@@ -120,7 +130,8 @@ static void test_restart(void)
sc = rtems_task_start(id, worker_task, 0);
rtems_test_assert(sc == RTEMS_SUCCESSFUL);
- _SMP_barrier_Wait(&ctx->barrier, &ctx->main_barrier_state, CPU_COUNT);
+ /* (B) */
+ barrier(ctx, &ctx->main_barrier_state);
for (arg = 1; arg < 23; ++arg) {
ctx->main_arg = arg;
@@ -129,7 +140,8 @@ static void test_restart(void)
sc = rtems_task_restart(id, arg);
+ /* (B) */
rtems_test_assert(ctx->worker_arg == arg);
@@ -168,7 +180,8 @@ static void test_delete(void)
sc = rtems_task_start(id, worker_task, arg);
+ /* (B) */
rtems_test_assert(!ctx->terminated);
@@ -190,7 +203,8 @@ static void delay_ipi_task(rtems_task_argument variant)
_ISR_Disable_without_giant(level);
(void) level;
+ /* (C) */
* Interrupts are disabled, so the inter-processor interrupt deleting us will
@@ -237,7 +251,8 @@ static void test_set_life_protection(rtems_task_argument variant)
sc = rtems_task_start(id, delay_ipi_task, variant);
+ /* (C) */
sc = rtems_task_delete(id);
@@ -256,7 +271,8 @@ static void delay_switch_task(rtems_task_argument arg)
ctx->delay_switch_for_executing = _Thread_Get_executing();
+ /* (D) */
sc = rtems_task_delete(RTEMS_SELF);
@@ -284,11 +300,11 @@ static void test_wait_for_execution_stop(void)
sc = rtems_task_start(id, delay_switch_task, 0);
- /* Wait for delay switch task */
+ /* (D) */
- /* Wait for delay switch extension */
+ /* (A) */
sc = rtems_task_create(
rtems_build_name('W', 'A', 'I', 'T'),
@@ -306,6 +322,161 @@ static void test_wait_for_execution_stop(void)
rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
+typedef enum {
+ TEST_OP_SUSPEND,
+ TEST_OP_EVENT,
+ TEST_OP_EVENT_SYSTEM
+} test_op;
+static void op_begin_suspend(void)
+ rtems_task_suspend(RTEMS_SELF);
+ rtems_test_assert(0);
+static void op_begin_event(void)
+ rtems_event_set events;
+ rtems_event_receive(
+ RTEMS_EVENT_0,
+ RTEMS_EVENT_ALL | RTEMS_WAIT,
+ RTEMS_NO_TIMEOUT,
+ &events
+static void op_begin_event_system(void)
+ rtems_event_system_receive(
+ RTEMS_EVENT_0,
+ RTEMS_NO_TIMEOUT,
+ &events
+static void (*const test_ops_begin[])(void) = {
+ op_begin_suspend,
+ op_begin_event,
+ op_begin_event_system
+static void op_end_suspend(test_context *ctx)
+ rtems_status_code sc;
+ sc = rtems_task_resume(ctx->worker_id);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void op_end_event(test_context *ctx)
+ sc = rtems_event_send(ctx->worker_id, RTEMS_EVENT_0);
+static void op_end_event_system(test_context *ctx)
+ sc = rtems_event_system_send(ctx->worker_id, RTEMS_EVENT_0);
+static void (*const test_ops_end[])(test_context *) = {
+ op_end_suspend,
+ op_end_event,
+ op_end_event_system
+static void op_worker_task(rtems_task_argument arg)
+ test_context *ctx = &test_instance;
+ test_op op = arg;
+ ISR_Level level;
+ _ISR_Disable_without_giant(level);
+ (void) level;
+ /* (E) */
+ /* (F) */
+ (*test_ops_begin[op])();
+static void help_task(rtems_task_argument arg)
+ test_op op = arg;
+ /* (F) */
+ rtems_counter_delay_nanoseconds(100000000);
+ (*test_ops_end[op])(ctx);
+static void test_operation_with_delete_in_progress(test_op op)
+ rtems_id help_id;
+ rtems_resource_snapshot snapshot;
+ rtems_resource_snapshot_take(&snapshot);
+ sc = rtems_task_create(
+ rtems_build_name('W', 'O', 'R', 'K'),
+ 1,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &ctx->worker_id
+ sc = rtems_task_start(ctx->worker_id, op_worker_task, op);
+ /* (E) */
+ rtems_build_name('H', 'E', 'L', 'P'),
+ 2,
+ &help_id
+ sc = rtems_task_start(help_id, help_task, op);
+ sc = rtems_task_delete(ctx->worker_id);
+ sc = rtems_task_delete(help_id);
+ rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
static void Init(rtems_task_argument arg)
TEST_BEGIN();
@@ -316,6 +487,9 @@ static void Init(rtems_task_argument arg)
test_set_life_protection(0);
test_set_life_protection(1);
test_wait_for_execution_stop();
+ test_operation_with_delete_in_progress(TEST_OP_SUSPEND);
+ test_operation_with_delete_in_progress(TEST_OP_EVENT);
+ test_operation_with_delete_in_progress(TEST_OP_EVENT_SYSTEM);
TEST_END();
@@ -329,7 +503,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
-#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TASKS (CPU_COUNT + 1)
#define CONFIGURE_INITIAL_EXTENSIONS \
diff --git a/testsuites/smptests/smpthreadlife01/smpthreadlife01.doc b/testsuites/smptests/smpthreadlife01/smpthreadlife01.doc
index 54fb858..011f47d 100644
--- a/testsuites/smptests/smpthreadlife01/smpthreadlife01.doc
+++ b/testsuites/smptests/smpthreadlife01/smpthreadlife01.doc
@@ -7,6 +7,9 @@ directives:
- rtems_task_restart()
- _Thread_Set_life_protection()
- _Thread_Wait_for_execution_stop()
+ - rtems_task_suspend()
+ - rtems_event_receive()
+ - rtems_event_system_receive()
concepts:
@@ -14,3 +17,6 @@ concepts:
- Ensure that a _Thread_Set_life_protection() works on SMP in case interrupt
processing is delayed.
- Ensure that _Thread_Wait_for_execution_stop() works on SMP.
+ - Ensure that rtems_task_suspend(), rtems_event_receive() and
+ rtems_event_system_receive() operations can be completed in case a thread
+ deletion is in progress on SMP.
1.7.7
