[rtems commit] JFFS2: Add device identifier for the flash device
Fri Jun 20 07:56:36 UTC 2014
On 2014-06-17 11:08, Chris Johns wrote:
> On 17/06/2014 6:51 pm, Sebastian Huber wrote:
>> On 2014-06-16 21:56, Chris Johns wrote:
>>> On 14/06/2014 2:00 am, Sebastian Huber wrote:
>>>> Module:    rtems
>>>> Branch:    master
>>>> Commit:    73bf499ce7710ff8e75833042f88d1ff5b3e84fa
>>>> Changeset:
>>>> http://git.rtems.org/rtems/commit/?id=73bf499ce7710ff8e75833042f88d1ff5b3e84fa
>>>> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
>>>> Date:      Tue Jun 10 10:56:55 2014 +0200
>>>> It is used in combination with the inode number to uniquely identify a
>>>> file system node in the system.
>>>>   cpukit/libfs/src/jffs2/include/rtems/jffs2.h |   11 ++++++++++-
>>>>   cpukit/libfs/src/jffs2/src/fs-rtems.c        |    7 +++++--
>>>>   2 files changed, 15 insertions(+), 3 deletions(-)
>>>> diff --git a/cpukit/libfs/src/jffs2/include/rtems/jffs2.h
>>>> b/cpukit/libfs/src/jffs2/include/rtems/jffs2.h
>>>> index e69fc20..7b2f4d5 100644
>>>> --- a/cpukit/libfs/src/jffs2/include/rtems/jffs2.h
>>>> +++ b/cpukit/libfs/src/jffs2/include/rtems/jffs2.h
>>>> @@ -118,7 +118,8 @@ typedef struct rtems_jffs2_flash_control
>>>> rtems_jffs2_flash_control;
>>>>    *     .flash_size = FLASH_SIZE,
>>>>    *     .read = flash_read,
>>>>    *     .write = flash_write,
>>>> - *     .erase = flash_erase
>>>> + *     .erase = flash_erase,
>>>> + *     .device_identifier = 0xc01dc0fe
>>> I cannot see anything that describes what this field is to contain. A
>>> number is
>>> a bit cryptic. Is this specific to a flash driver, all drivers, or
>>> something
>>> else ?
>>> I cannot find the flash driver used here so maybe a comment about this
>>> and
>>> where to find it would also help.
>> The description is here:
>> @@ -265,6 +266,14 @@ struct rtems_jffs2_flash_control {
>>      * This operation is optional and the pointer may be @c NULL.
>>     rtems_jffs2_flash_destroy destroy;
>> +   * @brief The device identifier of the flash device.
>> +   * It is used in combination with the inode number to uniquely
>> identify a
>> +   * file system node in the system.
>> +  dev_t device_identifier;
>>   typedef struct rtems_jffs2_compressor_control
>> rtems_jffs2_compressor_control;
>> Due to the dev_t type it should be clear what it is.
> Is there an example driver in the RTEMS source tree ?
Yes, here:
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__JFFS2.html
and here:
http://git.rtems.org/rtems/tree/testsuites/fstests/jffs2_support/fs_support.c
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
