PR2183 and affinity migration
Fri Jun 27 19:07:01 UTC 2014
On 06/27/2014 06:25 PM, Joel Sherrill wrote:
> I see this as two state changes within a single scheduler
> operation but that sounds the same as your double
> migration. We are likely replacing heir twice and tripping
> the same condition.
> If you want a test case of this, we can get our code
> cleaned up and push it. Gaisler will have to send their
> test code.
I work currently an a solution for bug PR2183 since I hit it also in a
new test case that works without the disabled thread dispatching trick.
It should be ready next week.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
