[PATCH] bsps/sparc: Reduce copy and paste
    Daniel Hellstrom
    daniel at gaisler.com
    Mon Jun 30 11:23:48 UTC 2014
Hello,
I like this initiative of having common code, however I'm not sure that all of it is good. The LEON2 UART and the LEON3 APBUART is not the same hardware. The GRLIB APBUART is compatible on most or if
not all aspects with the LEON2 AT697 UART, however the APBUART have more features that are currently not in use. I think it would be better to call the LEON3 BSP UART "APBUART" and the LEON2 UART
simply "LEON2 UART" and the common bit definitions could perhaps have a common name but not APBUART_*? It might be misleading to use APBUART_ definitions in the LEON2 code? For example LEON2
UART.STATUS.TH bit is named TE in in APBUART since they signal different things, I can see you are renaming from _THE into _TE in the LEON2 driver. I think I would prefer to just change the LEON3
console driver into APBUART_ something.
Daniel
On 06/30/2014 09:30 AM, Sebastian Huber wrote:
>   c/src/lib/libbsp/sparc/leon2/console/console.c     |   35 ++++++++++---------
>   c/src/lib/libbsp/sparc/leon2/console/debugputs.c   |   17 +++++----
>   c/src/lib/libbsp/sparc/leon2/include/leon.h        |   35 --------------------
>   c/src/lib/libbsp/sparc/leon2/include/rasta.h       |   31 -----------------
>   c/src/lib/libbsp/sparc/leon3/console/console.c     |   31 +++++++++--------
>   .../libbsp/sparc/leon3/console/printk_support.c    |   13 ++++---
>   c/src/lib/libbsp/sparc/leon3/include/leon.h        |   33 ------------------
>   c/src/lib/libbsp/sparc/shared/include/apbuart.h    |    1 +
>   c/src/lib/libbsp/sparc/shared/uart/apbuart.c       |    8 ++--
>   9 files changed, 55 insertions(+), 149 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon2/console/console.c b/c/src/lib/libbsp/sparc/leon2/console/console.c
> index cac21a6..e5768ee 100644
> --- a/c/src/lib/libbsp/sparc/leon2/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon2/console/console.c
> @@ -20,6 +20,7 @@
>   #include <stdlib.h>
>   #include <assert.h>
>   #include <rtems/bspIo.h>
> +#include <apbuart.h>
>    *  console_outbyte_polled
> @@ -81,16 +82,16 @@ rtems_isr console_isr_a(
>     char ch;
>     int UStat;
> -  if ( (UStat = LEON_REG.UART_Status_1) & LEON_REG_UART_STATUS_DR ) {
> -    if (UStat & LEON_REG_UART_STATUS_ERR) {
> -      LEON_REG.UART_Status_1 = LEON_REG_UART_STATUS_CLR;
> +  if ( (UStat = LEON_REG.UART_Status_1) & APBUART_STATUS_DR ) {
> +    if (UStat & APBUART_STATUS_ERR) {
> +      LEON_REG.UART_Status_1 = APBUART_STATUS_CLR;
>       ch = LEON_REG.UART_Channel_1;
>       rtems_termios_enqueue_raw_characters( console_termios_data[ 0 ], &ch, 1 );
> -  if ( LEON_REG.UART_Status_1 & LEON_REG_UART_STATUS_THE ) {
> +  if ( LEON_REG.UART_Status_1 & APBUART_STATUS_THE ) {
>       if ( !Ring_buffer_Is_empty( &TX_Buffer[ 0 ] ) ) {
>         Ring_buffer_Remove_character( &TX_Buffer[ 0 ], ch );
>         LEON_REG.UART_Channel_1 = (uint32_t) ch;
> @@ -121,16 +122,16 @@ rtems_isr console_isr_b(
>     char ch;
>     int UStat;
> -  if ( (UStat = LEON_REG.UART_Status_2) & LEON_REG_UART_STATUS_DR ) {
> -      LEON_REG.UART_Status_2 = LEON_REG_UART_STATUS_CLR;
> +  if ( (UStat = LEON_REG.UART_Status_2) & APBUART_STATUS_DR ) {
> +      LEON_REG.UART_Status_2 = APBUART_STATUS_CLR;
>       ch = LEON_REG.UART_Channel_2;
>       rtems_termios_enqueue_raw_characters( console_termios_data[ 1 ], &ch, 1 );
> -  if ( LEON_REG.UART_Status_2 & LEON_REG_UART_STATUS_THE ) {
> +  if ( LEON_REG.UART_Status_2 & APBUART_STATUS_THE ) {
>       if ( !Ring_buffer_Is_empty( &TX_Buffer[ 1 ] ) ) {
>         Ring_buffer_Remove_character( &TX_Buffer[ 1 ], ch );
>         LEON_REG.UART_Channel_2 = (uint32_t) ch;
> @@ -179,11 +180,11 @@ void console_exit()
>      *  should be empty.
> -  while ( (LEON_REG.UART_Status_1 & LEON_REG_UART_STATUS_THE) !=
> -          LEON_REG_UART_STATUS_THE );
> +  while ( (LEON_REG.UART_Status_1 & APBUART_STATUS_THE) !=
> +          APBUART_STATUS_THE );
> -  while ( (LEON_REG.UART_Status_2 & LEON_REG_UART_STATUS_THE) !=
> +  while ( (LEON_REG.UART_Status_2 & APBUART_STATUS_THE) !=
>     LEON_REG.UART_Control_1 = 0;
>     LEON_REG.UART_Control_2 = 0;
> @@ -223,8 +224,8 @@ void console_initialize_interrupts( void )
>     atexit( console_exit );
> -  LEON_REG.UART_Control_1 |= LEON_REG_UART_CTRL_RI | LEON_REG_UART_CTRL_TI;
> -  LEON_REG.UART_Control_2 |= LEON_REG_UART_CTRL_RI | LEON_REG_UART_CTRL_TI;
> +  LEON_REG.UART_Control_1 |= APBUART_CTRL_RI | APBUART_CTRL_TI;
> +  LEON_REG.UART_Control_2 |= APBUART_CTRL_RI | APBUART_CTRL_TI;
>     set_vector( console_isr_a, CONSOLE_UART_1_TRAP, 1 );
>   #ifdef RDB_BREAK_IN
> @@ -320,9 +321,9 @@ rtems_device_driver console_initialize(
>      *  Initialize Hardware
> -  LEON_REG.UART_Control_1 |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
> -  LEON_REG.UART_Control_2 |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE |
> -      LEON_REG_UART_CTRL_RI;  /* rx irq default enable for remote debugger */
> +  LEON_REG.UART_Control_1 |= APBUART_CTRL_RE | APBUART_CTRL_TE;
> +  LEON_REG.UART_Control_2 |= APBUART_CTRL_RE | APBUART_CTRL_TE |
> +      APBUART_CTRL_RI;  /* rx irq default enable for remote debugger */
>     LEON_REG.UART_Status_1 = 0;
>     LEON_REG.UART_Status_2 = 0;
>   #if (CONSOLE_USE_INTERRUPTS)
> diff --git a/c/src/lib/libbsp/sparc/leon2/console/debugputs.c b/c/src/lib/libbsp/sparc/leon2/console/debugputs.c
> index 4de2afc..6ddaf7b 100644
> --- a/c/src/lib/libbsp/sparc/leon2/console/debugputs.c
> +++ b/c/src/lib/libbsp/sparc/leon2/console/debugputs.c
> @@ -21,6 +21,7 @@
>   #include <rtems/libio.h>
>   #include <stdlib.h>
>   #include <assert.h>
> @@ -34,12 +35,12 @@ void console_outbyte_polled(
>     if ( port == 0 ) {
> -    while ( (LEON_REG.UART_Status_1 & LEON_REG_UART_STATUS_THE) == 0 );
> +    while ( (LEON_REG.UART_Status_1 & APBUART_STATUS_TE) == 0 );
>         LEON_REG.UART_Channel_1 = (unsigned int) ch;
>         return;
> -    while ( (LEON_REG.UART_Status_2 & LEON_REG_UART_STATUS_THE) == 0 );
> +    while ( (LEON_REG.UART_Status_2 & APBUART_STATUS_TE) == 0 );
>       LEON_REG.UART_Channel_2 = (unsigned int) ch;
> @@ -55,21 +56,21 @@ int console_inbyte_nonblocking( int port )
>     switch (port) {
>       case 0:
> -      if (LEON_REG.UART_Status_1 & LEON_REG_UART_STATUS_ERR) {
> -        LEON_REG.UART_Status_1 = ~LEON_REG_UART_STATUS_ERR;
> +      if (LEON_REG.UART_Status_1 & APBUART_STATUS_ERR) {
> +        LEON_REG.UART_Status_1 = ~APBUART_STATUS_ERR;
> -      if ((LEON_REG.UART_Status_1 & LEON_REG_UART_STATUS_DR) == 0)
> +      if ((LEON_REG.UART_Status_1 & APBUART_STATUS_DR) == 0)
>            return -1;
>         return (int) LEON_REG.UART_Channel_1;
>         return 1;
>       case 1:
> -      if (LEON_REG.UART_Status_2 & LEON_REG_UART_STATUS_ERR) {
> -        LEON_REG.UART_Status_2 = ~LEON_REG_UART_STATUS_ERR;
> +      if (LEON_REG.UART_Status_2 & APBUART_STATUS_ERR) {
> +        LEON_REG.UART_Status_2 = ~APBUART_STATUS_ERR;
> -      if ((LEON_REG.UART_Status_2 & LEON_REG_UART_STATUS_DR) == 0)
> +      if ((LEON_REG.UART_Status_2 & APBUART_STATUS_DR) == 0)
>            return -1;
>         return (int) LEON_REG.UART_Channel_2;
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/leon.h b/c/src/lib/libbsp/sparc/leon2/include/leon.h
> index 25826bd..708d77f 100644
> --- a/c/src/lib/libbsp/sparc/leon2/include/leon.h
> +++ b/c/src/lib/libbsp/sparc/leon2/include/leon.h
> @@ -232,41 +232,6 @@ typedef struct {
>   #define LEON_REG_TIMER_CONTROL_LD    0x00000004  /* 1 = load counter */
>                                                 /* 0 = no function */
> - *  The following defines the bits in the UART Control Registers.
> -#define LEON_REG_UART_CONTROL_RTD  0x000000FF /* RX/TX data */
> - *  The following defines the bits in the LEON UART Status Registers.
> -#define LEON_REG_UART_STATUS_CLR  0x00000000 /* Clear all status bits */
> -#define LEON_REG_UART_STATUS_DR   0x00000001 /* Data Ready */
> -#define LEON_REG_UART_STATUS_TSE  0x00000002 /* TX Send Register Empty */
> -#define LEON_REG_UART_STATUS_THE  0x00000004 /* TX Hold Register Empty */
> -#define LEON_REG_UART_STATUS_BR   0x00000008 /* Break Error */
> -#define LEON_REG_UART_STATUS_OE   0x00000010 /* RX Overrun Error */
> -#define LEON_REG_UART_STATUS_PE   0x00000020 /* RX Parity Error */
> -#define LEON_REG_UART_STATUS_FE   0x00000040 /* RX Framing Error */
> -#define LEON_REG_UART_STATUS_ERR  0x00000078 /* Error Mask */
> -#define LEON_REG_UART_CTRL_RE     0x00000001 /* Receiver enable */
> -#define LEON_REG_UART_CTRL_TE     0x00000002 /* Transmitter enable */
> -#define LEON_REG_UART_CTRL_RI     0x00000004 /* Receiver interrupt enable */
> -#define LEON_REG_UART_CTRL_TI     0x00000008 /* Transmitter interrupt enable */
> -#define LEON_REG_UART_CTRL_PS     0x00000010 /* Parity select */
> -#define LEON_REG_UART_CTRL_PE     0x00000020 /* Parity enable */
> -#define LEON_REG_UART_CTRL_FL     0x00000040 /* Flow control enable */
> -#define LEON_REG_UART_CTRL_LB     0x00000080 /* Loop Back enable */
>   #ifndef ASM
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/rasta.h b/c/src/lib/libbsp/sparc/leon2/include/rasta.h
> index b7eccb4..d2f765f 100644
> --- a/c/src/lib/libbsp/sparc/leon2/include/rasta.h
> +++ b/c/src/lib/libbsp/sparc/leon2/include/rasta.h
> @@ -55,37 +55,6 @@ extern int rasta_register(void);
>   #define UART0_IRQ   (1<<UART0_IRQNO)
>   #define UART1_IRQ   (1<<UART1_IRQNO)
>   #define UART_SET_SCALER 0
>   #define UART_SET_CTRL   1
>   #define UART_GET_STAT   2
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
> index cdfbf2a..235788c 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
> @@ -34,6 +34,7 @@
>   #include <leon.h>
>   #include <rtems/termiostypes.h>
>   int syscon_uart_index __attribute__((weak)) = 0;
> @@ -74,7 +75,7 @@ static void leon3_console_isr(void *arg)
>     char data;
>     /* Get all received characters */
> -  while ((status=uart->regs->status) & LEON_REG_UART_STATUS_DR) {
> +  while ((status=uart->regs->status) & APBUART_STATUS_DR) {
>       /* Data has arrived, get new data */
>       data = uart->regs->data;
> @@ -83,8 +84,8 @@ static void leon3_console_isr(void *arg)
>     if (
> -    (status & LEON_REG_UART_STATUS_THE)
> -      && (uart->regs->ctrl & LEON_REG_UART_CTRL_TI) != 0
> +    (status & APBUART_STATUS_THE)
> +      && (uart->regs->ctrl & APBUART_CTRL_TI) != 0
>       /* write_interrupt will get called from this function */
>       rtems_termios_dequeue_characters(uart->cookie, 1);
> @@ -102,7 +103,7 @@ static int leon3_console_write_support(int minor, const char *buf, size_t len)
>     if (len > 0) {
>       /* Enable TX interrupt (interrupt is edge-triggered) */
> -    uart->regs->ctrl |= LEON_REG_UART_CTRL_TI;
> +    uart->regs->ctrl |= APBUART_CTRL_TI;
>       /* start UART TX, this will result in an interrupt when done */
>       uart->regs->data = *buf;
> @@ -110,7 +111,7 @@ static int leon3_console_write_support(int minor, const char *buf, size_t len)
>       sending = 1;
>     } else {
>       /* No more to send, disable TX interrupts */
> -    uart->regs->ctrl &= ~LEON_REG_UART_CTRL_TI;
> +    uart->regs->ctrl &= ~APBUART_CTRL_TI;
>       /* Tell close that we sent everything */
>       sending = 0;
> @@ -180,26 +181,26 @@ static int leon3_console_set_attributes(int minor, const struct termios *t)
>     switch (t->c_cflag & (PARENB|PARODD)) {
>       case (PARENB|PARODD):
>         /* Odd parity */
> -      ctrl |= LEON_REG_UART_CTRL_PE|LEON_REG_UART_CTRL_PS;
> +      ctrl |= APBUART_CTRL_PE|APBUART_CTRL_PS;
>         break;
>       case PARENB:
>         /* Even parity */
> -      ctrl &= ~LEON_REG_UART_CTRL_PS;
> -      ctrl |= LEON_REG_UART_CTRL_PE;
> +      ctrl &= ~APBUART_CTRL_PS;
> +      ctrl |= APBUART_CTRL_PE;
>         break;
>       default:
>       case 0:
>       case PARODD:
>         /* No Parity */
> -      ctrl &= ~(LEON_REG_UART_CTRL_PS|LEON_REG_UART_CTRL_PE);
> +      ctrl &= ~(APBUART_CTRL_PS|APBUART_CTRL_PE);
>     if (!(t->c_cflag & CLOCAL)) {
> -    ctrl |= LEON_REG_UART_CTRL_FL;
> +    ctrl |= APBUART_CTRL_FL;
>     } else {
> -    ctrl &= ~LEON_REG_UART_CTRL_FL;
> +    ctrl &= ~APBUART_CTRL_FL;
>     /* Update new settings */
> @@ -339,11 +340,11 @@ static int leon3_console_first_open(int major, int minor, void *arg)
>     uart->sending = 0;
>     /* Enable Receiver and transmitter and Turn on RX interrupts */
> -  uart->regs->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE |
> +  uart->regs->ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE |
> +                      APBUART_CTRL_RI;
>   #else
>     /* Initialize UART on opening */
> -  uart->regs->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
> +  uart->regs->ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE;
>   #endif
>     uart->regs->status = 0;
> @@ -359,7 +360,7 @@ static int leon3_console_last_close(int major, int minor, void *arg)
>     /* Turn off RX interrupts */
>     rtems_termios_interrupt_lock_acquire(tty, level);
> -  uart->regs->ctrl &= ~(LEON_REG_UART_CTRL_RI);
> +  uart->regs->ctrl &= ~(APBUART_CTRL_RI);
>     rtems_termios_interrupt_lock_release(tty, level);
>     /**** Flush device ****/
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
> index 35fb4b5..d12099b 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
> @@ -21,6 +21,7 @@
>   #include <stdlib.h>
>   #include <assert.h>
>   #include <stdio.h>
>   int debug_uart_index __attribute__((weak)) = 0;
>   static struct apbuart_regs *dbg_uart = NULL;
> @@ -69,7 +70,7 @@ void bsp_debug_uart_init(void)
>       apb = (struct ambapp_apb_info *)adev->devinfo;
>       dbg_uart = (struct apbuart_regs *)apb->start;
> -    dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
> +    dbg_uart->ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE;
>       dbg_uart->status = 0;
> @@ -87,7 +88,7 @@ void apbuart_outbyte_polled(
>   send:
> -  while ( (regs->status & LEON_REG_UART_STATUS_THE) == 0 ) {
> +  while ( (regs->status & APBUART_STATUS_TE) == 0 ) {
>       /* Lower bus utilization while waiting for UART */
>       __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
> @@ -103,7 +104,7 @@ send:
>     /* Wait until the character has been sent? */
>     if (wait_sent) {
> -    while ((regs->status & LEON_REG_UART_STATUS_THE) == 0)
> +    while ((regs->status & APBUART_STATUS_TE) == 0)
> @@ -116,10 +117,10 @@ send:
>   int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
>     /* Clear errors */
> -  if (regs->status & LEON_REG_UART_STATUS_ERR)
> -    regs->status = ~LEON_REG_UART_STATUS_ERR;
> +  if (regs->status & APBUART_STATUS_ERR)
> +    regs->status = ~APBUART_STATUS_ERR;
> -  if ((regs->status & LEON_REG_UART_STATUS_DR) == 0)
> +  if ((regs->status & APBUART_STATUS_DR) == 0)
>       return EOF;
>     else
>       return (int) regs->data;
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> index ccf2fb7..d7048f3 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> @@ -86,39 +86,6 @@ extern "C" {
>   /* LEON3 Interrupt Controller */
>   extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
>   /* LEON3 GP Timer */
> diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart.h b/c/src/lib/libbsp/sparc/shared/include/apbuart.h
> index 139d1ec..2f34a11 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/apbuart.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/apbuart.h
> @@ -71,6 +71,7 @@ typedef struct {
>   #define APBUART_STATUS_OV 0x10
>   #define APBUART_STATUS_PE 0x20
>   #define APBUART_STATUS_FE 0x40
> +#define APBUART_STATUS_ERR 0x78
>   #define APBUART_STATUS_TH 0x80
>   #define APBUART_STATUS_RH 0x100
>   #define APBUART_STATUS_TF 0x200
> diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
> index e64784f..d63b324 100644
> --- a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
> +++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
> @@ -158,7 +158,7 @@ static void apbuart_hw_open(apbuart_priv *uart);
>   #if 0
>   static int apbuart_outbyte_try(struct apbuart_regs *regs, unsigned char ch)
> -	if ( (READ_REG(®s->status) & LEON_REG_UART_STATUS_THE) == 0 )
> +	if ( (READ_REG(®s->status) & APBUART_STATUS_THE) == 0 )
>   		return -1; /* Failed */
>   	/* There is room in fifo, put ch in it */
> @@ -171,12 +171,12 @@ static int apbuart_inbyte_try(struct apbuart_regs *regs)
>   	unsigned int status;
>   	/* Clear errors if any */
> -	if ( (status=READ_REG(®s->status)) & LEON_REG_UART_STATUS_ERR) {
> -		regs->status = status & ~LEON_REG_UART_STATUS_ERR;
> +	if ( (status=READ_REG(®s->status)) & APBUART_STATUS_ERR) {
> +		regs->status = status & ~APBUART_STATUS_ERR;
>   	/* Is Data available? */
> -	if ( (READ_REG(®s->status) & LEON_REG_UART_STATUS_DR) == 0 )
> +	if ( (READ_REG(®s->status) & APBUART_STATUS_DR) == 0 )
>   		return -1; /* No data avail */
>   	/* Return Data */
